Macintosh 128K/512K General Maintenance
The Macintosh 128K and Macintosh 512K have no fan: the power/sweep board behind the CRT runs hot and relies on convection through the case vents.[1] Most maintenance on these machines is on that board, its connectors and the PRAM battery, and every job inside the case starts with discharging the CRT. Capacitor work is covered on Macintosh 128K/512K Capacitor Replacement Guide and fault-finding on Macintosh 128K/512K Troubleshooting.
Safety
[edit | edit source]The CRT holds about 12,000 V after the machine is unplugged. Apple's procedure discharges it with a CRT discharge tool clipped to the metal ground lug, repeated to be sure; discharging to anything else can damage the logic board. Follow CRT Discharge Procedure.[2] |
Apple's rules for working on compact Macintoshes include: do not work alone; remove jewellery; wear safety goggles, because a damaged CRT can implode; keep one hand behind your back when working on a live machine; and never wear a grounding wrist strap, or work on a grounded mat, while the machine is plugged in, while discharging the CRT or while making live adjustments.[2] The Service Source repeats that a wrist strap must not be worn until the CRT has been discharged.[3]
Opening the case
[edit | edit source]Apple's take-apart sequence is: remove the battery compartment cover and the programmer's (reset/interrupt) switch if fitted; remove the four case screws with a long Torx screwdriver; ease the rear housing off with a case-splitting tool; then remove the RFI shield. The edges of the metal chassis can be sharp. The power/sweep board and logic board come out only after the CRT has been discharged, and the power/sweep board also needs the anode cap removed.[4]
Cleaning
[edit | edit source]With the machine unplugged and the CRT discharged, clear dust from the vent slots and from the boards, and keep the top and rear vents unobstructed in use. Do not rest anything on the case. For yellowed plastic see Retrobrite.
PRAM battery
[edit | edit source]The 128K and 512K both have a PRAM battery: Apple's specification gives "CMOS custom chip with 4.5 V, user-replaceable battery backup".[5] It is an alkaline cell, Apple part 742-0003, listed on Apple's support site as type 523.[6][7] It sits behind a door on the back of the case, in a holder on the power/sweep board.[4] Because it is alkaline, not lithium, its leakage is cleaned up differently from the lithium cells in later Macs; see Battery Explosion, Capacitor or Corrosion Damage. Apple gives no replacement interval or replace-below voltage for it. Take the battery out of any machine going into storage.
Voltage check
[edit | edit source]Apple says to verify the supply voltages whenever the logic board or the power/sweep board is replaced.[8] The check is made at the external drive port with voltage test cable 077-0135, with the machine running: the orange (+12 V) lead must read 11.90-12.75 V and the red (+5 V) lead 4.85-5.15 V. If they are out of tolerance, the regulator on the power/sweep board is adjusted with a plastic alignment tool, +12 V first; if both cannot be brought into tolerance, Apple replaces the board. Keep the rubber hoods on the test-cable plugs, because shorting them together damages the Macintosh. Use a mirror to watch the screen rather than reaching round the machine.[8][9]
The adjustment is trimmer R56, and it regulates the +12 V rail; the other rails follow it. If +5 V reads low because of a dirty connector, turning R56 to correct it pushes +12 V over specification. Thomas Lee recommends cleaning the contacts of connector J4 (the cable to the logic board) before adjusting anything.[1] The full procedure is on the capacitor replacement guide.
Connectors and solder joints
[edit | edit source]Thomas Lee names cracked solder joints at the four-pin yoke connector J1 on the power/sweep board as the commonest fault on the board: they cause an intermittent, wobbly, narrow or missing picture, or a single vertical line, often changing when the case is tapped. He reflows the J1 pins with the connector halves mated, so the heat does not distort the plastic.[1] Contact problems at J4 cause the "boots, bongs, resets" loop described on Macintosh 128K/512K Troubleshooting.[1]
Floppy drive
[edit | edit source]The 128K and 512K use a single-sided 400K drive, Apple part 661-76156 (mechanism).[6] Apple's symptom charts give these first steps:[10][11]
- A disk will not eject: press Shift-Command-1 (internal drive) or Shift-Command-2 (external), or choose Eject from the File menu; failing that, push a straightened paper clip into the hole beside the drive slot.
- A disk cannot be inserted all the way: switch off, then hold the mouse button down while switching on, so that the eject cycle completes.
