Apple Hard Disk 20 Owner's Guide
Macintosh Hard Disk 20 is Apple's 1985 owner's guide for the Apple Hard Disk 20, scanned as a 60-page PDF. The scan opens with Apple's separate "Macintosh Update: Hard Disk 20" sheet (PDF pp. 1-7), which adds notes for owners with a Macintosh Plus or a LaserWriter. The guide describes the Hard Disk 20 Startup disk's System file as dated 1 September 1985.[1]
Contents
Printed page numbers, from the guide's contents list. PDF page numbers run ahead of them: printed p. 2 is PDF p. 13, printed p. 38 is PDF p. 45 and printed p. 44 is PDF p. 50.[1]
  • Chapter 1, Getting Started (p. 1): unpacking, handling, connecting the hard disk, starting up for the first time, switching on and off, adding a second Hard Disk 20 or an external 3.5-inch drive.
  • Chapter 2, Using the Hard Disk 20 (p. 13): the Open and Save As commands, backing up, the new Finder, where system software lives, the current startup disk, the Choose Printer desk accessory, installing the LaserWriter, the Font/DA Mover.
  • Chapter 3, Maintenance and Troubleshooting (p. 37): operating environment, cleaning, common problems, using Hard Disk 20 Test.
  • Appendix A, Hard Disk 20 Specifications (p. 44); Appendix B, Service and Support; Appendix C, Radio and Television Interference; Appendix D, Safety Information; glossary and index.
What it settles
  • Placement: put the HD20 under the Macintosh, and keep its side vents clear. If it goes beside the Macintosh, put it on the right; on the left it risks magnetic interference from the Macintosh's power supply and video circuitry (p. 2, PDF p. 13).
  • Operating environment: 50 to 104 °F and 20 to 80 % relative humidity; keep liquids, solvent fumes and steam away from it (p. 38, PDF p. 45).
  • Troubleshooting for owners: a missing HD20 icon usually means the Macintosh was switched on before the HD20; a damaged System file on the HD20 is replaced from the Startup disk (pp. 39-40, PDF pp. 46-47).
  • Hard Disk 20 Test, on the Startup disk, takes about 15 minutes and tests the hard disk on the Disk Drive port. Apple suggests running it every month or so; it tests hardware only (pp. 40-41, PDF pp. 47-48).
  • The specifications match Apple's Tech Info Library article 1306: 20,769,280 bytes formatted, 39,040 blocks of 532 bytes, 85-270 V AC, 30 W, 3.2 kg (p. 44, PDF p. 50).
It is an owner's guide. It warns owners not to remove the cover because the unit holds high-voltage components that keep their charge after switch-off (p. 39, PDF p. 46), and it has no take-apart procedure, parts list, schematic or component values. For those, see Apple Hard Disk 20 Technical Procedures and Apple Hard Disk 20 Service Source.
Pages that cite this document
Download: Apple Hard Disk 20 Owners Guide 1985.pdf
  1. ↑ 1.0 1.1 Apple Computer, Macintosh Hard Disk 20 (owner's guide, 1985), with the "Macintosh Update: Hard Disk 20" sheet. Hosted as File:Apple Hard Disk 20 Owners Guide 1985.pdf; from archive.org item AppleHD20Manual.
