Acorn Archimedes A310
Revision as of 18:25, 9 September 2025 by Josh (talk | contribs) (→System Components)
File:Acorn Archimedes A310.jpg
TypePersonal Computer
ReleasedJune 1987
Discontinued1989
Intro price£875 (1987)
CPUARM2 @ 8 MHz
Memory1 MB RAM (expandable to 4 MB)
Storage3.5" floppy drive (800 KB), optional hard drive
Display640×512 (16 colours), 640×256 (256 colours), 1152×896 (monochrome)
Sound8-channel stereo, 8-bit logarithmic DAC
Dimensions415 mm × 355 mm × 104 mm
Weight8 kg
OS / FirmwareArthur 0.30 (later RISC OS 2.00)
PredecessorBBC Master
SuccessorAcorn Archimedes A410, Acorn Archimedes A3000
CodenameFairway
Model no.A305, A310, A440
The Acorn Archimedes A310 was the first mass-market computer to use a RISC processor, released in June 1987 alongside the A305 and A440 models. Built around Acorn's revolutionary ARM2 processor, the A310 delivered unprecedented performance for its price point, outperforming the Motorola 68000-based competition while maintaining full BBC BASIC compatibility through its advanced operating system.
Architecture
The A310's architecture represented a radical departure from conventional microcomputer design. At its core, the ARM2 processor implemented a Reduced Instruction Set Computer philosophy with a streamlined 32-bit architecture. The processor executed most instructions in a single cycle, achieving 4-8 MIPS performance at 8 MHz when contemporary 68000 and 80286 processors struggled to reach 2 MIPS at similar clock speeds.
System Components
Component Part Number Function Key Features
ARM2 VL2333-PC10 32-bit RISC CPU 25,000 transistors, 68-pin PLCC, <1W power
MEMC VL7991-PC11 Memory controller CAM-based MMU, DMA control, 84-pin PLCC
VIDC VL475-PC12 Video/sound controller 4096 colors, 8-channel DMA sound, 88-pin PLCC
IOC VL2966-PC10 I/O controller Timers, interrupts, peripherals, 68-pin PLCC
The system employed four custom VLSI chips that Acorn designed specifically for the Archimedes range. These chips communicated via a high-speed local bus operating at 8 MHz, with MEMC coordinating all memory access to prevent conflicts between the processor, video, and sound subsystems.
Memory Map
A310 Memory Organization
Address Range Size Function Access Speed
$0000000 – $01FFFFF 32 MB Logical RAM space 2-4 cycles
$0200000 – $02FFFFF 1 MB Physical RAM Fast page mode
$1F00000 – $1FFFFFF 1 MB I/O space 8 MHz
$2000000 – $2FFFFFF 16 MB Physical space DMA/Video
$3000000 – $33FFFFF 4 MB ROM space 2 cycles
$3400000 – $3FFFFFF 12 MB Expansion ROM Variable
MEMC implemented an unusual but efficient memory management scheme using a CAM (Content Addressable Memory) array providing hardware page translation without the complexity of a full MMU. This design supported 32 logical pages of 32 KB each, allowing sophisticated memory protection while maintaining single-cycle access for sequential addresses.
Hardware Design
The A310 motherboard measured 355mm × 245mm and employed a four-layer PCB design to minimize signal interference. The layout positioned the four custom chips in a square formation to minimize trace lengths, with the ARM2 and MEMC chips requiring precise timing relationships.
ARM2 Processor Details
The ARM2 processor contained approximately 25,000 transistors fabricated on a 3µm CMOS process. Despite its 32-bit architecture, the chip used only 68 pins and consumed less than 1 watt of power. The processor implemented 27 32-bit registers arranged in multiple banks for rapid context switching during interrupts.
Feature Specification Implementation
Pipeline 3-stage Fetch, decode, execute
Registers 27× 32-bit 16 visible, banked for modes
Addressing 26-bit 64 MB address space
Instructions Fixed 32-bit Conditional execution on all
Barrel shifter 32-bit Single-cycle shifts/rotates
Multiply 32×32→32 2-16 cycles depending on data
The three-stage pipeline allowed the ARM2 to fetch, decode, and execute instructions simultaneously. Conditional execution on all instructions eliminated many branch operations, improving pipeline efficiency. The barrel shifter permitted complex address calculations and bit manipulation in a single cycle, compensating for the limited instruction set.
