Macintosh TV Capacitor Replacement Guide
Revision as of 11:31, 10 February 2026 by Josh (talk | contribs) (Added recap guide images from Recap-a-Mac)
Replacing electrolytic capacitors (recapping) in your Macintosh TV is essential for long-term reliability. The surface-mount capacitors on the logic board and TV tuner board are particularly prone to leakage, which can cause corrosion and permanent damage to PCB traces if not addressed.
Macintosh TV Capacitor Overview
Capacitor Inspection
Before beginning replacement, inspect all boards for signs of capacitor failure:
  • Bulging Tops - Electrolytic capacitors have a scored vent on top; bulging indicates internal pressure from failure
  • Leaking Electrolyte - Brown, black, or clear fluid around capacitor base indicates active leakage
  • Corrosion or PCB Staining - Discoloration of the PCB near capacitors suggests electrolyte damage
  • Crystalline Deposits - White or tan crystalline material indicates dried electrolyte
The Macintosh TV contains capacitors on three boards:
  1. Logic Board (5 capacitors)
  2. TV Tuner Board (12 capacitors)
  3. Analog Board (various through-hole capacitors)
Macintosh TV Capacitor Lists
Logic Board Capacitors
Macintosh TV Logic Board
Logic Board Capacitor Specifications[1]
Capacitance Voltage Quantity Type Notes
100uF 25V 1x SMD Aluminum Electrolytic Main filter capacitor
47uF 16V 2x SMD Aluminum Electrolytic
10uF 16V 2x SMD Aluminum Electrolytic
The logic board is similar to the Macintosh LC 550 but with modifications for the TV tuner interface.
TV Tuner Board Capacitors
Macintosh TV Tuner Board Capacitor Guide
TV Tuner Board Capacitor Specifications[2]
47uF 6.3V 1x SMD Aluminum Electrolytic Non-standard value
4.7uF 35V 4x SMD Aluminum Electrolytic
4.7uF 25V 4x SMD Aluminum Electrolytic
1uF 50V 1x SMD Aluminum Electrolytic
0.47uF 50V 2x SMD Aluminum Electrolytic Non-standard value
Note: The TV tuner board uses non-standard capacitor values (particularly 6.3V and 0.47uF) that are uncommon in other Macintosh boards. These may require special ordering.[3]
Analog Board Capacitors
The LC 500 series analog board contains numerous through-hole electrolytic capacitors. Complete specifications are not fully documented, but key capacitors include:
Analog Board Key Capacitors (Partial List)
Location Capacitance Voltage Type Notes
Main filter 1000uF-3300uF 16V-25V Radial electrolytic Low ESR recommended
Secondary filter 220uF-470uF 25V-35V Radial electrolytic
Deflection circuit 47uF-100uF 100V-160V Radial electrolytic High voltage rating critical
B+ filter 100uF-220uF 200V-250V Radial electrolytic Safety rated
The analog board may not require immediate recapping unless symptoms are present. Focus on the logic board and TV tuner board first.
  1. Discharge the CRT - Follow the CRT Discharge Procedure before opening the case. The CRT and analog board contain lethal voltages.
  1. Remove the rear case - Use a long Torx T-15 screwdriver to remove the rear housing screws.
  1. Disconnect cables - Carefully disconnect the video cable, speaker cables, power connector, and any other cables to the logic board.
  1. Remove the logic board - The logic board slides out after removing mounting screws. Note the orientation of all connectors.
  1. Remove the TV tuner board - The tuner board connects to the logic board via an edge connector. Carefully release it.
  1. Desolder old capacitors - Use a temperature-controlled soldering iron (350C-380C) and desoldering braid or pump. For SMD capacitors, heat both pads alternately while gently lifting the capacitor.
  1. Clean the pads - Remove old solder and any electrolyte residue with isopropyl alcohol (90%+) and a soft brush. Inspect traces for damage.
  1. Install new capacitors - Observe correct polarity. The negative side is typically marked with a stripe on the capacitor. Match the silkscreen markings on the PCB.
  1. Solder securely - Use quality leaded solder (60/40 or 63/37) and ensure good solder joints.
  1. Trim leads and inspect - For through-hole capacitors, trim leads flush. Inspect all joints under magnification.
  1. Clean the board - Remove flux residue with isopropyl alcohol.
  1. Test for shorts - Use a multimeter to check for shorts between power rails before reassembly.
  • Temperature-controlled soldering iron (Hakko, Weller, or equivalent)
  • Fine soldering tip (chisel or conical, 1-2mm)
  • Desoldering braid (2-3mm width)
  • Desoldering pump/solder sucker
  • Fine leaded solder (0.5-0.8mm diameter)
  • Isopropyl alcohol (90% or higher)
  • ESD-safe brush
  • Multimeter
  • Magnifying glass or loupe
  • Safety glasses
  • ESD wrist strap
For SMD aluminum electrolytics, quality brands include:
  • Nichicon
  • Panasonic (FR, FC, or FM series)
  • Rubycon
  • United Chemi-Con (KZE, KY series)
Avoid generic or low-quality capacitors. Match or exceed the original voltage rating. Slightly higher capacitance values (within 20%) are acceptable.
Voltage Adjustment After Recap
After recapping, verify power supply voltages:
  • +5V rail: 4.85V - 5.15V
  • +12V rail: 11.9V - 12.7V
Adjust potentiometers on the analog board if necessary. Allow the system to warm up for 15-30 minutes before final adjustment.
Additional Tips
  • Work in a well-lit, static-free environment - Use an ESD mat and wrist strap
  • Document before disassembly - Take photos of cable routing and connector positions
  • Label capacitors - Note polarity and position before removal
  • Test incrementally - Power on and test after completing each board before full reassembly
  • Keep the old capacitors - Useful for reference if issues arise
  • Practice first - If unfamiliar with SMD work, practice on a scrap board
Sourcing Capacitors
Reliable sources for quality capacitors:
  • Mouser Electronics
  • Digi-Key
  • RS Components
  • Console5 (pre-made kits for some Macintosh models)
For the TV tuner board's non-standard values, you may need to search specialty electronics suppliers or accept nearest-value substitutes where appropriate.
  1. Mac TV Cap Reference, MacDat—link(accessed 2026-02-10)
  2. Mac TV Cap Reference, MacDat—link(accessed 2026-02-10)
  3. Macintosh TV, Recap-a-Mac—link(accessed 2026-02-10)
