Apple Trackball
Revision as of 18:39, 7 September 2025 by Josh (talk | contribs) (Created page with "{{Infobox computer peripheral | name = ADB Trackballs | image = 250px | caption = Kensington Turbo Mouse Version 4.0 ADB trackball | manufacturer = Kensington, Logitech, CH Products, others | type = Pointing device / Trackball | release date = 1987 (first ADB models) | discontinued = 2000 (transition to USB) | price = US$169-199 (typical retail) | interface = Apple Desktop Bus | compatible...")
ADB Trackballs
File:Kensington Turbo Mouse ADB.jpg
Manufacturer Kensington, Logitech, CH Products, others
Type Pointing device / Trackball
Discontinued 2000 (transition to USB)
Price US$169-199 (typical retail)
Interface Apple Desktop Bus
Compatible All ADB-equipped Macs (System 6.0.7 or later)
Dimensions Varies by model
Weight 400-600g typical
Predecessor Serial/quadrature trackballs
Successor USB trackballs
ADB trackballs were pointing devices designed for use with Apple Desktop Bus-equipped Macintosh computers from the late 1980s through the late 1990s. While Apple never produced a standalone ADB trackball (only integrating them into portable computers), third-party manufacturers filled this market niche with numerous models that became essential tools for desktop publishing, CAD work, and accessibility applications. The most successful was the Kensington Turbo Mouse series, which dominated the Mac trackball market throughout the ADB era.
Historical Context
The introduction of Apple Desktop Bus in 1986 with the Apple IIGS and Macintosh SE created a standardized interface for input devices. This prompted peripheral manufacturers to develop alternatives to the traditional mouse, particularly for users requiring greater precision or those with repetitive strain injuries. Trackballs offered stationary operation ideal for cramped workspaces and reduced arm movement for users with mobility limitations.
The first ADB trackballs appeared in 1987, initially as rebranded or modified versions of existing serial devices. By 1988, purpose-built ADB trackballs emerged with features specifically targeting Macintosh users, including multiple buttons programmable through software and high-resolution tracking mechanisms. The market peaked in the mid-1990s before declining with the transition to USB in 1998-1999.
Major Manufacturers and Models
Kensington Turbo Mouse Series
The Kensington Turbo Mouse, later renamed Expert Mouse for trademark reasons, was the most popular ADB trackball series for Macintosh computers.
Version History:
  • Version 1.0 (1987): Model #62350 - Quadrature output, rebranded Assimilation Process AP07045
  • Version 2.0 (1988): Model #62352 - First native ADB interface
  • Version 3.0 (1989): Model #62360 - Two buttons, ADB passthrough ports, DIP switches
  • Version 4.0 (1991): Model #64100 - Improved mechanism, side-by-side ADB ports
  • Version 5.0 (1994): Model #64210 - Four-button configuration, enhanced software support
  • USB/ADB hybrid (2000): Model #64215 - Final ADB-compatible model with USB primary interface
Technical Specifications (Version 4.0):
  • Ball diameter: 57mm (2.25 inches) - regulation pool ball size
  • Resolution: 200 CPI (counts per inch)
  • Buttons: 2 or 4 depending on version
  • Tracking: Optical levering technology
  • ADB ports: 2 passthrough connectors
  • Compatibility: System 6.0.7 through Mac OS 9.2.2
Logitech TrackMan Series
Logitech entered the Mac trackball market in 1989 with ADB versions of their PC trackballs.
ADB Models:
  • TrackMan: Original thumb-operated design
  • TrackMan Stationary: Large ball centered design
  • MouseMan/TrackMan combo: Convertible mouse/trackball hybrid
Technical Specifications:
  • Ball diameter: 32mm (thumb models) or 40mm (finger models)
  • Resolution: 200-300 CPI depending on model
  • Tracking: Opto-mechanical with slotted wheel encoders
  • Buttons: 2-3 standard
  • Software: MouseWare for programmable functions
CH Products RollerMouse
CH Products produced several ADB trackballs targeting both Mac and Apple IIGS users.
