MC68030 Enhanced 32-Bit Microprocessor User's Manual Third Edition 1990
The MC68030 Enhanced 32-Bit Microprocessor User's Manual is Motorola's reference manual for the MC68030 processor, published for Motorola by Prentice Hall, Englewood Cliffs, New Jersey. The hosted copy is the Third Edition, © 1990 Motorola, Inc., ISBN 0-13-566423-3; it has 608 PDF pages and is paginated by section.[1]
The MC68030 is the processor in several Macintosh models, among them the Macintosh SE/30, Macintosh IIci and Macintosh Classic II. The manual is the manufacturer's source for the chip's pinout, supply pins and maximum ratings.
Contents
Sixteen sections: 1 Introduction; 2 Data Organization and Addressing Capabilities; 3 Instruction Set Summary; 4 Processing States; 5 Signal Description; 6 On-Chip Cache Memories; 7 Bus Operation; 8 Exception Processing; 9 Memory Management Unit; 10 Coprocessor Interface Description; 11 Instruction Execution Timing; 12 Applications Information; 13 Electrical Characteristics; 14 Ordering Information and Mechanical Data; M68000 Family Summary; Index.[1]
Maximum ratings and thermal data
MC68030 maximum ratings (section 13.1)
Rating Symbol Value
Supply voltage VCC −0.3 to +7.0 V
Input voltage Vin −0.5 to +7.0 V
Operating temperature TA 0 to 70 °C
Storage temperature Tstg −55 to 150 °C
[1]
A footnote to the supply-voltage rating reads: "A continuous clock must be supplied to the MC68030 when it is powered up." The thermal resistance of the ceramic PGA package is given as 30 °C/W junction to ambient and 15 °C/W junction to case, both marked as estimates.[1]
Supply pins and decoupling
Table 12-7 groups the VCC and GND pins by the circuits they feed:[1]
MC68030 VCC and GND pin assignments (Table 12-7)
Pin group VCC GND
Address bus C6, D10 C5, C7, C9, E11
Data bus L6, K10 J11, L9, L7, L5
ECS, SIZx, DS, AS, DBEN, CBREQ, R/W K4 J3
FC0-FC2, RMC, OCS, CIOUT, BG D4 E3
Internal logic, RESET, STATUS, REFILL, misc. H3, F2, F11, H11 L8, G3, F3, G11
Motorola suggests a combination of low-, middle- and high-frequency capacitors placed as close to the MC68030 as possible, for example 10 µF, 0.1 µF and 330 pF in parallel, and the same treatment for the other VLSI devices in the system. It warns that a poor connection between the processor's supply pins and the board's power planes results in increased assertion delays on external signals, reduced noise margins and potential errors in internal logic.[1]
Ordering information
Standard MC68030 parts (section 14.1)
Package Frequency (MHz) Temperature Order number
Pin grid array (RC suffix) 20.0 0-70 °C MC68030RC20
Pin grid array (RC suffix) 25.0 0-70 °C MC68030RC25
Pin grid array (RC suffix) 33.33 0-70 °C MC68030RC33
Ceramic surface mount (FE suffix) 20.0 0-70 °C MC68030FE20
Ceramic surface mount (FE suffix) 25.0 0-70 °C MC68030FE25
Ceramic surface mount (FE suffix) 33.33 0-70 °C MC68030FE33
[1]
Section 13 states that the DC electrical characteristics, power figures and AC timing specifications are in a separate Motorola document, MC68030EC/D, MC68030 Electrical Specifications, which the wiki does not hold. So this manual has no supply current, logic levels or setup and hold times.[1] It also has nothing specific to any computer.
Download: MC68030 Users Manual 3rd Edition 1990.pdf (20 MB)
  1. ↑ 1.0 1.1 1.2 1.3 1.4 1.5 1.6 1.7 Motorola, MC68030 Enhanced 32-Bit Microprocessor User's Manual, Third Edition, Prentice Hall, 1990, ISBN 0-13-566423-3, MC68030 Users Manual 3rd Edition 1990.pdf. Title and copyright pages (PDF pp. 3-4); Table 12-7 and decoupling, p. 12-46; Section 13, p. 13-1; Section 14.1, p. 14-1.
