Laserwriter Pro 1993
LaserWriter Pro 1993 is Apple's owner's guide for the LaserWriter Pro 600 and LaserWriter Pro 630, copyright 1993, part number 030-2508-C. It has xii front pages and 140 numbered pages; the scan has 150 pages including the covers.[1] It is the manual that came with the printers, not a service manual.
Contents
Page numbers are the guide's own.[1]
  • Radio and television interference (p. vii); Preface, The LaserWriter Pro 600 and LaserWriter Pro 630 (ix-xii): the two models, how the printer works, fonts, TrueType
  • Chapter 1, Setting Up the LaserWriter Pro (1): moving the printer, choosing a place, preparing the printer, first toner cartridge (7), loading paper (12-14), safety instructions (15)
  • Chapter 2, Connecting the LaserWriter Pro (17): connection ports (17), LocalTalk (18-21), Ethernet on the Pro 630 (22-25), serial (26) and parallel (27) cables, port settings (31), the push-button switch (32), power (33)
  • Chapter 3, Using Your Printer With a Macintosh Computer (35): software installation, fonts, the LaserWriter Utility (43-51), printing (52-55)
  • Chapter 4, Using Your Printer With an IBM PC or Compatible (57): Windows 3.1 and 3.0 drivers
  • Chapter 5, Loading the LaserWriter Pro With Paper (69)
  • Chapter 6, Troubleshooting (79): indicator lights (80), paper jams (80), connections (83), start-up problems (84), printed documents (84), Macintosh and PC troubleshooting (87-89)
  • Chapter 7, Maintenance (91): safety, precautions, low toner, replacing the toner cartridge (94), cleaning the exterior (98)
  • Appendix A, Upgrades (99): memory, hard disks
  • Appendix B, Paper handling options (105): envelope feeder, 500-sheet feeder and universal cassette, 250-sheet universal cassette
  • Appendix C, Specifications and Parts List (121): specifications, ozone emission (124), communication settings (124), available settings and accessories (127)
  • Appendix D, Service and Support (129); Appendix E, HP LaserJet printer emulation (131); Index (133)
What it settles
Appendix C gives Apple's specification. The marking engine is given as a Canon EX. Both controllers have a 25 MHz 68030 and 2 MB of ROM; the Pro 600 has 4 MB of RAM and the Pro 630 8 MB, both expandable to 32 MB. Both have LocalTalk/RS-422, RS-232 and Centronics parallel ports, and the Pro 630 adds Ethernet and SCSI. The laser is a 780 nm, 5 mW GaAlAs semiconductor laser. Speed is up to eight pages per minute. Minimum life expectancy is five years or 450,000 pages and the recommended service interval is 200,000 pages. The supply range is 90-110.5 V or 103.5-126.5 V AC at 58-62 Hz (US and Japan) or 194-264 V AC at 48-52 Hz (Europe and Australia); consumption is about 95 W on standby and up to 560 W at 100-115 V or 530 W at 220-240 V. The printer weighs 39 lb.[2] The LaserWriter Pro 600/630 Service Source names the engine as a Canon LBP-B270 and gives 8 MB for the Pro 600, noting that some early-1993 units shipped with 4 MB.
The communication settings table lists the port settings, baud rate, flow control and mode for each position of the rear push-button switch. Positions 0-5 are fixed and positions 6-9 can be changed with the LaserWriter Utility.[3] The accessories list gives order numbers such as M6018G/A for the toner cartridge and M5859G/A for the Pro 630 controller card upgrade.[4]
It is an owner's manual. There are no service procedures, board diagrams, schematics or DC supply voltages, and the parts list is a list of orderable accessories.[1] Service information for these printers is in the LaserWriter Pro 600/630 Service Source and in Apple Service Guide Laserwriter Printers Volume Ii Sept 1993.
Pages that cite this document
Download: LaserWriter Pro 1993.pdf
  1. ↑ 1.0 1.1 1.2 Apple Computer, Inc., LaserWriter Pro 600 and 630 owner's guide (1993), copyright page, contents pp. iii-vi, index ending p. 140 and back cover (PDF pp. 3-7, 148, 150). Hosted as File:LaserWriter Pro 1993.pdf.
  2. ↑ LaserWriter Pro owner's guide, Appendix C, Specifications, pp. 121-123 (PDF pp. 130-132).
  3. ↑ LaserWriter Pro owner's guide, Appendix C, Communication settings, pp. 124-126 (PDF pp. 133-135).
  4. ↑ LaserWriter Pro owner's guide, Appendix C, Accessories, p. 127 (PDF p. 136).