Features:
  • Buttons: 4 total (2 programmable)
  • ADB passthrough: Single port
  • Ball diameter: 50mm
  • Unique feature: Hardware-switchable button mapping
Other Manufacturers
  • CoStar Stingray: Budget model with 2 buttons
  • Mouse Systems A3 Trackball: High-end CAD-focused device
  • Microspeed MacTrac: Included proprietary acceleration software
  • Curtis MVP Mouse: Combination trackball/touchpad device
Technical Architecture
ADB Protocol Implementation
ADB trackballs communicated using the standard Apple Desktop Bus protocol:
Device addressing:
  • Default address: $3 (relative positioning device)
  • Handler ID: $01 for standard mouse, $02 for extended mouse
  • Polling rate: 100 Hz maximum
  • Data format: 2-byte packets for X/Y deltas
Register structure:
  • Register 0: Device data (movement and button state)
  • Register 1: Reserved
  • Register 2: Status flags and LED state
  • Register 3: Device handler ID and address
Tracking Technologies
Opto-Mechanical
Most ADB trackballs used opto-mechanical tracking:
Components:
  • Encoders: Slotted wheels interrupting infrared beam
  • Rollers: X and Y axis contact with ball
  • Resolution: 100-400 CPI typical
  • Maintenance: Regular cleaning required
Common issues:
  • Roller contamination from skin oils and debris
  • Encoder wheel damage from forced movement
  • Infrared emitter/detector degradation
Optical Levering
Kensington's proprietary technology used optical sensors to detect ball rotation:
Mechanism:
  • Sensors: Four-cell linear optical arrays
  • Pattern detection: Contrast stripes on ball surface
  • Processing: Hardware quadrature generation
  • Advantage: More consistent tracking than mechanical
Button Implementation
Mechanical switches:
  • Type: Typically Omron D2F series microswitches
  • Lifespan: 1-5 million clicks rated
  • Actuation force: 75-150 grams
  • Modification: Some users replaced with lighter switches
Software programmability:
  • System 7 and later: Third-party control panels
  • Functions: Click, double-click, drag lock, modifier keys
  • Acceleration curves: Customizable through software
Internal Construction
Kensington Turbo Mouse Disassembly
Tools required:
  • Phillips screwdriver #1
  • Plastic spudgers
  • Isopropyl alcohol for cleaning
Disassembly procedure:
  1. Remove trackball by inverting unit
  2. Locate and remove 2-8 screws (varies by version)
  3. Note: Version 3.0-4.0 have screws hidden under label
  4. Separate top and bottom case halves
  5. Disconnect ribbon cable if present
  6. Remove PCB mounting screws
Internal components:
  • Main PCB: Contains ADB controller and button switches
  • Sensor board: Optical or mechanical encoders
  • Cable: Usually non-removable, strain relief critical
  • Bearings: Ruby or ceramic ball supports
Common Maintenance Procedures
Ball and Bearing Cleaning
Cleaning schedule:
  • Light use: Every 3 months
  • Heavy use: Monthly
  • Signs needed: Erratic cursor, increased resistance
Procedure:
  1. Remove ball and inspect for damage
  2. Clean ball with mild soap and water
  3. Clean bearings with isopropyl alcohol on cotton swab
  4. For optical models, clean sensor windows
  5. Lubrication generally not recommended
Roller Maintenance (Mechanical Models)
Cleaning rollers:
  1. Remove accumulated debris with tweezers
  2. Clean with isopropyl alcohol
  3. Check for flat spots or grooves
  4. Replace foam cleaning pads if degraded
Roller replacement:
  • Source from donor units
  • Some compatible with mouse rollers
  • Ensure proper spring tension
Common Issues and Diagnostics
Tracking Problems
Tracking Issue Diagnostics
Symptom Likely Cause Test Method Solution
Cursor jumps erratically Dirty sensors/rollers Visual inspection Clean thoroughly with alcohol
Cursor won't move one axis Failed encoder or roller Swap X/Y mechanically Replace encoder assembly
