Macintosh LC 630 Troubleshooting
Troubleshooting the Macintosh LC 630 and related models (Quadra 630, Performa 630 series, LC 630 DOS Compatible) requires understanding their shared architecture. All variants use the same logic board (820-0524) with minor configuration differences. This guide covers common issues and diagnostic procedures.
Before diagnosing component failures, verify:
  • Power cable securely connected
  • Power outlet functional (test with another device)
  • Power switch on rear of unit in ON position
  • Monitor connected and powered on separately
  • Keyboard and mouse connected to ADB port
Power Supply Voltages
  • +5V rail: 4.85V – 5.15V
  • +12V rail: 11.9V – 12.7V
  • -12V rail: Within 10% of nominal
No Power (Unit Dead)
No Power Diagnostics
No LED, no sound, completely dead Blown fuse in power supply Open PSU, check and replace fuse if blown
No LED, no sound Failed power supply Test PSU outputs, replace if necessary
No LED, no sound Power switch failure Bypass switch to test; replace if faulty
Faint click when power button pressed Shorted component on logic board Disconnect drives and cards; test bare board
Power LED flashes briefly then dies Capacitor failure Inspect for leaking capacitors; recap board
Intermittent power Loose power connector Reseat internal power cable connections
Power Supply Testing
  1. Disconnect power and open case
  2. Slide out motherboard drawer for access
  3. Reconnect power with drawer extended (careful!)
  4. Measure voltages at logic board connector
  5. If voltages absent or incorrect, PSU requires service
  6. Check PSU capacitors for bulging or leakage
Chime but No Video
Startup Chime Without Video
Normal chime, no video Monitor connection issue Check DA-15 video cable; try different monitor
Normal chime, no video Video DRAM failure Logic board repair required (DRAM soldered)
Normal chime, black screen Resolution mismatch Zap PRAM (Cmd-Opt-P-R at startup)
Normal chime, garbled display Video DRAM failure Test with external video card if available
Chime, monitor shows "No Signal" Video output failure Check video port for bent pins; test board
Chime, dim or flickering image DRAM timing issues Recap logic board; check capacitors near video
Video System Notes
The LC 630 uses 1 MB DRAM shared with system operations:
  • Video memory cannot be upgraded
  • DRAM failure requires board-level repair
  • Some video issues caused by capacitor failure
Sad Mac Errors
Sad Mac errors display a code indicating the failure type. See Sad Mac Error Codes for complete reference.
Common LC 630 Sad Mac Codes
Code Meaning Resolution
0000000F 00000001 ROM test failure Clean ROM if socketed; logic board failure likely
0000000F 00000002 Memory (RAM) test exception Reseat or replace SIMMs; check soldered RAM
0000000F 00000003 Memory (RAM) test failure Test with known-good SIMM; check SIMM socket
0000000F 00000005 Bus error Check for bent pins; reseat all socketed ICs
0000000F 0000000E NuBus error Remove expansion cards; test bare board
0000000F 0000000F Data bus test failure Logic board failure; recap may help
Intermittent Operation Issues
Random freezes after warmup Thermal issues (passive cooling) Clean vents; check for dust accumulation
Crashes after 10-30 minutes Failing capacitors Inspect and recap logic board
Freezes during disk access IDE cable issue Check IDE cable connections; try different cable
Intermittent startup Oxidized CPU socket Reseat 68040; clean socket with DeoxIT
Freezes with extensions enabled Software conflict Boot with extensions off (hold Shift)
System hangs at startup Corrupted system software Reinstall System 7.5.3 or later
Random resets PRAM battery failure Check and replace 4.5V alkaline battery
RAM and Memory Issues
Memory Problems
Less RAM reported than installed Incompatible SIMM Use 72-pin, 80ns, non-parity SIMMs
