IBM PC 3278/79 Emulation Adapter Technical Reference
The IBM Personal Computer 3278/79 Emulation Adapter Technical Reference is IBM's 22-page technical reference for the long 3278/79 Emulation Adapter, part number 1502336, first edition, October 1983. It is the same card that the IBM 3270 PC calls the Distributed Function Communications Adapter (DFCA). The scan has a text layer.
Contents
  • The BNC coaxial connection to the control unit
  • Interrupt level 2
  • The I/O registers at 2D0h to 2D6h: interrupt/status, visual/sound, cursor address, control, scan code and terminal ID
No schematic, no parts list and no fault-isolation procedure.
Pages that cite this document
Download: IBM PC 3278-79 Emulation Adapter Technical Reference 1502336.pdf
