Template:Cmbox/doc
Revision as of 14:30, 26 March 2026 by Josh (talk | contribs) (Created page with "{{Documentation subpage}} <!-- Categories go where indicated at the bottom of this page, please; interwikis go to Wikidata (see also: Wikipedia:Wikidata). --> {{Cascade-protected template}} {{high-use}} {{Lua|Module:Message box}} {{Mbox templates (small)}} This is the {{tl|Cmbox}} (['''C''']ategory ['''m''']essage ['''box''']) metatemplate. It is used to build message box templates such as {{tl|Category diffuse}} for category pages. It offers several dif...")
Message box
meta-templates
templatecontext
{{Ambox}}article
{{Cmbox}}category
{{Imbox}}image
{{Tmbox}}talk
{{Fmbox}}footer / header
{{Ombox}}other pages
{{Mbox}}auto-detect
{{Asbox}}article stub
{{Dmbox}}disambiguation
This is the {{Cmbox}} ([C]ategory [m]essage [box]) metatemplate.
It is used to build message box templates such as {{Category diffuse}} for category pages. It offers several different colours, uses default images if no image parameter is given, and it has some other features.
This template works almost exactly like {{Ambox}} and uses the same parameters.
Usage
Simple usage example:
{{cmbox | text = Some text.}}
Complex example:
{{cmbox
| type      = style
| image     = [[File:Emblem-question-yellow.svg|40px]]
| style     = width: 400px;
| textstyle = color: red; font-weight: bold; font-style: italic;
| text      = The message body text.
Category message box types
The following examples use different type parameters but use no image parameters, thus they use the default images for each type.
Other images
The default images shown above are mostly for convenience. In many cases it is more appropriate to use more specific images. These examples use the image parameter to specify an image other than the default images.
Special
Some other parameter combinations.
Parameters
List of all parameters:
{{cmbox
| name = name of the template
| type  = speedy / delete / content / style / notice / move / protection
| image = none / [[File:Some image.svg|40px]]
| imageright = [[File:Some image.svg|40px]]
| class = A custom CSS class to apply to the box
| style = CSS values
| textstyle = CSS values
| plainlinks  = no
name
(Optional) Name of the template. This adds a CSS class with name box-name to the HTML element, for use by bots or scripts.
type
If no type parameter is given, the template defaults to type notice. That means it gets a blue background.
No parameter = If no image parameter is given, the template uses a default image. Which default image it uses depends on the type parameter.
An image = Should be an image with usual wiki notation. 40px - 50px width is usually about right depending on the image height-to-width ratio (but the message box can handle images of any size).
For example: image = [[File:Sub-arrows.svg|40px]]
none = Means that no image is used.
imageright
No parameter = If no imageright parameter is given, no image is shown on the right side.
For example: imageright = [[File:Nuvola apps bookcase.png|40px]]
Anything = Any other object that you want to show on the right side.
style
An optional CSS value used by the entire message box table. Without quotation marks " ".
For example: style = margin-bottom: 0.5em;
textstyle
An optional CSS value used by the text cell.
For example: textstyle = text-align: center;
plainlinks
Normally on Wikipedia, external links have an arrow icon next to them, like this: Example.com. However, in message boxes, the arrow icon is suppressed by default, like this: Example.com. To get the normal style of external link with the arrow icon, use |plainlinks=no.
text
Technical details
If you need to use special characters in the text parameter then you need to escape them like this:
{{cmbox
| text  = <div>
Equal sign = and a start and end brace { } work fine as they are.
But here is a pipe {{!}} and two end braces <nowiki>}}</nowiki>.
And now a pipe and end braces <nowiki>|}}</nowiki>.
</div>
This template uses the cmbox CSS classes in MediaWiki:Common.css for most of its looks, thus it is fully skinnable.
Internally this meta-template uses HTML markup instead of wiki markup for the table code. That is the usual way we make meta-templates since wiki markup has several drawbacks. For instance it makes it harder to use parser functions and special characters in parameters.
The default images for this meta-template are in PNG format instead of SVG format. The main reason is that some older web browsers have trouble with the transparent background that MediaWiki renders for SVG images. The PNG images here have hand-optimised transparent background colour so they look good in all browsers. Note that SVG icons only look somewhat bad in the old browsers, thus such hand optimisation is only worth the trouble for very widely used icons.
For more technical details see the talk page. Since this template works almost exactly like the other mboxes, their talk pages and related pages might also contain more details (see the See also section below).
There are seven metatemplates in the Module:Message box family:
  • {{Ambox}}, for messageboxes on article pages.
  • {{Cmbox}}, for messageboxes on category pages.
  • {{Imbox}}, for messageboxes on file (image) pages.
  • {{Tmbox}}, for messageboxes on talk pages.
  • {{Fmbox}}, for header and footer messageboxes.
  • {{Ombox}}, for messageboxes on other types of page.
  • {{Mbox}}, for messageboxes that are used in different namespaces and change their presentation accordingly.
Closely related metatemplates:
  • {{Article stub box}}, for messageboxes in article stubs.
  • {{Dmbox}}, for messageboxes on disambiguation or set-index pages.
  • Template:Tla, a simple full-width box with default ivory background intended to frame important messages or notices.
  • {{Hmbox}}