- A 400K drive will not boot: if the logic board has Rev. A ROMs and the drive's stepper motor has serial number F518 or higher, fit the Rev. B ROMs, 342-0220-B (ROM HI) at D5 and 342-0221-B (ROM LOW) at D8, notches towards the front.[12]
For cleaning and mechanical work on the drive itself see Macintosh Floppy Drive Maintenance and Floppy Drive Repair.
Programmer's switch
[edit | edit source]If the plastic programmer's (reset/interrupt) switch makes the Macintosh reset at random, Apple's cure is to remove it and file it down by about 1/16 in.[13]
Tools
[edit | edit source]Apple's procedures call for:[4][8][9]
- a long Torx screwdriver for the case screws, and a case-splitting tool
- a CRT discharge tool
- a voltmeter and voltage test cable 077-0135
- a plastic alignment tool for the voltage and video adjustments
- a mirror, to watch the screen while adjusting from behind
- an IC extractor for the ROMs
See also Recommended Tools.
Maintenance checklist
[edit | edit source]- Unplug the machine, remove the case and discharge the CRT to the ground lug.
- Remove the PRAM battery and check its compartment and holder for leakage.
- Inspect the power/sweep board for leaking or bulging capacitors, heat damage and cracked joints at J1; see Macintosh 128K/512K Capacitor Replacement Guide.
- Clean the contacts of the J4 cable between the boards.
- Clear dust from the boards and the vents.
- Reassemble, then check +12 V and +5 V at the external drive port and adjust only if they are out of tolerance.
[edit | edit source]- Macintosh 128K
- Macintosh 128K/512K Troubleshooting
- Macintosh 128K/512K Capacitor Replacement Guide
- Macintosh 128K/512K Service Source
- Apple Macintosh Service Guide Volume 1 1990
- CRT Discharge Procedure
- Sad Mac Error Codes
[edit | edit source]- ↑ 1.0 1.1 1.2 1.3 Thomas H. Lee, Classic Mac Repair Notes, revision of 31 May 2007 (©2000 Thomas H. Lee; not re-hosted here). https://archive.org/details/Classic_Mac_Repair_Notes Sections 4.1-4.2 (yoke connector J1, power-supply faults), 5.1 (voltage adjustment) and 7.4 (regulator and R56).
- ↑ 2.0 2.1 Apple Computer, Inc., Apple Service Guide: Macintosh Computers (1990), Safety, pp. 1-4 (PDF pp. 5-8). Hosted as File:APPLE MACINTOSH SERVICE GUIDE VOL1 1990.pdf; see Apple Macintosh Service Guide Volume 1 1990.
- ↑ Apple Computer, Inc., Macintosh (Service Source for the Macintosh 128K and 512K). Hosted as File:Macintosh 128k.512k.pdf; see Macintosh 128K/512K Service Source.
- ↑ 4.0 4.1 4.2 Macintosh Service Source, Take Apart, Cover, Power/Sweep Board and Logic Board, pp. 1-12 (PDF pp. 24-35).
- ↑ Macintosh Service Source, Specifications, Memory, p. 2 (PDF p. 6).
- ↑ 6.0 6.1 Apple Service Guide: Macintosh Computers (1990), Tab 1, Parts List, p. 5 (PDF p. 15).
- ↑ Apple, "Macintosh 128K: Technical Specifications", Apple Support. Retrieved 2026-09-30.
- ↑ 8.0 8.1 8.2 Macintosh Service Source, Adjustments, Voltage, pp. 1-6 (PDF pp. 61-66).
- ↑ 9.0 9.1 Apple Service Guide: Macintosh Computers (1990), Tab 1, Power/Sweep Voltage Adjustment, p. 7 (PDF p. 17).
- ↑ Apple Service Guide: Macintosh Computers (1990), Tab 1, Symptom/Cure Chart, pp. 11-13 (PDF pp. 21-23).
- ↑ Macintosh Service Source, Troubleshooting, Symptom Charts, pp. 3-4 (PDF pp. 16-17).
- ↑ Apple Service Guide: Macintosh Computers (1990), Tab 1, ROM Upgrade & ROM Compatibility, p. 16 (PDF p. 26).
- ↑ Macintosh Service Source, Troubleshooting, Symptom Charts, Miscellaneous, p. 9 (PDF p. 22).
