Apple High-Res Monochrome Monitor Technical Procedures
The High-Res Monochrome Monitor Technical Procedures are the section of Apple's Apple Service Technical Procedures, Volume Six that covers the 12-inch Apple High-Res Monochrome Monitor for the Macintosh II, 57 pages revised May and June 1987. Apple's Service Source volume for the monitor is described at Apple High-Res Service Source.
Contents
From the section's table of contents:
  • Section 1, Basics: product description, safety precautions, safe electrical setup, CRT safety rules, live adjustment rules, disposing of the CRT
  • Section 2, Take-Apart: rear cover, discharging the CRT, main logic board, power supply, fuse, contrast control board, video board "C", chassis assembly, CRT, LED cable assembly, power switch, AC inlet
  • Section 3, Adjustments: safety instructions, setup, materials, running the test, subbrightness (cutoff), horizontal size (width), vertical size (height), focus
  • Section 4, Troubleshooting: symptom chart
  • Illustrated Parts List: internal assembly, CRT case assembly
Module-level service only: no schematic and no component values.
Pages that cite this document
Download: Apple High-Res Monochrome Monitor Technical Procedures.pdf
