Acorn Archimedes A540
| Acorn Archimedes A540 | |
| Type | Personal Computer |
| Released | September 1990 |
| Discontinued | 1992 |
| Intro price | £2,995 (1990) |
| CPU | ARM3 @ 26 MHz |
| Memory | 4 MB RAM (expandable to 16 MB) |
| Storage | 3.5" floppy drive (1.6 MB), 100 MB SCSI hard drive |
| Display | 640×512 (16 colours), 800×600 (256 colours), 1152×896 (256 colours) |
| Sound | 8-channel stereo, 8-bit logarithmic DAC |
| Dimensions | 415 mm × 355 mm × 104 mm |
| Weight | 10 kg |
| OS / Firmware | RISC OS 2.01 |
| Predecessor | Acorn Archimedes A440 |
| Successor | Acorn A5000 |
The Acorn Archimedes A540 was introduced in September 1990 as the flagship model of the second-generation Archimedes range. First Archimedes to feature the ARM3 processor as standard, the A540 delivered unprecedented performance for the platform while introducing SCSI storage and enhanced memory capabilities that positioned it as a serious Unix workstation.
Overview
The A540 represented Acorn's response to criticism that the original Archimedes lacked the performance for professional workstation applications. The ARM3 processor, running at 26 MHz with 4 KB of cache memory, provided approximately four times the processing power of the ARM2-based models. Combined with a 100 MB SCSI hard drive and support for up to 16 MB of RAM, the A540 competed directly with entry-level Sun and HP workstations at a fraction of the cost.
Acorn positioned the A540 primarily at the Unix workstation market, bundling RISC iX with many systems. The machine also attracted high-end educational users, CAD operators, and desktop publishing professionals who required maximum performance from the RISC OS platform. At £2,995, the A540 cost significantly more than the A440 it replaced, but delivered specifications that justified the premium for demanding applications.
Architecture
The A540 introduced significant architectural improvements over first-generation machines. The ARM3 processor maintained instruction set compatibility with ARM2 while adding cache memory and higher clock speeds. The MEMC1a memory controller supported larger memory configurations through bank switching, while the enhanced VIDC20 video controller provided improved color depth and resolution support.
ARM3 Processor
| Feature | ARM2 (A440) | ARM3 (A540) | Improvement |
| Clock speed | 8 MHz | 26 MHz | 3.25× |
| Cache | None | 4 KB unified | N/A |
| Process | 3µm | 1.5µm | 50% reduction |
| Transistors | 25,000 | 300,000 | 12× |
| Power | 1W | 1.5W | 50% increase |
| IPC | 0.5 | 0.9 with cache | 80% improvement |
The 4 KB cache proved crucial for performance, reducing memory bandwidth requirements by approximately 75% for typical code. Cache operation was fully transparent to software, with hardware maintaining coherency for DMA operations. The write-through design simplified implementation while providing substantial performance benefits.
Memory System
The A540 supported dramatically expanded memory configurations:
| Configuration | SIMM Type | Banks | Total RAM | Notes |
| Standard | 4× 1M×9 | 1 bank | 4 MB | Single MEMC1a |
| Expanded | 4× 1M×9 | 4 banks | 16 MB | Requires MEMC podule |
| Maximum (unofficial) | 4× 4M×9 | 4 banks | 64 MB | Third-party modification |
The standard MEMC1a controller addressed 4 MB directly. Larger configurations required the MEMC podule, which implemented bank switching to access additional memory. While RISC OS could only directly use 4 MB for applications, the additional memory served as RAM disc or cache for Unix operations.
Hardware Specifications
The A540 motherboard represented a significant revision from earlier models, optimized for the ARM3 processor and enhanced peripherals.
Motherboard Design
Key improvements included:
- Six-layer PCB: Improved signal integrity and EMI reduction
- Surface-mount technology: Reduced size and improved reliability
- Enhanced power distribution: Separate planes for digital and analog supplies
- Improved grounding: Star ground configuration reduced noise
- Modular connectors: Simplified assembly and service
The ARM3 processor mounted in a 160-pin QFP socket, allowing field replacement if necessary. The cache RAM utilized fast 15ns static RAM chips, essential for single-cycle operation at 26 MHz.
