IBM PS2 Hardware Interface Technical Reference (May 1988)
The IBM Personal System/2 Hardware Interface Technical Reference is IBM's 625-page family-wide interface reference for the Micro Channel PS/2 models, First Edition, May 1988. The preface describes it as the manual for functions and architecture common to several PS/2 models, to be used with the model-specific technical references and the PS/2 and PC BIOS Interface Technical Reference. In it, Type 1 means the initial hardware design level of a function, and Type 2, Type 3 and so on the later levels (preface, p. ii).
Contents
Each section has its own contents, page numbering and index. PDF page numbers of each section's contents page:
Section PDF page
Micro Channel Architecture: channel definition, signal descriptions and connectors for the 16-bit, 32-bit, matched-memory and auxiliary video extension sections, bus ownership and arbitration, channel support, level-sensitive interrupt sharing, and critical timing (transfer, DMA, arbitration and configuration cycles) 8
Programmable Option Select: adapter setup, configuration utilities and adapter description files 84
Micro Channel Adapter Design: dimensions, power requirements and design guidelines 110
Microprocessors and Instruction Sets 138
Direct Memory Access Controller (Type 1) 246
Interrupt Controller (Type 1) 260
System Timers (Type 1) 276
Diskette Drive Controller (Type 1) 296
Keyboard and Auxiliary Device Controller 332
Serial Port Controller (Types 1 and 2) 350
Parallel Port Controller (Type 1) 378
Video Subsystem (Type 1), the VGA 388
Keyboards (101- and 102-Key) 506
Characters and Keystrokes 564
Power Supply (Types 1 and 2) 576
Power Supply (Type 3) 584
Compatibility 590
Bibliography 622
It is a programming and interface reference, not a service manual: no FRUs, removal procedures, symptom index, schematics or component values. BIOS is in the separate BIOS Interface Technical Reference. It predates XGA, so video is the VGA only. By October 1990 IBM had divided this material into the Architectures and Common Interfaces volumes.
What it settles
The power supply sections define three DC outputs, +5, +12 and −12 V, for the Micro Channel supplies of Types 1, 2 and 3. A short on any output, or an internal overvoltage before any output exceeds 130 % of nominal, latches all outputs off; the supply restarts only after the fault is removed and the power switch has been off for at least ten seconds (PDF pp. 579 and 587). The Type 1 supply plugs into the system board through a 50-pin card-edge connector, the Type 2 through a 15-pin connector with two 4-pin fixed disk connectors, and the Type 3 through a 12-pin connector (J7) and a 6-pin connector (J14) (PDF pp. 580-581 and 588).
Pages that cite this document
Download: IBM PS2 Hardware Interface Technical Reference May88.pdf