Video System
VIDC provided exceptional graphics capabilities for 1987, supporting multiple resolutions and color depths through programmable video timing. The chip contained sophisticated palette handling and hardware cursor support, with all video data fetched via DMA without processor intervention.
Display Modes
Mode Resolution Colors Refresh Memory Bandwidth
0 640×256 2 50 Hz 20 KB 1 MB/s
9 640×256 16 50 Hz 80 KB 4 MB/s
10 640×256 256 50 Hz 160 KB 8 MB/s
12 640×512 16 50 Hz 160 KB 8 MB/s
13 640×512 256 50 Hz 320 KB 16 MB/s
15 640×512 16 50 Hz 160 KB 8 MB/s
20 640×512 16 70 Hz 160 KB 11.2 MB/s
21 640×512 256 70 Hz 320 KB 22.4 MB/s
23 1152×896 2 75 Hz 128 KB 9.6 MB/s
Video timing was fully programmable, allowing custom display modes beyond the standard configurations. The chip generated separate horizontal and vertical sync signals compatible with both standard and multisync monitors. Border color and display blanking were software-controlled, enabling overscan effects and smooth mode switching.
Sound System
The VIDC sound system represented a significant advancement over previous 8-bit computers. Eight independent DMA channels could each play different samples at varying rates and stereo positions.
Audio Specifications
Parameter Specification Notes
Channels 8 independent DMA-driven
Sample format 8-bit µ-law ~12-bit linear equivalent
Sample rates 3.125 - 48 kHz Per channel
Stereo positions 7 per channel Hardware panning
Buffer size 4 words/channel Interrupt on empty
Output Stereo 3.5mm jack Line level
Each channel supported seven stereo positions (left, center-left, center, center-right, right, and two intermediate positions), enabling sophisticated spatial effects. The logarithmic DAC encoding provided better perceived quality than linear 8-bit systems, approximating 12-bit linear resolution for typical audio material.
Input/Output Systems
The A310 provided comprehensive I/O capabilities through multiple interfaces. The IOC chip managed most standard peripherals while the motherboard included dedicated controllers for floppy drives and optional hard drives.
Port Specifications
Interface Controller Connector Speed Protocol
Serial 6551 ACIA 9-pin D-sub 19200 bps RS423
Parallel 8-bit latch 25-pin D-sub 50 KB/s Centronics
Floppy WD1772 34-pin IDC 31.25 KB/s ADFS format
SCSI Optional NCR5380 50-pin IDC 1 MB/s SCSI-1
Econet 68B54 ADLC 5-pin DIN 200 kbps Network
Mouse Quadrature 9-pin mini-DIN 100 Hz X/Y encoders
Keyboard 8051 MCU 6-pin mini-DIN Serial Custom protocol
The WD1772 floppy disk controller operated at 8 MHz, supporting both 250 kbps (double density) and 500 kbps (high density) data rates. The controller interfaced directly with the IOC chip for DMA transfers. The ADFS (Advanced Disc Filing System) implemented a proprietary format storing 800 KB on double-density disks through efficient sector allocation.
Expansion Bus
Four 96-pin DIN 41612 expansion slots provided access to the full processor bus. These "podule" slots supported sophisticated expansion capabilities:
  • Bus width: 8-bit or 16-bit data transfers
  • Addressing: 24-bit address space per slot
  • Speed: 2 MHz (slow) or 8 MHz (fast) operation
  • Power: +5V @ 200mA, ±12V @ 100mA per slot
  • Interrupts: IRQ and FIQ support
  • DMA: Direct memory access capability
Common expansion cards included SCSI interfaces, Ethernet adapters, video digitizers, MIDI interfaces, and ROM/RAM expansion boards. The podule specification allowed automatic configuration, with each card identifying itself to the operating system at startup.
Operating System Evolution
The A310 initially shipped with Arthur 0.30, a rudimentary operating system providing basic functionality while RISC OS was under development. Arthur included a simple command-line interface, BBC BASIC V interpreter, and essential filing system support.
Operating System Comparison
Feature Arthur 0.30/1.20 RISC OS 2.00
Desktop Single-tasking Cooperative multitasking
Memory management Static allocation Dynamic areas
Font system Bitmap only Outline fonts
File systems ADFS, DFS ADFS, DFS, NetFS, RamFS
Applications Command-line tools Paint, Draw, Edit included
Window manager Basic windowing Full WIMP environment
ROM size 512 KB 2 MB
RISC OS 2.00, released in April 1989, transformed the A310 into a sophisticated GUI-based system. The operating system resided in ROM, providing instant startup and immunity from disk corruption. The modular architecture allowed individual components to be updated or replaced without affecting system stability.
