Improved Power Macintosh Computers Developer Note
Improved Power Macintosh Computers is Apple Computer's developer note dated 4/23/96 (Developer Press, © Apple Computer, Inc. 1996), 14 PDF pages. It is a delta guide: it lists only what changed in the Power Macintosh 7200/100, 7200/120, 7600/120, 8500/132, 8500/150 and 9500/150 against the earlier models, and refers back to the full developer notes for everything else.
Contents
[edit | edit source]With printed page numbers, all in Chapter 1, Delta Guide:
- Summary of new features (p. 2)
- Processor types and speeds (p. 2), Table 1-1
- Second-level cache, hard disk sizes, Macintosh System 7.5.3, configurations (p. 3)
- Compatibility and machine identification (p. 4)
- RAM DIMM dimensions (p. 5)
What it settles
[edit | edit source]- Processor and bus speeds of each model (Table 1-1, p. 3): 7200/100 at 100 MHz on a 50 MHz bus; 7200/120 and 7600/120 at 120 MHz on 40 MHz; 8500/132 at 132 MHz on 44 MHz; 8500/150 and 9500/150 at 150 MHz on 50 MHz.
- The improved 7500 is named the 7600 because its processor changed to a PowerPC 604 (p. 2).
- The note lists a 7200/100 that Apple's 7200 Service Source does not; Power Macintosh 7200 records the difference.
[edit | edit source]No architecture, connector or expansion detail beyond the changes; those are in Power Macintosh 7200 Computer Developer Note, Power Macintosh 7500 and 8500 Computers Developer Note and Power Macintosh 9500 Computers Developer Note. No service information.
Pages that cite this document
[edit | edit source]- Power Macintosh 7200: models and bus speeds, Tables 1-1 and 1-2
- Power Macintosh 7500: the 7600 naming, p. 2
- Power Macintosh 7600: 7600/120 processor, bus and configuration
- Power Macintosh 8500: 8500/132 and 8500/150 bus speeds
- Power Macintosh 9500: 9500/150 speed, cache and display card
Download: Improved Power Macintosh Computers Developer Note (1996).pdf
