File:IBM Options and Adapters - IBM Monochrome Display (5151).pdf
Link to the index page
Original file (0 ร— 0 pixels, file size: 150 KB, MIME type: application/pdf)
IBM, IBM Monochrome Display, part 6361470-series Options and Adapters section, Personal Computer Hardware Reference Library.
IBM's own technical description and specification for the IBM 5151 monochrome display: the 28.3 cm (11.5 in) 90-degree-deflection CRT, P39 high-persistence green phosphor, the 9 PEL by 14 PEL character matrix, 16.257 MHz video bandwidth, 50 Hz vertical with 350 lines of vertical and 720 lines of horizontal resolution, 18.432 kHz positive-level TTL horizontal drive, physical specifications and the logic diagrams for both the 110 Vac and the 220/240 Vac models.
Source: scanned by Ray Cunningham and published in the IBM Options and Adapters section of minuszerodegrees.net. Hosted here so that the repair guides on this wiki can cite a copy that will not disappear.
IBM published this manual as part of the Personal Computer Hardware Reference Library; it is reproduced here for the benefit of people maintaining surviving machines. IBM retains copyright.
Date/TimeDimensionsUserComment
current03:15, 23 September 20260 ร— 0 (150 KB)Josh (talk | contribs)IBM Options and Adapters technical reference section, for citation by the IBM peripheral pages
