Template:Protection padlock/doc
Revision as of 01:56, 2 September 2025 by RetroTechCollection>Waddie96 (t/d)
This is a general template for producing protection banners and padlock icons. It can be used with any protection reason, any protection action, and any protection level.
Usage
{{pp
| 1        = reason
| small    = yes
| action   = action
| date     = protection date
| user     = username
| section  = talk page section name
| category = no
Parameters
All parameters are optional:
  • |1= โ€“ The reason that the page was protected. If set, this must be one of the values listed in the reasons table.
  • |small= โ€“ If set to yes, y, 1, or true, a padlock icon is generated instead of a full protection banner.
  • |action= โ€“ The protection action. Must be one of edit (for normal protection), move (for move-protection) or autoreview (for pending changes). The default value is edit.
  • |date= โ€“ The protection date. This must be valid input to the second parameter of the #time parser function. This argument only has an effect for the office and reset reasons.
  • |user= โ€“ The username of the user to generate links for. As of July 2014, this only has an effect when the usertalk reason is specified.
  • |section= โ€“ The section name of the protected page's talk page where discussion is taking place. This works for most, but not all, values of reason.
  • |category= โ€“ Categories are suppressed if this is set to no, n, 0, or false.
Reasons
The following table contains the available reasons, plus the actions for which they are available. Reasons are used to customize the banner text, to place articles in more specific hidden categories such as Category:Wikipedia pages semi-protected against vandalism, and sometimes to change the icon of the banner (e.g. office actions).
Reason Action Description
blp edit For pages protected to promote compliance with the biographies of living persons policy
dispute edit For pages protected due to editing disputes
dmca edit For pages protected by the RTC due to Digital Millennium Copyright Act takedown requests
ecp edit For articles in topic areas authorized by ArbCom or meets the criteria for community use
mainpage edit For pages protected for being displayed on the Main Page
office edit For pages protected by the Wikimedia Foundation
reset edit For pages protected by the Wikimedia Foundation and "reset" to a bare-bones version
sock edit For pages protected due to sock puppetry
template edit For high-risk templates and Lua modules
usertalk edit For pages protected against disruptive edits by a particular user
vandalism edit For pages protected against vandalism
dispute move For pages protected against page moves due to disputes over the page title
vandalism move For pages protected against page-move vandalism
Syntax examples
Padlock icons
Padlock icon for a page protected due to vandalism:
{{pp|vandalism|small=yes}}
Padlock icon for a page temporarily protected due to editing disputes:
{{pp|dispute|small=yes}}
Banners
Banner for a page protected due to sockpuppetry, with a link to a talk page discussion:
{{pp|sock|section=Sockpuppetry concerns}}
Banner for a page temporarily move-protected due to page-move vandalism:
{{pp|vandalism|action=move}}
Visibility
This template will hide itself (not display a padlock icon) if it is used on a page that is not currently protected. User:MusikBot II may also automatically remove the template wikicode from pages that are not currently protected.
TemplateData
This is the TemplateData for this template used by TemplateWizard, VisualEditor and other tools. See a monthly parameter usage report for Template:Protection padlock in articles based on its TemplateData.
TemplateData for Protection padlock
Produces banners to describe why a page is protected and padlock icons
Template parameters
ParameterDescriptionTypeStatus
Reason1
Reason for protection, may be one of: blp, dispute, dmca, mainpage, office, reset, sock, template, usertalk, vandalism
Suggested values
vandalism template usertalk blp dispute dmca ecp mainpage reset sock office
Stringsuggested
Small?small
Specifies whether only a padlock is generated. If set to "yes", "y", "1", or "true", a padlock icon is generated instead of a full protection banner.
Default
0
Example
1
Booleansuggested
Restricted actionaction
Action which is restricted. Must be one of "edit" (for normal protection), "move" (for move-protection) or "autoreview" (for pending changes).
Suggested values
edit move autoreview
Default
Example
move
Stringsuggested
Date protecteddate
Protection date. This must be valid input to the second parameter of the #time parser function. This argument only has an effect for the "office" and "reset" reasons.
Example
yyyy-mm-dd
Dateoptional
Usernameuser
Username of the user to generate links for. This only has an effect when the "usertalk" reason is specified.
Useroptional
Section name of talksection
Section name of the protected page's talk page where discussion is taking place. This works for most, but not all, values of reason.
Stringoptional
Categorize?category
Categories are suppressed if this is set to "no", "n", "0", or "false".
Default
1
Example
0
Booleanoptional
