Troubleshooting the Macintosh Quadra 840AV requires understanding its unique architecture, including the AV-specific features like the DSP chip and video I/O circuitry. This guide covers common problems and their solutions.
Preliminary Checks
Verify the power cable is securely connected
Check that the power outlet is working
Ensure all internal cables are properly seated
Remove any recently added hardware (NuBus cards, RAM, etc.)
Disconnect external SCSI devices
Power Supply Voltage Check
Expected Voltages
Rail
Target
Acceptable Range
+5V
5.0V
4.85V โ 5.15V
+12V
12.0V
11.9V โ 12.7V
-12V
-12.0V
-11.5V โ -12.7V
No Power
No Power Diagnostics
Symptom
Possible Cause
Recommended Action
Completely dead, no fan
Power supply failure
Test PSU voltages; recap or replace PSU
Blown fuse in PSU
Check and replace internal PSU fuse
Failed power switch
Test continuity of front panel power switch
Clicking/ticking sound
PSU overload protection
Disconnect drives; check for shorts on logic board
Fan spins briefly then stops
PSU failure or short
Check for shorts; test PSU under load
Intermittent power
Loose power connector
Reseat power supply connector to logic board
Startup Chime But No Video
No Video Diagnostics
Symptom
Possible Cause
Recommended Action
Chime, no video
Bad VRAM
Remove optional VRAM SIMMs; test with onboard VRAM only
Chime, no video
Failed monitor
Test with known-good monitor
Chime, no video
Bad video cable
Inspect and replace video cable
Chime, no video
Logic board failure
Check for capacitor leakage; inspect video circuitry
Chime, garbled video
VRAM failure
Reseat or replace VRAM SIMMs
Chime, rolling picture
Monitor sync issue
Try different resolution in PRAM or with different monitor
Video Artifacts
Common causes of display artifacts:
Failing VRAM (soldered or in SIMMs)
Cold solder joints on video circuitry
Capacitor leakage affecting video section
Overheating
No Startup Chime
No Chime Diagnostics
Symptom
Possible Cause
Recommended Action
No chime, fan runs
Bad RAM
Test RAM SIMMs individually; try known-good RAM
No chime, fan runs
Bad ROM
Rare; logic board replacement likely needed
No chime, fan runs
Logic board failure
Check for capacitor leakage; inspect for damage
No chime, fan runs
CPU failure
Very rare; requires logic board repair
Death chimes (pattern)
RAM failure
Replace RAM; try different SIMM slots
Sad Mac Error Codes
The Quadra 840AV displays a Sad Mac icon with a hexadecimal error code when hardware failures are detected during startup.
