Macintosh Quadra 800 Troubleshooting
Troubleshooting is essential for diagnosing and resolving issues with your Macintosh Quadra 800. This guide covers the most common problems encountered with this system.
Preliminary Checks
[edit | edit source]Before detailed troubleshooting, verify:
- Power cable is securely connected
- Power outlet is functional (test with another device)
- All internal cables are properly seated
- PRAM battery is installed and has charge
- No foreign objects are inside the case
Power Supply Specifications:
- Input: 100V-240V AC, 47-63 Hz
- Maximum: 200 watts
No Power (System Dead)
| No response when power button pressed | Dead PRAM battery | Replace 3.6V lithium battery |
| No response | Failed power supply | Test PSU voltages; replace if out of spec |
| No response | Faulty power switch | Test continuity of power switch; replace if faulty |
| Power light on, no startup | Logic board failure | Check for corrosion, reseat chips, test components |
| Ticking or clicking sound | Short circuit or PSU issue | Disconnect all peripherals and internal drives; test bare system |
Power Supply Testing
[edit | edit source]Measure voltages at the logic board power connector:
- +5V: Should read 4.85V โ 5.15V
- +12V: Should read 11.9V โ 12.7V
- -12V: Should read approximately -12.0V
If voltages are out of specification, the power supply may need capacitor replacement or full replacement.
Startup Chime but No Video
| Chime, no video on any monitor | Failed VRAM | Reseat or replace VRAM SIMMs |
| Chime, no video | Faulty video output circuit | Test with NuBus video card if available |
| Chime, no video | Incompatible monitor | Try a different monitor or adapter |
| Distorted or garbled video | VRAM failure | Replace VRAM SIMMs |
| Distorted video | Incorrect VRAM configuration | Ensure matching VRAM SIMMs are installed |
| Video works on NuBus card only | On-board video failure | Use NuBus video card as workaround; logic board repair needed for on-board video |
| Random freezes | Bad RAM | Test RAM modules individually; replace faulty SIMMs |
| Random freezes | Overheating | Clean dust from interior; verify fan operation |
| Boots sometimes, not others | Weak PRAM battery | Replace PRAM battery |
| Boots sometimes | Marginal power supply | Test voltages under load; recap or replace PSU |
| Freezes during disk access | SCSI issues | Check termination, cables, and device IDs |
| Freezes during disk access | Failing hard drive | Run diagnostic software; backup and replace drive |
Sad Mac Error Codes
[edit | edit source]A Sad Mac icon indicates a hardware failure detected during POST. The codes displayed below the icon help identify the failing component.
See the Sad Mac Error Codes page for a comprehensive list.
Common Quadra 800 Sad Mac Codes:
| Code | Meaning | Action |
| 0000000F 00000001 | ROM test failed | Logic board fault; may need repair |
| 0000000F 00000002 | Memory test failed | Test/replace RAM SIMMs |
| 0000000F 00000003 | Memory addressing error | Check SIMM seating; test individual SIMMs |
| 0000000F 00000004 | Memory test โ byte error | Replace faulty SIMM |
| 0000000F 0000000E | Data bus test error | Logic board issue |
| 0000000F 0000000F | Address line test error | Logic board issue or RAM problem |
SCSI Issues
| Flashing question mark | No bootable drive found | Check SCSI cables and termination; verify drive is spinning |
| Flashing question mark | Corrupt system folder | Boot from CD or floppy; reinstall system |
| Drive not recognized | Incorrect SCSI ID | Ensure unique IDs (0-6) for each device |
| Drive not recognized | Missing termination | Add terminator to last device in chain |
| Intermittent SCSI errors | Bad cables | Replace SCSI ribbon cable |
| External device not seen | Termination power issue | Some devices need termination power; check settings |
Memory Issues
| Sad Mac on startup | Faulty SIMM | Remove SIMMs one at a time to identify bad module |
| Less RAM recognized than installed | Incompatible SIMM | Use 60 ns or faster 72-pin SIMMs |
| Less RAM recognized | SIMM not fully seated | Reseat all SIMMs |
| Intermittent errors | Dirty contacts | Clean SIMM contacts with isopropyl alcohol |
| Memory errors in specific applications | Marginal SIMM | Replace SIMM even if it passes basic tests |
Floppy Drive Issues
[edit | edit source]See: Macintosh Floppy Drive Maintenance
| Disk not recognized | Dirty heads | Clean heads with cleaning disk |
| Disk not recognized | Misaligned heads | Professional realignment or drive replacement |
| Disk ejects immediately | Bad disk | Try different disk |
| Disk ejects immediately | Drive failure | Replace floppy drive mechanism |
| Read/write errors | Worn heads | Replace floppy drive |
CD-ROM Issues
[edit | edit source]If equipped with the AppleCD 300i:
| Disc not recognized | Dirty laser lens | Clean lens with appropriate cleaner |
| Disc not recognized | Incorrect SCSI ID | Verify CD-ROM has unique SCSI ID (typically 3) |
| Audio CDs don't play | Software issue | Check CD player software settings |
| Slow reading | Dirty lens | Clean laser lens |
| Tray won't open | Mechanical failure | Use emergency eject hole; may need drive replacement |
NuBus Card Issues
| Card not recognized | Poor contact | Reseat card firmly |
| Card not recognized | Dirty contacts | Clean card edge connector with isopropyl alcohol |
| System unstable with card | Incompatible card | Check compatibility; update drivers |
| System unstable with card | Power supply overloaded | Remove other cards; test individually |
| Conflicts between cards | Resource conflicts | Try different slot configurations |
Startup Sequence
[edit | edit source]Normal Quadra 800 startup sequence:
- Power supply activates
- Startup chime sounds
- POST (Power-On Self-Test) runs
- RAM test completes
- SCSI bus scans for devices
- Boot device selected
- System software loads
- Desktop appears
If the sequence fails at any point, the failure location indicates which component to troubleshoot.