SCSI Subsystem
| Component | Specification | Performance |
| Controller | NCR 53C90A | Asynchronous SCSI-1 |
| Interface | 50-pin IDC | Internal and external |
| Transfer rate | 5 MB/s maximum | 2.5 MB/s typical |
| Devices | 7 maximum | 2 internal, 5 external |
| Termination | Active | Automatic detection |
The integrated SCSI controller eliminated the podule slot requirement of earlier models, freeing expansion capacity for other uses. The NCR chip provided hardware command queuing and disconnect/reconnect capability, improving multi-device performance.
Standard Drive Configuration
The A540 shipped with various drive options:
| Model | Drive Type | Capacity | Access Time | Cache |
| A540 base | Conner CP30100 | 100 MB | 19ms | None |
| A540/120 | Quantum ProDrive | 120 MB | 17ms | 64 KB |
| A540/200 | Maxtor 7213 | 200 MB | 15ms | 64 KB |
All drives utilized embedded SCSI controllers, eliminating the reliability issues associated with ST506 interfaces. The faster seek times and command queuing capability provided substantial performance improvements for multi-tasking operations.
Video System
The A540 incorporated the enhanced VIDC20 video controller, though early units used VIDC1a:
VIDC20 Capabilities
| Feature | VIDC1a | VIDC20 | Benefit |
| Color depth | 8-bit | 8/16/32-bit | True color support |
| Palette | 4096 colors | 16.7 million | Photographic quality |
| Maximum resolution | 1152×896 | 1280×1024 | Industry standard |
| Pixel clock | 24 MHz | 36 MHz | Higher refresh rates |
| Hardware cursor | 32×32 | 32×32×3 | Colored pointers |
The VIDC20 required 2 MB of VRAM for high-color modes, installed separately from main memory. This dedicated video memory eliminated the bandwidth contention that plagued earlier models in high-resolution modes.
Display Modes
| Mode | Resolution | Colors | Refresh | VRAM Required |
| 21 | 640×512 | 256 | 75 Hz | 320 KB |
| 24 | 800×600 | 256 | 60 Hz | 480 KB |
| 28 | 1024×768 | 256 | 70 Hz | 768 KB |
| 31 | 1280×1024 | 16 | 60 Hz | 640 KB |
| X | 640×480 | 32768 | 60 Hz | 600 KB |
The expanded mode selection supported industry-standard resolutions, improving monitor compatibility and enabling professional graphics applications previously impossible on the platform.
Expansion Capabilities
The A540 provided four podule slots, all available for expansion due to the integrated SCSI controller:
Professional Expansion Cards
Common podule configurations included:
- Ethernet cards: i-cubed EtherLan 500/600 for TCP/IP networking
- Graphics accelerators: Colour Card Gold for 24-bit color
- Video digitizers: Eagle M2 for multimedia applications
- DSP cards: Lark A16 for audio processing
- PC cards: Aleph One 486 emulator
- MIDI interfaces: EMR Studio 24 Plus
The four-slot capacity allowed sophisticated system configurations impossible on earlier models with SCSI podules consuming expansion space.
Memory Expansion
The MEMC podule provided access to additional memory banks:
| Podule Type | Additional RAM | Total System RAM | Primary Use |
| Atomwide MEMC | 12 MB | 16 MB | RISC iX |
| Simtec MEMC | 28 MB | 32 MB | Large RAM disc |
| IFEL MEMC | 60 MB | 64 MB | Specialized applications |
RISC OS applications could only directly access 4 MB, but the additional memory served as ultra-fast storage or workspace for Unix operations.
Operating System Support
The A540 shipped with RISC OS 2.01, addressing bugs in the 2.00 release:
RISC OS 2.01 Improvements
- ARM3 support: Cache control and configuration
- SCSI manager::** Native SCSI device handling
- Memory management::** Support for >4 MB configurations
- Bug fixes::** Printer driver stability, font manager leaks
- Performance::** Optimized for ARM3 cache
The ROM-based operating system provided instant startup and immunity from corruption, crucial for reliability in professional environments.
RISC iX Capabilities
Many A540s ran Acorn's RISC iX Unix variant:
| Specification | Requirement | A540 Capability |
| Minimum RAM | 8 MB | 16 MB typical |
| Swap space | 32 MB | 100 MB available |
| X Windows | 4 MB RAM | Comfortable operation |
| Concurrent users | 2-4 | Via serial terminals |
| Compilation speed | N/A | 4× faster than A440 |
RISC iX on the A540 provided genuine workstation capabilities, supporting software development, scientific computing, and multi-user operation competitive with contemporary Sun SPARCstation 1+ systems.
