IBM Proprinter Guide to Operations (First Edition, April 1985)
The IBM Proprinter Guide to Operations, First Edition (April 1985), part number 6328945, is the owner's manual for the original IBM Proprinter (4201-001). The PDF has 200 pages. It is a user book; its related-publications page sends the reader to the IBM Proprinter Technical Reference for technical detail and the IBM Proprinter Hardware Maintenance and Service for service.
Its front-matter DANGER notice reads: "Serious shock hazards exist within the main cover of your printer. Do not remove this cover. For service information refer to the Proprinter Hardware Maintenance and Service."
Contents
[edit | edit source]Page numbers are the book's own.
| Section | Subjects | Page |
| 1. Introduction | printer description, dot-addressable graphics, operator panel, types of printing, user-designed characters, near-letter-quality printing, paper feeding, built-in test, print modes, parts of the printer | 1-1 |
| 2. How to Set Up Your Printer | setup requirements, interface and printer cable, ribbon cartridge, test sheet, power cord, printer checkout and self-test, connecting the cable | 2-1 |
| 3. How to Operate Your Printer | switching on, lights, control keys, paper cover and forms guide, paper advance knob, paper release and forms thickness levers, cut and continuous forms, top of form, cleaning | 3-1 |
| 4. Printer Control Codes and Escape Sequences | control codes, escape sequences, mixing print modes, character set charts | 4-1 |
| 5. Problem Determination Procedures | user checks and the operator-panel light charts | 5-1 |
| 6. How to Change the Switch Settings | 6-1 | |
| 7. How to Move Your Printer | 7-1 | |
| Appendices | A what to do when the printer needs service; B parallel interface; C replacement ribbons; D factory-set options | A-1 to D-1 |
Useful to a repairer
[edit | edit source]- Self-test (p. 2-18): hold the Line Feed key while switching on and release it when printing starts. The printer repeats a rolling character pattern until it is switched off or runs out of paper; press Online to stop it at the end of a line (p. 2-20). This tests the printer without a host.
- Light charts (section 5): Paper Out and Ready flashing alternately means a paper or ribbon jam; IBM's user steps are to remove the ribbon, look for paper dust or scraps below the forms thickness lever, and rerun the self-test.
- IBM warns (p. 2-19) that setting the forms thickness lever lower than needed can damage the print head and ribbon.
- Replacement ribbon: IBM part 6328829, black (Appendix C).
[edit | edit source]There are no FRU part numbers, service procedures, adjustments, schematics or component values. For the service side of the later Proprinter models see IBM Proprinter 420X Service Information and Parts Catalog.
Download: IBM Proprinter Guide to Operations First Edition Apr85.pdf
