Commodore 64 Power-Supply Protector (C64 Saver)
Caption A popular open-hardware implementation of the C64 Saver
Type External over-voltage / over-current protection adapter
Designer Ray Carlsen (original design)
community derivatives (OpenC64Saver, SaV64, SaRuMan-64, C64 Saver 2, etc.)
Manufacturer Unknown
First released 2016 (public release of the Carlsen “C64 Saver 1.2” design)
Latest revision C64 Saver 2.4 PCB (2022)
Operating voltage +5 V DC (monitored) • 9 VAC passthrough
Layers / PCB
Compatibility Commodore 64 / 64C / SX-64 / VIC-20 CR and any CBM 8-bit that uses the 7-pin DIN power connector
Features
Model No.
The Commodore 64 Power-Supply Protector—best-known by Ray Carlsen’s original name “C64 Saver”—is a small plug-through safety adapter that sits between a vintage Commodore power brick and the computer.
Its only mission is to sacrifice itself if the +5 V rail from the ageing “epoxy-potted” supply drifts above a safe level, instantly disconnecting the load and saving irreplaceable MOS chips such as the VIC-II, SID, CIA and RAM.
Why a Protector Is Needed
Original Commodore “brick” PSUs were cost-reduced, epoxy-potted switchers with no serviceable parts or active regulation feedback. With age the internal linear regulator or crowbar diode can short, driving the +5 V DC rail to 7–12 V—high enough to destroy ICs within seconds. Modern collectors therefore avoid the stock PSU unless a C64 Saver-class device is in-line.
Operating Principle
Function block Component example Description
Over-voltage sense TL431 programmable shunt (earlier boards use 5 V zener) Monitors the 5 V rail; trips at 5.3–5.5 V (adjustable ± 50 mV).
Crowbar / latch SCR (e.g. C106D) or P-channel MOSFET + relay When tripped, shorts the rail through the SCR or mechanically opens the circuit; resets only when input power is removed.
Fuse element Resettable polyfuse 1.1 A or fast-blow 1 A Limits fault current so the PSU shuts down instead of the computer.
Visual alert Bi-colour LED Green = normal; Red = tripped/over-voltage.
Passthrough lines 9 VAC pair, Sense line These are not switched—protector covers only +5 V DC.
  • OpenC64Saver* introduces reverse-polarity protection, replaces the SCR with a low-RDS(on) MOSFET for cooler running, and adds a precision trim-pot for exact trip voltage set-up.
Design Evolution
Variant Year Key features Trip point (nom.)
C64 Saver 1.x (Ray Carlsen) 2016 Through-hole, SCR crowbar, 5 V6 zener 5.4 V
C64 Saver 2.x (RC) 2019 Smaller PCB, TL431 reference, polyfuse replaces wire link 5.25 V
OpenC64Saver (SukkoPera) 2018 Fully open hardware, MOSFET disconnect, reverse-polarity diode User-set
SaV64 / SaV64-II (SharewarePlus) 2019 Commercial kit, optional OLED volt-meter, user-replaceable fuse 5.25 V
SaRuMan-64 2020 SMD, auto-reset, fold-back current limit 5.30 V
All variants honour Carlsen’s open-distribution request that the design remain non-proprietary for the benefit of the community.
Typical Bill of Materials (through-hole C64 Saver 2.3)
Qty. Reference Part
1 F1 Polyfuse 1.1 A (RXE110)
1 SCR1 C106-D or BT151-500R
1 U1 TL431 (2 %) shunt reg
2 R1, R2 1 kΩ & 4.7 kΩ (trip divider)
1 R3 220 Ω (LED limiter)
1 C1 100 nF decouple
1 D1 1N4148 (gate clamp)
1 D2 5.6 V Zener (reference bias)
1 LED1 3 mm bi-colour (GRN/RED)
1 J1 Male 7-pin DIN (to PSU)
1 J2 Female 7-pin DIN (to computer)
Installation
  1. Power off and unplug the PSU.
  2. Connect the PSU’s 7-pin DIN plug into the male side of the Saver.
  3. Plug the Saver’s female 7-pin into the computer.
  4. Power up. LED should show green.
  5. If LED immediately turns red or no power reaches the C64, the PSU is already faulty—do not keep using it.
The device draws under 5 mA and introduces ≈ 15 mΩ series resistance, insignificant even for sensitive Ultimate-64 boards.
Testing the Trip Circuit (Bench)
  • Dial a bench supply to 5.0 V and feed the Saver through the DIN pins (+5 V → pin 2, GND → pin 5).
  • Increase voltage slowly; at 5.3–5.5 V the LED flips to red and the output collapses to ≈ 0 V.
  • Remove input power for 5 s to reset the latch.
Limitations
  • Does not regulate ripple—a PSU with excessive 50/60 Hz ripple under 5.2 V will still pass.
  • No 9 VAC protection; an internal short in the PSU transformer can still inject noise or excessive VAC.
  • Not a substitute for a modern PSU—it is a last-line “crowbar”, not continuous regulation.
  • If the SCR version trips it may blow the PSU’s internal fuse; replace that fuse before re-testing.
Where to Buy or Build
  • DIY PCB/gerbers: OpenC64Saver repository (KiCad + BOM).
  • Kits / assembled: SharewarePlus SaV64 series, RETRO Innovations, and many eBay/Tindie sellers.
  • Integrated solutions: All Ray Carlsen modern PSUs ship with an internal Saver circuit plus precision linear regulation.
