Amstrad PC 2386 Service Manual
The PC2386-65 Personal Computer Service Manual is Amstrad's own service manual for the PC2386. 46 pages. No text layer, so values must be read from the page images.
Contents
[edit | edit source]Amstrad's own contents list:
- Technical specification; notes to engineers; safety tests; alignment instructions
- Memory and FDD expansion PCBs
- Main PCB top and bottom views; expansion board / LED PCB top and bottom views; power / keyboard / bug PCBs
- Interconnection diagrams; chassis schematic diagrams
- Keyboard chassis schematic diagram
- Electrical parts list
- Keyboard exploded view; cabinet exploded view and parts list
- Power supply chassis schematic diagram
What it settles
[edit | edit source]Technical specification: 80386 at 20 MHz, zero wait states, 32-bit full-width main memory, 80387 socket, 4 MB of parity-checked RAM, a 64K / 35 ns RAM cache, five 16-bit expansion slots, asynchronous bus operation, a 65 MB hard disc option at 1:1 interleave, 1.4 MB floppy drives, connectors for an external 5.25-inch or 3.5-inch drive and a tape streamer, Hercules/CGA/EGA/VGA compatible video, a bi-directional parallel printer port, an RS232 serial port, battery-backed clock and configuration RAM, a Microsoft-compatible mouse, a 101/102-key AT keyboard with a security lock, a speaker volume control, built-in LIM 4.0 with a RAM division option between conventional, extended and LIM, and Novell NetWare server compatibility. System unit 415 × 160 × 485 mm; keyboard 475 × 35 × 200 mm.
Amstrad's notes to engineers set the repair policy, and they are unusually blunt:
- "no component level repairs are to be carried out on Main CPU PCB. After diagnosis test if the fault is confirmed replace CPU PCB."
- The same applies to the floppy and hard disc drives, and any attempt to repair or replace parts within them invalidates the warranty.
- "PSU & Monitors are subject to component level repairs."
That last sentence is why this manual includes a power supply chassis schematic diagram but treats the mainboard as an exchange unit. It is also a caution for anyone reading the electrical parts list: Amstrad expected it to be used for the supply and the peripherals, not for board-level repair of the CPU PCB.
Safety test figures: flash test at 1.5 kV RMS for 3 s between mains live/neutral and all accessible exterior metal; insulation resistance at the same voltage showing greater than 4 MΩ; and earth continuity of the mains lead not exceeding 0.5 Ω.
[edit | edit source]- No CPU board component-level repair information, by Amstrad's explicit instruction.
- No drive service data.
- No monitor sections — unlike the PC2086 manual, no display is covered here.
- No fault-symptom table or diagnostic flowchart.
- No text layer, so nothing can be searched.
Download here: Amstrad PC 2386 Service Manual.pdf
