Atari PC5 AMI-386 BIOS Plus User Manual
This is the documentation supplied with the Atari PC5: American Megatrends' AMI-386 BIOS PLUS User Manual and AMI's system board documentation, stamped by Atari Computer GmbH, Braunschweig. The scan has 132 pages with a text layer; the schematic pages are low resolution but legible.
Contents
[edit | edit source]In PDF page order:
- AMI-386 BIOS user manual, section 1: installing the BIOS, the CMOS set-up, clock speed and wait-state selection from the keyboard, and the errors reported by the BIOS, including the fatal-error beep counts (1 DRAM refresh, 2 parity circuit, 3 base 64 KB RAM, 4 system timer, 5 processor, 6 keyboard controller gate A20, 7 virtual-mode exception, 8 display memory, 9 ROM BIOS checksum) and messages such as "CMOS battery state low"
- Section 2: AMI's built-in diagnostics for hard disk, floppy, keyboard and video
- AMI-386 system board manual: installation, the jumper and switch list (J1 turbo LED, J2 hard reset, J4 EPROM type, J19 speaker, J20 keyboard lock, J21 four-pin battery connector for the clock and CMOS, J22 keyboard), and a system overview: 80386 at 16 MHz, optional 80387, 64 KB cache, 8.5 × 13 inch board, four 16-bit slots, one 8-bit slot and one 32-bit memory slot
- AMI schematics: the 32-MEM 32-bit memory card (Rev A, 26 August 1987) and the 386PC system board (Rev 4A, 28 July 1987, 23 sheets), with the 80386 at U1
[edit | edit source]No Atari parts list and no power supply schematic.
Pages that cite this document
[edit | edit source]- Atari PC5: cites Section 3.1, Section 1.3, Section 10, Sheet 1
