Commodore PET 2001 General Maintenance
Commodore PET 2001 with the top lifted open.
Routine care of the Commodore PET 2001 covers cleaning, the keyboard, the chip sockets, supply checks and the CRT hazards. For fault-finding see Commodore PET 2001 Troubleshooting; for component values see Commodore PET 2001 Capacitor Replacement Guide. Commodore's parts lists and schematics for the machine are hosted at Commodore PET 2001 Service Documentation.[1][2][3][4]
Before you start
The mains transformer is mounted in the case, with the power switch and a 1.8 A fuse on its primary. A 16.2 V AC winding feeds the display assembly and a 15.7 V AC centre-tapped winding feeds the main logic board, with a 23,000 µF reservoir capacitor wired in the case.[5]
  • Mains voltage is present at the switch, the fuse and the transformer primary whenever the machine is plugged in. Unplug it at the wall.
  • The CRT anode runs at about +10 kV from flyback T2, and the tube holds that charge after power-off. Discharge it before working near it; see CRT Discharge Procedure.
  • The display assembly also carries a +85 V boost rail and a −30 V rail.[3]
  • C1 on the display assembly (4700 µF) and the 23,000 µF capacitor in the case store real energy. Bleed them through a resistor.
Which board do you have
Commodore built four variants of the original static board. Its note on the schematic records that all component locations are the same across the four and only the fitted devices differ; the board number is printed in the upper left corner.[2]
Original PET 2001 static board assemblies
Assembly ROMs RAM
320008 6540 6550
320081 2316B 6550
320132 6540 2114
320137 2316B 2114
The later 2001-N, 3000 and 4000 board is a different, dynamic design; see Commodore PET 4000 Series Maintenance Guide.
Regular cleaning
Internal
  • Unplug the machine and discharge the CRT before lifting the top.
  • The top lifts on its hinge to expose the logic board and the CRT.
  • Use compressed air and an anti-static brush on the logic board, particularly around the ROM and RAM sockets, and on the display assembly and the cassette deck.
  • Use isopropyl alcohol (over 90 %) on swabs for stubborn areas. Do not soak the board.
External
  • Mild soap on a damp microfibre cloth for the painted steel case.
  • Glass cleaner sprayed onto a lint-free cloth, never onto the tube, for the screen.
Power supply checks
What generates what
Assembly Produces Regulators
Main logic board +9 V unregulated from CR1 and CR2; four +5 V supplies VR3, VR4, VR5, VR6[2]
Display assembly +12 V, +85 V boost, −30 V, about +10 kV anode VR1, a 7812 (Commodore 901527-01)[4][3]
Commodore's parts cross-reference for the logic board omits VR3 to VR6; they appear on sheet 2 of the schematic. Each feeds its own part of the board, so a single failed regulator can leave one section dead while the rest works.[2]
What to inspect
  • The four regulators and their heatsinks on the logic board, and CR1 and CR2, for heat stress, discoloured board and cracked joints.
  • The joints at the display assembly's bridge rectifier CR19-CR22 and at VR1.
  • The reservoir capacitor in the case and its wiring.
Neither Commodore parts list names a mains suppression (X or Y class) capacitor. The highest-rated capacitors in the display assembly's list are the 500 V ceramic discs at C18, C20 and C30.[4][1]
Voltage test points
Where to measure
Rail Where Note
+5 V TP1-1 to TP1-4, the four regulator outputs[2] Measure all four
+5 V 6502 (UF3) pin 8 Pins 1 and 21 are ground; pin 40 is RESET[5]
+9 V unregulated Regulator inputs; the cassette-motor circuit Feeds VR3-VR6 and the motor drivers[2]
+12 V VR1 output on the display assembly The display board's only regulated rail[3]
+85 V, −30 V Display assembly Present whenever the machine is running[3]
Capacitors
The main logic board has four aluminium electrolytics, C7 to C10 (47 µF 16 V), one on each regulator output. The rest of the C1-C49 range on that board is ceramics, apart from C5 and C11-C13, which are 1 µF 25 V tantalums; replace those with tantalums.[1][2] The bulk capacitors are the 23,000 µF reservoir in the case and C1 (4700 µF 25 V) on the display assembly.[5][4]
Full lists with Commodore part numbers are on Commodore PET 2001 Capacitor Replacement Guide. See also Capacitor Failure Symptoms.
Keyboard
The 2001-4 and 2001-8 have a calculator-style keyboard with small keys.[6]
  • Photograph the keycap layout before taking anything apart.
