Atari 65XE General Maintenance
Atari 65XE (photo)
Atari 65XE
General maintenance for the Atari 65XE. Cleaning, supply, connector, keyboard and colour-adjustment work is the same across the XE range, and the Atari 130XE General Maintenance page has the full procedures.
Which board is fitted
Atari 65XE board assemblies (2016 reproduction, section 2)
Assembly RAM Figure Notes
CO70025 8 × 4164 (64K × 1) at U9–U16 2-7 No C22
CA20097 8 × 4164 at U9–U16 2-9 Drawn as "65XEN"
CA200519 (C103579-001) 2 × 4464 (64K × 4) 2-11 Shared with the 800XE; the sheet is titled "65XE/800XE"
The figures are from the 2016 reproduction of the 130XE service manual, whose schematics were redrawn in 2014 by "jer/eightbitter"; it is not an Atari document.[1] The FAQ lists late NTSC 65XEs on the NTSC 130XE board and the common later PAL 65XE, with the expansion (ECI) port, on the PAL 130XE board.[2] The board determines how many RAM chips there are to test and whether C22 is fitted.
The 65XE takes +5 V DC from an external supply through a 7-pin DIN socket, J7 (Atari part C061838 on the 130XE): pins 1, 4 and 6 are +5 V, pins 3, 5 and 7 ground and pin 2 the shield.[3][2] It is not a barrel jack, and there is no rectifier or regulator on the board; after the power switch S1 the 5 V is filtered into separate rails through ferrite beads.[4]
The FAQ lists two Atari supplies for the 65XE: the 5 V DC 1 A unit C070042, whose "Logo" version shipped with most 65XEs, and the 5 V DC 1.5 A unit C061982/CA024814 shared with the 600XL, 800XL, 130XE and XE Game System. It warns that the sealed "Ingot" version of the 1.5 A unit, supplied with some 65XEs, can damage the computer if it fails and the machine is not switched off quickly, and advises disconnecting it if hum bars appear on the screen.[2]
Measure an unknown supply at its plug before connecting it. If a supply has failed, check the computer for a short between J7 pins 1 and 3 with the power switch on before fitting a replacement. The supply and its own capacitors are covered on Atari 130XE General Maintenance#Power supply.
Opening the machine
The reproduction gives the sequence as: four screws in the bottom cover; disconnect the keyboard cable and the LED connector; seven screws hold the shielded board; seven tabs hold the shields together.[1] The full sequence is on Atari 130XE General Maintenance#Opening the machine.
Capacitors
There are eleven electrolytics, or ten on a CO70025 board, which has no C22. The largest is C1, 470 µF, the input reservoir after the power switch; C2 and C3 sit beside it on the incoming supply.[4] The complete list with ratings and Atari part numbers is on the Atari 65XE Capacitor Replacement Guide.
Self test
Hold OPTION while switching on, with no cartridge and no powered disk drive, to disable the built-in BASIC and run the self test.[2] Atari's XE/XL production test cartridge (Rev 3.4) goes further; its tests and error codes are on the Atari 65XE Troubleshooting Guide.[5]
Colour adjustment
The colour control is R38, a 500 kΩ preset (Atari C023030-04 on the 130XE).[3][4] Atari's production test adjusts it with the video test's colour tuning bar: turn the pot until the smaller bar inside the tuning bar disappears. The pot is reached through a hole in the bottom of the housing.[5] Adjust it before suspecting GTIA for a colour fault.
  1. ↑ 1.0 1.1 Atari 130XE Personal Computer Field Service Manual, 2016 reproduction (PDF author "Jurek"), schematics "Drawn by jer/eightbitter", 2014: section 2, figures 2-7, 2-9 and 2-11, and section 4, console disassembly. Not an Atari publication. Hosted on this wiki: Atari 130XE Field Service Manual (PDF).
  2. ↑ 2.0 2.1 2.2 2.3 Michael D. Current (ed.), comp.sys.atari.8bit Frequently Asked Questions, last modified 29 November 2009, sections 1.7 (versions and boot options), 1.16 (power socket pinout) and the power supply list, faqs.org.
  3. ↑ 3.0 3.1 Atari (U.S.) Corp., 130XE Parts List, 25 June 1985: J7 (C061838) and R38 (C023030-04). Hosted on this wiki: Atari 130XE Parts List and Production Test Instructions (PDF).
  4. ↑ 4.0 4.1 4.2 Jerzy Sobola, Atari 65XE schematic, nine sheets, 2003–2009: sheet 3 (R38) and sheet 8 (J7, S1, L1–L3, C1–C3). Community redrawing of the 8 × 4164 board. Hosted on this wiki: File:ATARI65XE-SCHEMATIC.pdf.
  5. ↑ 5.0 5.1 Atari Corp., XE/XL Production Test Operator's Instructions, Rev 3.4, 22 May 1986, pages 1 and 2 (the cartridge identifies a 65XE as "ATARI 65XE TESTS"; video test and colour tuning bar), in Atari 130XE Parts List and Production Test Instructions.