Memory and Performance
The A310 shipped with 1 MB of RAM as standard, organized as four 256K×9-bit SIMMs providing byte-wide error detection. Memory bandwidth limitations significantly affected system performance in high-resolution modes.
Performance Impact by Display Mode
Mode Resolution DMA Overhead CPU Performance
0 640×256×2 6% 94% of maximum
12 640×512×16 25% 75% of maximum
13 640×512×256 50% 50% of maximum
21 640×512×256 @ 70Hz 70% 30% of maximum
Memory expansion to 4 MB required replacing the standard modules with 1M×9-bit SIMMs. The system reserved the top 32 KB of physical memory for screen display, with additional allocations for sound buffers and system workspace. Contemporary benchmarks demonstrated the A310's superiority, with Dhrystone yields of 4100 iterations per second compared to 1800 for a 16 MHz 80286.
Power Supply
The A310 employed a linear power supply rated at 45 watts continuous output. The transformer-based design provided excellent regulation but generated substantial heat.
Power Specifications
Rail Voltage Current Usage
Primary +5V 6A Logic circuits
Drive +12V 1.5A Floppy/hard drives
Serial -5V 100mA RS423 levels
Auxiliary -12V 50mA Optional peripherals
The conservative design contributed to long-term reliability, though electrolytic capacitors eventually degrade, causing ripple and regulation problems that manifest as system instability or startup failures.
Manufacturing Variants
Acorn produced several PCB revisions addressing design issues and reducing costs:
Issue Production Period Changes Known Problems
1 Jun-Dec 1987 Original design Timing marginal, Arthur bugs
2 Jan-Sep 1988 PAL integration Podule compatibility
3 Oct 1988-1989 RISC OS ready Battery placement
4 1989 Cost reduced Some incompatibilities
Component substitutions occurred throughout production. Early machines used Motorola 68B51 serial chips, later replaced with Rockwell 65C51 variants. RAM manufacturers varied between Samsung, NEC, and Hitachi, with minor timing differences affecting marginal systems.
Known Issues
Several design decisions affected long-term reliability:
  • Battery leakage: 3.6V NiCd CMOS battery corrodes PCB traces after 10-15 years
  • Thermal stress: Linear PSU operates near limits, stressing capacitors
  • Keyboard controller: 8051 firmware corruption requires chip replacement
  • ROM bugs: Arthur versions exhibit memory corruption and crashes
  • Podule timing: Some expansion cards require Issue 2+ motherboards
Early ROM versions contained numerous bugs. Arthur 0.30 and 1.20 exhibited memory corruption under specific circumstances, random crashes during disk access, and compatibility problems with certain podule cards. RISC OS 2.00 resolved most issues but introduced new problems with some existing software.
Regular maintenance extends operational lifetime significantly. Critical tasks include CMOS battery replacement before leakage occurs, power supply capacitor inspection for bulging or leakage, and ventilation path cleaning to prevent thermal stress. The keyboard requires periodic cleaning to maintain reliable operation, while the floppy drive needs lubrication and alignment checks every 2-3 years.
Common failures follow predictable patterns. Power supply problems manifest as startup failures or random resets, usually traced to degraded capacitors in the main filter section. Video corruption indicates VIDC timing issues or RAM failures, diagnosed through systematic memory testing. Floppy drive errors result from alignment drift or WD1772 controller chip failure, requiring careful adjustment or component replacement.
After 35+ years, electrolytic capacitors require replacement. Critical components include:
  • PSU main filter: 4700µF 25V
  • PSU auxiliary: 1000µF 16V (×3), 470µF 25V (×2)
  • Motherboard: 100µF 16V (×6), 47µF 16V (×8), 10µF 25V (×4)
  • High-voltage: 100µF 200V (×2) in PSU primary
Technical Legacy
The A310 established ARM processors in the personal computer market, demonstrating RISC architecture advantages over complex instruction set competitors. While commercial success remained limited outside education markets, the technical innovations influenced subsequent computer designs. ARM processors, refined through successive generations, now dominate mobile computing, validating Acorn's architectural decisions from 1987.