Performance Analysis
The A540 delivered exceptional performance for its era:
Benchmark Comparisons (1990)
| System | Processor | Dhrystone 2.1 | SPECint89 | Price |
| Archimedes A540 | ARM3 26 MHz | 21,000 | 13.9 | £2,995 |
| Sun SPARCstation 1+ | SPARC 25 MHz | 22,000 | 15.8 | £5,995 |
| HP 9000/425 | 68040 25 MHz | 20,000 | 14.2 | £8,500 |
| IBM RS/6000 320 | POWER 20 MHz | 24,000 | 17.3 | £12,000 |
| A440 (for comparison) | ARM2 8 MHz | 4,100 | 3.2 | £2,499 |
The A540 matched workstations costing twice as much while dramatically outperforming its predecessor. Cache efficiency and the optimized RISC instruction set compensated for the relatively modest clock speed.
Software Optimization
Software developers quickly adapted to the A540's capabilities:
Development Tools
Professional development environments included:
- Acorn Desktop C: Optimized for ARM3 code generation
- Norcroft C++: Object-oriented development
- Desktop Assembler::** Integrated ARM assembly
- GCC::** GNU compiler collection port
- CrossWorks::** Cross-platform development
The ARM3's cache benefited compiled code substantially, with typical applications running 3-5 times faster than ARM2 versions without recompilation.
Professional Applications
High-end software leveraged the A540's power:
- Impression Publisher Professional::** Desktop publishing with color separation
- ProArtisan 24::** 24-bit image processing
- Sibelius 7::** Professional music notation
- Clares Render Bender::** 3D ray tracing
- Schema 2::** Electronic PCB design
These applications required the A540's performance and memory capacity for practical operation, driving system sales in professional markets.
Manufacturing and Variants
The A540 underwent several revisions during production:
| Period | Revision | Changes | Notes |
| Sep 1990-Mar 1991 | Issue 1 | VIDC1a, NCR 53C90 | Initial release |
| Apr-Oct 1991 | Issue 2 | VIDC20 standard | Enhanced video |
| Nov 1991-May 1992 | Issue 3 | NCR 53C90A | Improved SCSI |
| Jun-Sep 1992 | Issue 4 | Cost reduction | Final production |
Total production remained under 8,000 units, reflecting the limited market for high-end ARM workstations. Universities and research institutions purchased approximately 45% of production, with commercial users accounting for 30% and advanced educational institutions the remainder.
Common Issues and Reliability
The A540's complexity created specific maintenance requirements:
Component Reliability
| Component | MTBF | Common Failure Mode | Resolution |
| ARM3 processor | >100,000 hours | Cache RAM failure | Replace cache chips |
| SCSI controller | >50,000 hours | Termination issues | Check terminator power |
| Power supply | 30,000 hours | Capacitor degradation | Recap required |
| SCSI drive | 40,000 hours | Bearing wear | Replace drive |
| VIDC20 | >100,000 hours | Thermal stress | Improve cooling |
The ARM3 processor proved remarkably reliable, with most failures traced to the external cache RAM rather than the processor itself. The switch-mode power supply, while more efficient than earlier linear designs, required periodic capacitor replacement.
Thermal Management
Heat dissipation remained challenging:
- ARM3 dissipation::** 1.5W requiring heatsink
- System total::** 65W typical operation
- Internal temperature::** 40-45°C with proper ventilation
- Critical components::** Power supply, hard drive, ARM3
Many users added supplementary cooling fans, particularly for systems running continuously as Unix servers. The standard rear exhaust fan proved marginal for fully-loaded systems.
Upgrade Paths
Limited upgrade options existed for the A540:
Processor Enhancements
- Clock speed increase::** 30-33 MHz possible with cooling
- Cache expansion::** 8 KB or 16 KB third-party upgrades
- FPA11 coprocessor::** Hardware floating-point
- ARM3 variants::** 36 MHz parts in later production
Clock speed increases required careful attention to cache RAM timing and system cooling. The performance gain rarely justified the reliability risks.
Storage Upgrades
SCSI standardization simplified storage expansion:
- Internal drives::** Up to 2 GB with driver updates
- External arrays::** Multiple drives for capacity
- Removable media::** ZIP, JAZ, magneto-optical
- Tape backup::** DAT or Exabyte drives
The SCSI interface's longevity meant modern solutions like SCSI2SD adapters could replace mechanical drives, essential for current operation given hard drive failures.
