Super Nintendo General Maintenance
Super Nintendo (SNS-CPU-GPM-01) Motherboard
The iconic Super Nintendo Entertainment System (SNES, Super Famicom, SFC) is now over 30 years old. Aging capacitors, yellowing plastics, and unreliable power supplies are common issues threatening these classic consoles.
This page collects best-practice hardware care, preventive maintenance, and periodic checks for all major SNES/SFC motherboard revisions. Follow these guidelines to keep your SNES running reliably for years to come.
Identify Your Board Revision
SNES/SFC Motherboard Generations
Board Code Year(s) Region Key Differences
SNS-CPU-GPM-01/02/03 1991–1995 NTSC-U Early “1CHIP” boards, separate CPU/PPU/PPU2, through-hole caps, robust VRAM
SNS-CPU-RGB-01 1995–1997 NTSC-U “1CHIP” revision, improved RGB video, fewer chips, SMD capacitors
SHVC-CPU-01/02 1990–1993 NTSC-J (SFC) Japanese launch boards, similar to early US, unique S-RGB encoder
SNSP-CPU-01/02 1992–1997 PAL 50 Hz, unique lockout, different video encoder, SMD caps on later boards
SNS-101 (“SNES Mini”) 1997–1999 NTSC-U/J Smallest board, no RF modulator, SMD-only, no eject lever
Find the board code silkscreened near the cartridge slot or on the PCB edge.
Regular Cleaning
Case & Controller Ports
  • Wipe exterior ABS plastic with a damp microfiber cloth and mild dish soap.
  • For yellowed cases, use retrobright cautiously—avoid overheating and UV overexposure.
  • Clean controller ports with a soft brush and 99% isopropyl alcohol (IPA).
Cartridge Slot & Expansion Port
  • Use a dry, clean cartridge to gently exercise the slot.
  • For stubborn contacts, insert a thin card wrapped in IPA-dampened cloth.
  • Clean the expansion port (underside) with compressed air and a soft brush.
PCB Dust & Corrosion
  • Unplug the console and wait 5 minutes for capacitors to discharge.
  • Blow away dust with compressed air; brush gently with an antistatic brush.
  • Inspect for green/white corrosion near capacitors and battery.
Power Supply & Battery
  • Only use an original or high-quality modern replacement PSU (9–10V DC, center-negative, 850–1200mA).
  • Avoid cheap, unregulated adapters—these can cause overvoltage and damage.
  • If your SNES has a save battery (CR2032 or soldered lithium cell), check for leaks.
  • Replace leaking or dead batteries with a quality branded cell.
Preventive Maintenance
Capacitors
  • Early SNES/SFC boards use through-hole electrolytic capacitors; later and Mini use SMD.
  • Inspect for bulging, leaking, or crusty caps—especially near the power input and audio section.
  • Replace aging capacitors with high-quality 105°C-rated parts, matching capacitance and voltage.
Cartridge Slot Care
  • Avoid “blowing” into cartridges—moisture can corrode contacts.
  • Clean cartridge PCBs with IPA and a soft eraser if needed.
Eject Mechanism (Original SNES)
  • Lightly lubricate the eject lever’s pivot with plastic-safe grease if sticky.
  • Do not force—replace broken springs or levers with reproduction parts.
Storage & Handling
  • Store SNES in a cool, dry place away from direct sunlight.
  • Avoid stacking heavy items on the console—plastic can warp or crack.
  • Keep cartridges and controllers disconnected when not in use.
Periodic Checks
  • Power on the SNES every 6–12 months to keep capacitors “formed.”
  • Inspect the PCB for corrosion, leaking caps, or battery damage annually.
  • Test video and audio output for distortion or color loss.
Troubleshooting Basics
  • No power: Check PSU, power switch, and fuse (replace if blown).
  • No video/audio: Clean cartridge slot, check AV cable, inspect for cracked solder joints.
  • Random freezes: Suspect dirty cartridge slot, failing caps, or dry solder joints.
  • Distorted colors: Clean AV port, inspect for bad caps near video encoder.