  • Clean the contact pads on the PCB with isopropyl alcohol.
  • Inspect for lifted traces and corroded vias, and check the connector at both ends. A whole dead row or column points at the connector or a broken trace, not a single key.
  • Conductive paint will restore a worn pad, but it does not last as well as the original plating.
Sockets
The 6502, the two PIAs, the VIA, the character generator, the seven ROM positions and all eighteen RAM positions are socketed.[1] PETs are known for socketed chips working out of their sockets; reseat each chip in its original position and orientation.[7] The original 6540 ROMs and 6550 RAMs are unreliable parts in their own right.[8]
  • Remove chips with a proper puller, clean the pins and the socket, and reseat firmly.
  • Replace a failed socket with a turned-pin type.
Cassette deck
  • Check the drive belt for perishing or slack.
  • Clean the head, pinch roller and capstan.
  • Check head azimuth if tapes from other machines will not load.
Diagnostics
  • A PET test ROM exercises RAM and ROM faster than swapping chips. Tynemouth Software runs one from a ROM/RAM replacement board, which also takes load off the original 6540 and 6550 parts.[8]
  • Check 5 V at the user port and the Φ2 clock first, then the CPU's interrupt and reset lines.[7]
  • Run the machine for a few hours to show up marginal parts that pass a cold test, and watch the regulator heatsinks while it runs.
Tools
  • ESD-safe driver set, chip puller, plastic spudger
  • Digital multimeter; a CRT discharge tool
  • Isopropyl alcohol (99 %), contact cleaner, anti-static brush
  • Fine-tip temperature-controlled soldering iron, braid or pump
  • ESR meter, logic probe or oscilloscope
See Recommended Tools.
  1. ↑ 1.0 1.1 1.2 1.3 Commodore Business Machines, 8K Main Logic Assembly Parts Cross Reference for the PET 2001, hosted at File:Commodore PET 2001 Main Logic Assembly Parts List.pdf. Components of the system board by reference designator and Commodore part number, including C7-C10 (47 µF 16 V electrolytics), C5 and C11-C13 (1 µF 25 V tantalums), CR1-CR3 (1N5402), the cassette-motor transistors and the IC sockets. It does not list the four +5 V regulators.
  2. ↑ 2.0 2.1 2.2 2.3 2.4 2.5 2.6 Commodore Business Machines, PET Computer Main Logic schematic, drawings 320130 and 320026, hosted at File:Commodore PET 2001 Main Logic Schematic (320008).pdf. Sheet 1: cassette-motor drivers on the +9 V unregulated rail with 7.2 V zeners VR1 and VR2. Sheet 2: J8, CR1-CR3 and regulators VR3-VR6 with outputs at test points TP1-1 to TP1-4. Sheet 3: component locations common to assemblies 320008, 320081, 320132 and 320137.
  3. ↑ 3.0 3.1 3.2 3.3 3.4 Commodore Business Machines, Schematic, Service, Display Circuit for the PET 2001, hosted at File:Commodore PET 2001 Display Circuit Schematic.pdf. CR19-CR22 rectifiers, reservoir C1, regulator VR1 producing +12 V, the +85 V boost and -30 V rails, flyback T2 and the +10 kV anode supply.
  4. ↑ 4.0 4.1 4.2 4.3 Commodore Business Machines, Display Assembly Component Cross Reference for the PET 2001, hosted at File:Commodore PET 2001 Display Assembly Parts List.pdf. Includes C1 at 4700 µF 25 V and regulator VR1, Commodore part 901527-01.
  5. ↑ 5.0 5.1 5.2 PET-Shack (P.S. Software House), PET 2001 schematic and data-sheet bundle, c. 1978, hosted at File:PET-Shack PET 2001 Bundle.pdf. Third-party. "PET console wiring" drawing: power switch, 1.8 A fuse, transformer with a 16.2 V AC winding to the video monitor and a 15.7 V AC centre-tapped winding to the logic board, 23,000 µF 15 V capacitor.
  6. ↑ Dan Fylstra, "User's Report: The PET 2001", BYTE vol. 3 no. 3, March 1978, pp. 114-127.
  7. ↑ 7.0 7.1 André Fachat, PET repairs—link(accessed 2026-10-01)
  8. ↑ 8.0 8.1 Dave Curran, Commodore PET 2001 Repair - Garbage screen with noise, July 2017—link(accessed 2026-10-01)