Unix Workstation Role
The A540 achieved recognition as a legitimate Unix workstation:
RISC iX Performance
| Operation | A440 RISC iX | A540 RISC iX | Improvement |
| Kernel compile | 45 minutes | 11 minutes | 4.1× |
| X Windows startup | 35 seconds | 8 seconds | 4.4× |
| Database query | 12 seconds | 3 seconds | 4.0× |
| LaTeX document | 8 seconds | 2 seconds | 4.0× |
The ARM3 cache particularly benefited Unix operations, reducing memory bandwidth demands for kernel operations and improving multi-user response times.
Research Applications
Universities utilized A540 systems for:
- Compiler research::** ARM provided ideal RISC target
- Parallel processing::** Clusters of A540s via Ethernet
- Graphics research::** VIDC20 programmability
- Real-time systems::** Predictable interrupt latency
- Network protocols::** TCP/IP stack development
The open architecture and comprehensive documentation enabled research impossible on proprietary workstations.
Market Position
The A540 faced challenging market dynamics:
Competitive Landscape (1990-1992)
Advantages:
- Exceptional price/performance ratio
- Native RISC architecture
- Integrated development environment
- Educational market presence
- Low power consumption
Disadvantages:
- Limited software availability
- Weak third-party support
- No industry-standard bus
- Limited marketing resources
- Proprietary architecture
The emergence of 486-based PCs and affordable SPARC workstations eroded the A540's competitive position. By 1992, standard workstations offered comparable performance with vastly superior software ecosystems.
Service and Support
Acorn provided comprehensive support for the A540:
- Technical Reference Manual::** Complete hardware documentation
- Programmer's Reference::** Software interfaces
- RISC iX Administration::** Unix system management
- Service Manual::** Diagnostic and repair procedures
The documentation quality exceeded industry standards, enabling third-party development and simplifying maintenance.
Diagnostic Tools
- POST ROM::** Power-on self-test routines
- RISC OS utilities::** Memory and disk verification
- RISC iX diagnostics::** Comprehensive hardware testing
- Third-party tools::** ZIDEFS, Killer, System Devices
These tools enabled field diagnosis without specialized equipment, crucial for educational institutions with limited technical resources.
Critical maintenance focuses on thermal management and power supply health. The ARM3 processor heatsink requires periodic cleaning and thermal compound replacement. SCSI termination needs verification when adding or removing devices. Power supply capacitors show age-related degradation requiring inspection and replacement after 25-30 years. The VIDC20 runs hot, benefiting from additional heatsinking. Battery replacement every 5 years prevents configuration loss and potential corrosion damage.
Common fault patterns include cache-related crashes indicating failing cache RAM, SCSI timeout errors from termination problems or cable issues, and power supply instability under load. Video corruption at high resolutions suggests VRAM timing problems. System instability often traces to thermal issues, resolved through improved cooling. The diagnostic process should verify power supply voltages, test cache operation, check SCSI chain integrity, and validate memory configuration.
The switch-mode power supply contains critical capacitors: primary side (100µF 400V, 47µF 400V), secondary filtering (2200µF 16V ×2, 1000µF 25V ×2, 470µF 35V ×3), and regulation circuits (100µF 25V ×8). Motherboard capacitors include processor decoupling (100µF 16V ×4), VIDC20 supply (220µF 16V ×2), and general distribution (47µF 16V ×12). SCSI termination uses precision capacitors requiring exact replacement values.
End of Production
Acorn discontinued the A540 in September 1992, replacing it with the A5000. Factors contributing to discontinuation included:
- Limited market acceptance outside education
- Competition from affordable Unix workstations
- Development costs for next-generation architecture
- Strategic focus on education market
Remaining inventory sold slowly, with some units available into 1993. The A5000 offered similar performance at lower cost but lacked the A540's expansion capacity and Unix focus.
Legacy
The A540 represented the pinnacle of the original Archimedes architecture, demonstrating ARM's potential for workstation applications. While commercial success remained elusive, the technical achievement was substantial. The system proved that British companies could compete with established American and Japanese manufacturers in sophisticated computer design.
The A540's influence extended through software development, with applications optimized for ARM3 cache architectures. These optimization techniques proved valuable for subsequent ARM developments, contributing to the architecture's eventual mobile dominance.
Modern collectors value A540 systems as the ultimate expression of Acorn's engineering capabilities. However, restoration challenges include failing power supplies, degraded capacitors, and increasingly scarce SCSI drives. The relative complexity compared to other Archimedes models makes maintenance demanding but rewarding for dedicated enthusiasts.
