Laserwriter 8.0 Driver 1993
Installing and Using the LaserWriter 8.0 Driver is Apple's 1993 software update guide, 42 pages. It is a software document, not a hardware one.
Contents, with the guide's own page numbers
  • Installing and Using the LaserWriter 8.0 Driver (p. 1), When to refer to this update guide (p. 1), Before you install LaserWriter 8.0 (p. 2), Protecting your disks (p. 2), Installing the printer software on your Macintosh (p. 3), Installing all the printer software (p. 4), Custom installing the printer software (p. 6)
  • Selecting and setting up the printer (p. 9), Setting up the printer driver automatically (p. 10), Setting up the printer driver manually (p. 11), Configuring the driver to use custom settings
  • Printing documents (p. 19), Printing a document with an automatic cover page (p. 20), Printing colour or greyscale documents (p. 21), Printing a report of PostScript errors (p. 22), Printing a document with FinePrint or PhotoGrade (p. 23), Printing to a file (p. 24), Turning automatic tray switching on or off (p. 27), Printing at 300 or 600 dpi (p. 28)
  • LaserWriter 8.0 PPD Files (p. 31)
Printing a report of PostScript errors is the item a repairer would want: it turns a silent failure to print into a message, and distinguishes a software or font problem from a printer fault.
Nothing about the hardware at all. No service procedures, no parts, no schematics, no voltages, no component values, no symptom charts. It should never be cited for a hardware figure.
Pages that cite this document
Download: LaserWriter 8.0 Driver 1993.pdf
