DECstation 3100 Documentation
DECstation 3100 Documentation describes the Digital Equipment Corporation documents for the DECstation 3100 and DECstation 2100, with the PDF of each.
DECstation 2100/3100 Operator's Guide (EK-302AB-OG-002)
DEC's owner's guide, order number EK-302AB-OG-002, September 1989. The scan has 169 pages.[1]
Contents: 1 basic hardware (system unit and the rear panel, Figure 1-2 and Table 1-1; monitors; keyboard; mouse and its cleaning on pp. 1-14 to 1-15); 2 hardware options (memory, storage, printers, modems); 3 using the hardware (turning on and off, the configuration display, console commands, booting); 4 tape drive; 5 compact disc drive; 6 RX23 diskette drive; 7 troubleshooting (the self-test and its subtests, Ethernet and SCSI checks, Table 7-1 solutions to common problems); 8 moving the workstation; appendices A equipment specifications (system unit on p. A-2), B part numbers, C console commands, D interpreting the self-test (monitor codes Table D-1 and LED codes Table D-2).[1]
It is a user's guide. It has no disassembly procedure, no power supply information and no component data; memory and internal drives are left to DEC service.[1]
Download: DECstation 2100 3100 Operator's Guide (EK-302AB-OG-002).pdf
DECstation 2100/3100 Hardware Installation Guide (EK-290AB-IN-002)
DEC's installation guide, order number EK-290AB-IN-002, September 1989. The scan has 95 pages.[2]
Contents: 1 getting started (site requirements on pp. 1-1 to 1-2, unpacking); 2 installing the basic hardware (system unit, keyboard, mouse, Ethernet loopback and terminators, SCSI terminator, video cables, monitor, power cable and voltage labels on pp. 2-20 to 2-21); 3 starting and testing (failure to turn on, self-test results, Ethernet address); 4 optional peripherals (expansion boxes, SCSI switches, printers, communications devices); 5 completing the installation; 6 notes for experienced installers; appendix A Ethernet hardware connections.[2]
Download: DECstation 2100 3100 Hardware Installation Guide (EK-290AB-IN-002).pdf
DECstation 3100 Desktop Workstation Functional Specification (revision 1.3)
The engineering specification of the KN01 system module from DEC Workstation Systems Engineering, Palo Alto, revision 1.3 dated 28 August 1990, 84 pages. The file on bitsavers is named "Rev3.1", but the document's title page and revision history say 1.3.[3]
Contents: 1 the DECstation 2100/3100 (subsystem list); 2 external interface; 3 power requirements (Table 3-1); 4 address map; 5 interrupts; 6 subsystems: processor, memory, ROM, serial interface, SCSI interface (SII registers and commands), network interface (LANCE), system clock and battery-backed RAM (6.7), frame buffers, video timing and the reset switch (6.15).[3]
Download: DECstation 3100 Desktop Workstation Functional Specification (Rev 1.3, 1990).pdf
KN01 system module schematic (54-19463-01)
DEC's engineering drawings of the KN01 (PMAX) system module, drawing number 54-19463-01, revision CX01, 21 B-size sheets dated October 1988.[4]
Sheet titles include System Module (1), Cache (3), Memory Array (5), Memory Interface (6), Misc Interface (7), Serial Interface (8), EIA Drivers (9), EIA Receivers (10), Serial Connectors (11), Real-Time Clock (12, which also carries the power supply connector, battery connector and reset switch), Status Register (13), Plane Mask (14), Video Control (15), Network Buffer (17), Ethernet Transceiver (19) and Disk Buffer (20).[4]
Values are written on the drawings as text. There is no parts list, and the power supply is not included.
Download: DECstation 3100 KN01 System Module Schematic (54-19463-01, Oct 1988).pdf
Not online
The operator's guide lists DEC's DECstation 2100/3100 Maintenance Guide as EK-291AA-MG-002.[1] Manx catalogues an EK-291AB-MG edition but records no online copy.[5]
Pages that cite these documents
  1. ↑ 1.0 1.1 1.2 1.3 Digital Equipment Corporation, DECstation 2100/3100 Operator's Guide, EK-302AB-OG-002, September 1989, title page, contents and Table B-4. Source: bitsavers.org.
  2. ↑ 2.0 2.1 Digital Equipment Corporation, DECstation 2100/3100 Hardware Installation Guide, EK-290AB-IN-002, September 1989, title page and contents. Source: bitsavers.org.
  3. ↑ 3.0 3.1 Digital Equipment Corporation, DECstation 3100 Desktop Workstation Functional Specification, revision 1.3, title page, revision history and contents. Source: bitsavers.org.
  4. ↑ 4.0 4.1 Digital Equipment Corporation, KN01 system module schematic, 54-19463-01, title blocks of sheets 1 to 21. Source: bitsavers.org.
  5. ↑ Manx catalogue entries for EK-291AB-MG, "DECstation 2100/3100 Maintenance Guide", and EK-291AA-U4, manx-docs.org.
