Macintosh Quadra 700 Capacitor Replacement Guide
Revision as of 11:41, 10 February 2026 by Josh (talk | contribs) (Created capacitor replacement guide for Macintosh Quadra 700 (noting tantalum caps))
Understanding the capacitor situation in your Macintosh Quadra 700 is essential for proper maintenance and repair.
Important Note: Tantalum Capacitors
The Macintosh Quadra 700 is unique among Macintosh computers of its era in that the logic board uses tantalum capacitors rather than electrolytic capacitors.[1]
This is significant because:
  • Tantalum capacitors do not leak electrolyte like electrolytics
  • The logic board is far less susceptible to the corrosion damage seen on other vintage Macs
  • Preventive recapping of the logic board is generally not necessary
However, tantalum capacitors have their own failure mode: they can fail short-circuit, potentially causing damage to other components. This is typically caused by voltage spikes or reverse polarity conditions.
Power Supply Capacitors
The power supply unit (PSU) does contain electrolytic capacitors that may require replacement over time. Signs of capacitor failure in the PSU include:
  • No power or intermittent power
  • Unstable voltage output
  • Visible bulging or leaking capacitors
  • Burning smell
Power Supply Capacitor Inspection
Warning: The power supply contains high-voltage components. Disconnect from mains power and allow capacitors to discharge before working inside.
  • Bulging Tops — Indicates internal pressure from failing electrolyte
  • Leaking Electrolyte — Brown or rust-colored residue around capacitor base
  • Corrosion — Green or white deposits on PCB near capacitors
Capacitor Replacement Procedure (Power Supply)
If power supply capacitors require replacement:
  1. Disconnect from mains power and wait at least 30 minutes
  2. Discharge high-voltage capacitors using a discharge tool or resistor
  3. Document capacitor locations and values before removal
  4. Desolder old capacitors using desoldering pump or wick
  5. Install replacements observing correct polarity
  6. Solder securely with adequate flow on both leads
  7. Inspect for shorts with multimeter before powering on
Use capacitors rated for 105°C operation and at least the same voltage rating as originals.
Logic Board: When Replacement May Be Needed
While the Quadra 700 logic board does not typically need recapping, tantalum capacitors should be replaced if:
  • Visible damage — Cracks, burn marks, or discoloration
  • Short circuit — Tantalum failures often present as shorts
  • Known overvoltage event — After power surge or incorrect power supply
Tantalum Capacitor Identification
Tantalum capacitors on the Quadra 700 logic board are typically:
  • Small, rectangular, surface-mount packages
  • Yellow, orange, or tan colored
  • Marked with polarity (+ stripe on positive end)
Tantalum Capacitor Replacement
If tantalum replacement is necessary:
  1. Use a temperature-controlled soldering station (recommend 300-350°C)
  2. Apply flux to both ends of the capacitor
  3. Heat one end while gently lifting with tweezers
  4. Alternate ends until capacitor is free
  5. Clean pads with solder wick
  6. Apply fresh solder to pads
  7. Place new capacitor observing correct polarity
  8. Solder each end with brief contact
Important: Tantalum capacitors are polarity-sensitive. Reverse polarity will cause immediate and potentially destructive failure.
  • Temperature-controlled soldering iron (for SMD work)
  • Fine solder tip (chisel or conical, 1-2mm)
  • Desoldering pump or wick
  • Fine leaded solder (0.5 mm diameter)
  • Flux (no-clean type recommended)
  • Isopropyl alcohol (99%) for cleaning
  • ESD brush
  • Multimeter
  • Capacitor discharge resistor (for PSU work)
  • Safety glasses and heat-resistant gloves
Voltage Verification After Service
After any capacitor work, verify voltage rails before reconnecting peripherals:
Rail Ideal Range
+5V 4.85V – 5.15V
+12V 11.9V – 12.7V
-12V -11.9V – -12.7V
Additional Notes
  • The Quadra 700's use of tantalum capacitors makes it one of the more reliable vintage Macs
  • Many Quadra 700 units remain operational 30+ years later without recap
  • Focus maintenance efforts on the power supply and PRAM battery instead
  • When troubleshooting, do not assume capacitor failure — the logic board is likely still healthy
  1. Working from home at 25MHz: You could do worse than a Quadra 700, Ars Technica, December 11, 2020—link(accessed 2026-02-10)
