Sad Mac Error Codes
Sad Mac with Error Code
The "Sad Mac" is a visual indicator displayed by vintage Macintosh computers (128K, 512K, Plus, SE, and SE/30) when a hardware failure prevents successful startup. Sad Mac error codes are valuable diagnostic tools that pinpoint specific hardware issues.
Understanding Sad Mac Error Codes
When you encounter a Sad Mac, it will show an error code in hexadecimal format. This code typically consists of two parts:
  • Class Code (First two digits): Identifies the diagnostic test or CPU exception that failed.
  • Subcode (Last four digits): Gives specific details about the error, such as identifying a faulty RAM chip.
Macintosh 128K, 512K, 512Ke, and Plus
The original ROM-based Macintosh computers (128K, 512K, 512Ke, Plus) use the following Sad Mac format:
Original ROM (Mac 128K, 512K, 512Ke, Plus) Sad Mac Codes
Class Code Meaning Subcode Description
01 ROM Test Failed Meaningless
02 Memory Test – Bus Subtest Identifies specific bad RAM chip
03 Memory Test – Byte Write Identifies specific bad RAM chips
04 Memory test–Mod3 test Identifies specific bad RAM chips
05 Memory test–Address uniqueness Identifies specific bad RAM chips
0F Exception (CPU Error) Identifies specific exception (e.g., illegal instruction, zero divide)
Single RAM Chip Identification
RAM errors provide a bitmask to identify the faulty chip:
Single Chip Identification
Data Bit Location Subcode Bits
0 F5 0001
1 F6 0002
2 F7 0004
3 F8 0008
3 F8 0008
4 F9 0010
5 F10 0020
6 F11 0040
7 F12 0080
8 G5 0100
9 G6 0200
10 G7 0400
11 G8 0800
12 G9 1000
12 G10 2000
13 G11 4000
14 G12 8000
Common Exception Codes (Class 0F)
Subcode Meaning
0001 Bus Error
0002 Address Error
0003 Illegal Instruction
0004 Zero Divide
0005 Check Instruction
0006 Traps Instruction
0007 Privilege Violation
0008 Trace
0009 Line 1010 Exception
000A Line 1111 Exception
000B Other Exception
000C Nothing (reserved)
000D NMI (Normal indication)
0064 Couldn't read System File into memory
Macintosh SE and SE/30 Expanded Codes
Mac SE and SE/30 use an enhanced two-line Sad Mac code format for more detailed diagnostics:
SE & SE/30 Extended Codes
YYYY Code Meaning
0001 ROM checksum failed
0002 Small RAM chunk failed (Bank B)
0003 RAM Bank B failed
0004 RAM Bank A test failed
0005 External addressing test failed
0006 Unable to address VIA1
000B Unable to access SCSI chip
000C Unable to access IWM (floppy controller)
000D Unable to access SCC (serial ports)
000E Data bus test failure
SE/30 Specific Issues: Simasimac
A common SE/30 issue is known as "Simasimac," where vertical stripes appear at startup, It’s often due to leaking capacitors on the logic board causing circuit corrosion. The fix is to thoroughly clean the board, repair any corroded traces (especially around the ROM SIMM and GLU chips), and recap the board. No chime with vertical lines basically means the CPU never even verified the ROM – so likely the ROM isn’t being read properly (dirty ROM SIMM contacts or damaged traces to it are common causes).
"Simasimac" vertical stripes
Chimes of Death
Macintosh II and SE series play distinctive "Chimes of Death" indicating hardware issues at startup, in addition to the Sad Mac icon.
Additional Notes
  • Always cross-reference Sad Mac codes with physical inspection (capacitor leakage, corrosion, etc.).
  • Use diagnostic tools cautiously; incorrect use may damage hardware further.
