Apple Lisa General Maintenance
Proper maintenance is essential to extending the lifespan and ensuring reliable operation of your Apple Lisa. As one of the earliest GUI-based personal computers, the Lisa requires special attention due to its age and the complexity of its systems.
Regular Cleaning
[edit | edit source]Internal Cleaning
[edit | edit source]- Power off and unplug the Lisa; allow capacitors to discharge for at least 24 hours before opening
- Use compressed air to remove dust from the interior, paying special attention to the power supply and cooling vents
- Clean the motherboard (I/O board) and CPU board with a soft brush
- Inspect and clean the expansion card slots
- Check for signs of corrosion or electrolyte leakage from capacitors
External and CRT Cleaning
[edit | edit source]- Clean the exterior plastic with a damp cloth and mild soap
- Use appropriate CRT-safe glass cleaner on the display
- Clean air vents with compressed air to maintain proper airflow
- Inspect the rear connector panel for dust buildup
Keyboard and Mouse Cleaning
[edit | edit source]- The Lisa keyboard uses capacitive foam pads that deteriorate over time
- If keys are unresponsive, the foam and foil pads may need replacement
- Clean the keyboard housing with isopropyl alcohol
- The Lisa Mouse uses a steel ball that should be cleaned regularly
PRAM/Parameter RAM
[edit | edit source]The Lisa uses parameter memory to store configuration settings:
- Located on the I/O board
- Powered by a battery on some models
- Battery leakage can cause significant board damage
- Inspect the battery area regularly and remove or replace failing batteries
Power Supply Maintenance
[edit | edit source]Critical Safety Capacitors
[edit | edit source]The Lisa power supply contains several RIFA-style safety capacitors that are prone to failure:
- These capacitors can crack, smoke, or explode when they fail
- Common values include 0.1µF, 0.22µF, and 0.047µF at 250V
- Replace with modern X2-rated safety capacitors
- ALWAYS replace RIFA caps preventatively before powering on a long-stored Lisa
Electrolytic Capacitors
[edit | edit source]- Power supply electrolytics should be replaced if the unit has not been serviced
- Check for bulging, leaking, or corroded capacitor cans
- Use capacitors rated for the appropriate voltage and temperature
Common Failure Points
[edit | edit source]Power Supply
[edit | edit source]- RIFA safety capacitors (most common cause of smoke/failure)
- Electrolytic capacitors in both high and low voltage sections
- Power transistors and voltage regulators
Memory Cards
[edit | edit source]- The Lisa uses proprietary 512K memory cards
- RAM chip failures are common
- Oxidation on edge connector contacts
- Clean contacts with isopropyl alcohol and a soft eraser
I/O Board
[edit | edit source]- IWM (Integrated Woz Machine) chip failures affect disk operations
- ROM chip failures (version should be H/88 for Lisa 2/10)
- Serial port driver chips
Floppy Drives
[edit | edit source]- Sony 400K drives in Lisa 2 models often have seized mechanisms
- Lubrication dries out over time
- Head cleaning may be required
- See Macintosh Floppy Drive Maintenance for compatible procedures
Widget Hard Drive (Lisa 2/10)
[edit | edit source]- The internal Widget drive is notorious for reliability issues
- No low-level format utility is publicly available
- Modern alternatives include X/ProFile or IDEfile emulators
- Consider ProFile emulation for long-term reliability
CRT Maintenance
[edit | edit source]Discharge Procedure
[edit | edit source]- The CRT operates at high voltage and retains charge after power-off
- Always discharge the CRT anode before working near it
- Use proper CRT discharge procedures (see CRT Discharge Procedure)
Display Adjustments
[edit | edit source]- Horizontal and vertical size/position adjustments are on the analog board
- Focus and brightness controls may require adjustment after capacitor replacement
- Some adjustments require accessing the deflection yoke
Voltage Checks
[edit | edit source]After any power supply work, verify output voltages:
- +5V rail: 4.85V – 5.15V
- +12V rail: 11.9V – 12.7V
- -12V rail: within 5% of nominal
- Check under load for proper regulation
