Programming the 68000 Macintosh Assembly Language 1986
The file this page embeds is not on the wiki.
The page was created to hold a document named Programming_the_68000_Macintosh_Assembly_Language_1986.pdf. That file has never been uploaded: it does not appear in the wiki's image list under that name, under any case or punctuation variant, or under any close variant found by fuzzy matching across all 1,481 files held here. The embed and the download link on this page are therefore both dead, and the page is kept only so that the gap is visible rather than silent.
Nothing about the missing document is asserted here. No author, publisher, edition, page count or content is claimed, because none of it can be checked. If you have the file, upload it as File:Programming_the_68000_Macintosh_Assembly_Language_1986.pdf and this page will work as intended.
This is not a repair source
This is a programming book. It contains no schematics, no parts lists, no component values, no voltages, no connector pinouts and no service procedures, and nothing in it should be cited for a hardware figure. Apple's software documentation and its compiler manuals describe the machine as the programmer sees it, which is not the machine the technician sees.
For hardware data use:
 level: specifications, symptom charts, take-apart and module part numbers
  • Apple's Developer Notes — the one class of Apple developer document that does carry
 rail currents, expansion-slot power budgets and connector pinouts. Several are held here, for
 example Macintosh IIci Developer Note, Macintosh IIsi Developer Note and
 Macintosh LC 475 and Quadra 605 Developer Note.
 the compact Macs