Intermittent movement Loose cable or connector Wiggle test at strain relief Resolder connections
Cursor drift Contaminated ball surface Clean ball, check for damage Replace ball if worn
Sluggish response Software acceleration disabled Check control panel settings Reinstall driver software
Button Failures
Button Problem Diagnostics
Problem Symptoms Cause Repair Method
Click not registering Intermittent or no response Worn microswitch Replace switch (Omron D2F)
Double-clicking Single click registers twice Dirty contacts Clean or replace switch
Stuck button Button remains depressed Mechanical binding Disassemble and realign
Mushy feel No tactile feedback Spring fatigue Replace entire switch
ADB Communication Issues
Diagnostic steps:
  1. Test on known-good ADB port
  2. Try different ADB chain position
  3. Check for bent pins in connector
  4. Verify cable continuity with multimeter
  5. Test with minimal ADB chain
Common causes:
  • Excessive bus current draw (>500mA total)
  • Cable damage at strain relief
  • Corroded connector pins
  • Failed ADB transceiver chip
Repair Procedures
Cable Repair
ADB trackballs typically had permanently attached cables prone to failure at the strain relief.
Testing cable integrity:
  1. Use multimeter in continuity mode
  2. Check each conductor (4 wires: +5V, Ground, Data, PSW)
  3. Flex cable while testing to find intermittent breaks
  4. Common failure point: 2-3 inches from device
Repair method:
  1. Disassemble trackball completely
  2. Cut cable past break point
  3. Strip and tin wire ends
  4. Solder to PCB maintaining color code:
 * Red: +5V
 * Black: Ground
 * Green: Data
 * Yellow: Power switch (if present)
  1. Add heat shrink for strain relief
  2. Consider adding flexible silicone at exit point
Switch Replacement
Identifying switch type:
  • Most use Omron D2F series microswitches
  • Some use Alps SKHHAJ series
  • Measure physical dimensions before ordering
Replacement procedure:
  1. Desolder defective switch with desoldering braid
  2. Note orientation of switch terminals
  3. Install new switch ensuring flat mounting
  4. Test actuation before reassembly
  5. Adjust actuator arm if necessary
Bearing Replacement
Ruby/Ceramic bearings (Kensington):
  • Part identification: Usually 3mm ceramic balls
  • Source: Industrial bearing suppliers (Si3N4 ceramic)
  • Installation: Glue with cyanoacrylate adhesive
  • Alignment: Critical for smooth operation
Roller replacement (Mechanical):
  • Clean shaft thoroughly
  • Check spring tension
  • Ensure perpendicular alignment
  • Test free rotation before assembly
Optical Sensor Cleaning
For optical trackballs:
  1. Locate sensor windows (usually 2-4)
  2. Clean with cotton swab and isopropyl alcohol
  3. Check for scratches on windows
  4. Verify LED illumination with digital camera
  5. Clean ball pattern if applicable
Electronic Troubleshooting
ADB Controller Issues
Common controller chips:
  • Kensington: Custom ASIC or licensed Apple chip
  • Logitech: Proprietary controller
  • Generic: Often 8051-based microcontroller
Testing controller:
  1. Check for +5V at chip power pins
  2. Verify clock signal (usually 1-4 MHz)
  3. Monitor data line for activity
  4. Controller replacement usually not feasible
Power Supply Problems
ADB power specifications:
  • Voltage: +5V ±5%
  • Current: 100mA maximum per device
  • Total bus: 500mA maximum
Diagnostics:
  1. Measure voltage at device
  2. Check current draw with ammeter
  3. Test with external powered ADB hub
  4. Verify host computer PSU stability
Software and Drivers
System Software Requirements
Minimum requirements:
  • System 6.0.7: Basic ADB support
  • System 7.0: Enhanced button programmability
  • System 7.5: Native acceleration control
  • Mac OS 8-9: Full USB/ADB compatibility
Third-Party Software
Kensington MouseWorks:
  • Versions: 1.0 (System 6) through 5.0.2 (Mac OS 9)
  • Features: Button programming, acceleration curves, chord clicks
  • Installation: Control panel and extension
Logitech MouseWare:
  • Compatibility: System 6.0.8 through Mac OS 9.2.2
  • Features: Similar to MouseWorks plus game profiles
  • Known issues: Conflicts with some USB drivers
Generic drivers:
  • USB Overdrive: Supported some ADB devices
  • SteerMouse: Limited ADB compatibility
  • System native: Basic 1-button operation always available
Modifications and Enhancements
Ball Replacements
Alternative balls:
  • Pool balls: Regulation 2.25" for Kensington
  • Phenolic resin: Better than standard plastic
  • Custom colors: Popular modification for personalization
  • Weight considerations: Heavier balls increase momentum
Switch Modifications
Lighter actuation:
  • Replace Omron D2F-01 (150g) with D2F-L (75g)
  • Add lever arm extension for mechanical advantage
  • Some users removed springs entirely
Cleaning Mechanism Improvements
Foam pad replacement:
  • Material: Low-density polyurethane foam
  • Thickness: 2-3mm typical
  • Attachment: Double-sided tape or adhesive
  • Function: Continuous roller cleaning
Preventive Maintenance
Regular Maintenance Schedule
Weekly (heavy use):
  • Wipe ball with microfiber cloth
  • Check for debris around bearings
Monthly:
  • Remove ball and clean bearings
  • Inspect cable for damage
  • Test all buttons
Quarterly:
  • Full disassembly and cleaning
  • Check internal connections
  • Update driver software if available
Annually:
  • Consider preventive switch replacement
  • Inspect PCB for capacitor issues
  • Document any degradation
Storage Recommendations
Long-term storage:
  • Clean thoroughly before storage
  • Store with ball removed
  • Protect from dust with cover
  • Avoid extreme temperatures
  • Coil cable loosely to prevent damage
Modern Usage
ADB to USB Conversion
Hardware adapters:
  • Griffin iMate: Discontinued but highly regarded
  • Wombat: Current production, programmable
  • DIY solutions: Teensy-based converters
Compatibility issues:
  • Power requirements may exceed USB limits
  • Button mapping requires configuration
  • Some acceleration features lost
  • Latency typically 1-3ms added
Replacement Parts Sources
Components still available:
  • Microswitches: Electronics suppliers
  • Bearings: Industrial suppliers
  • Cables: Generic 4-conductor
  • Cleaning supplies: Standard computer maintenance
Discontinued parts:
  • Original balls: Check vintage computer forums
  • Optical sensors: Salvage from donor units
  • Custom ASICs: No replacement available
  • Specific plastic parts: 3D printing possible
Collector Information
Desirable Models
High value:
  • Kensington Turbo Mouse 5.0 (4-button)
  • Rare color variants (white, black)
  • New-in-box examples
Common models:
  • Kensington Turbo Mouse 3.0/4.0
  • Logitech TrackMan
  • CH Products RollerMouse
Preservation Guidelines
  • Prevent UV exposure to reduce yellowing
  • Maintain 40-60% humidity
  • Regular exercise prevents mechanism seizure
  • Document serial numbers and versions
  • Preserve original software and documentation
Legacy and Impact
ADB trackballs represented a significant ergonomic alternative during the desktop publishing revolution of the late 1980s and 1990s. They were particularly popular among:
  • Graphic designers: Precision for detailed work
  • CAD operators: Reduced arm movement for long sessions
  • Users with disabilities: Accessibility advantages
  • Musicians: Used for MIDI sequencing (notably Prince used Kensington Turbo Mouse)
The technology and design principles developed for ADB trackballs directly influenced modern USB and wireless trackballs, with many current models maintaining similar ball sizes, button layouts, and tracking mechanisms established during the ADB era.