System won't boot with new SIMM Wrong SIMM type Check SIMM compatibility; use single-sided if slot 2
4 MB reported with SIMM installed SIMM not seated Reseat SIMM firmly in socket
Sad Mac RAM error Defective SIMM Test with known-good SIMM
System unstable with 64+ MB SIMM Unsupported size 64 MB requires single-banked SIMM specifically
SIMM Slot Notes
  • Single-slot models: Accept SIMMs up to 32 MB (64 MB unofficial)
  • Dual-slot models (DOS Compatible): Slot 2 requires single-sided SIMMs only
  • Slot 2 maximum: 16 MB (1, 4, or 16 MB single-sided)
IDE Hard Drive Problems
IDE Storage Issues
Drive not recognized Old system software Update to System 7.5.2+; use Drive Setup 1.0.3+
Drive clicks but won't mount Drive failure Try different IDE drive
"This disk is unreadable" Needs initialization Use Apple Drive Setup to format
Drive recognized but won't boot No System Folder Reinstall Mac OS; verify blessed System Folder
Only partial capacity recognized 8 GB limit IDE controller limitation; use drive ≤8 GB or partition
Single device only Normal LC 630 does not support master/slave configuration
IDE Compatibility Notes
  • First desktop Mac with IDE—driver support varies
  • System 7.1.2 requires third-party utilities for some drives
  • PIO Mode 3 maximum (11.1 MB/s theoretical)
  • Use Apple Drive Setup 1.0.3 or later for best compatibility
Floppy Drive Issues
Floppy Drive Diagnostics
Disk won't eject Mechanical failure Manual eject with straightened paperclip
Disks not recognized Dirty heads Clean with head cleaning disk
Read errors on all disks Worn heads Replace floppy drive mechanism
Drive accepts disk but won't read Misaligned heads Professional realignment or drive replacement
Disk icon with X at startup No bootable disk Insert system disk or check HD
CD-ROM Drive Issues
CD-ROM Diagnostics
Drive tray won't open Mechanical failure Use emergency eject hole with paperclip
CDs not recognized Dirty lens Clean with CD lens cleaner
Audio CDs work, data CDs fail Software issue Verify CD-ROM drivers installed
SCSI ID conflict Incorrect configuration Check CD-ROM SCSI ID (typically 3)
Intermittent recognition SCSI termination Verify proper SCSI chain termination
CD-ROM Notes
The internal CD-ROM uses SCSI, not IDE:
  • Apple CD 300i Plus (2X speed)
  • SCSI ID typically set to 3
  • External SCSI devices need proper termination
DOS Compatibility Card Issues
For LC 630 DOS Compatible and Performa 640 DOS Compatible models:
DOS Card Troubleshooting
DOS mode won't start Card not seated Reseat card in CPU socket and PDS slot
Blue screen in DOS mode RAM issue Check DOS card SIMM if installed
No sound in DOS mode Driver issue Reinstall SoundBlaster drivers
Joystick not working Port issue Check joystick port connection on card
Windows 95 unstable CPU upgrade issue Some 486 upgrades incompatible with Win95
"No PC card found" in PC Setup Connection failure Remove and reseat entire DOS card assembly
Mac freezes when switching to PC Software conflict Update PC Setup to latest version
PC mode shows wrong resolution Configuration issue Adjust in PC Setup control panel
DOS Card Seating Procedure
  1. Slide out motherboard drawer
  2. Disconnect DOS card from PDS slot first
  3. Carefully lift lower board from CPU socket
  4. Inspect contacts for corrosion
  5. Clean with DeoxIT if necessary
  6. Reinstall lower board in CPU socket
  7. Reconnect upper board to PDS slot
  8. Verify joystick port alignment
CPU Upgrade Compatibility
If you've upgraded the 486 processor:
Cyrix 5x86-100GP Recommended; stable
Intel 486DX4-100 Windows 95 may be unstable
AMD 5x86-133 Requires voltage interposer; may be unstable
Capacitor Failure Symptoms
Capacitor-Related Failures
Symptom Typical Cause Resolution
Won't power on at all Failed power filtering caps Full recap of logic board
Powers on, no chime Audio circuit caps failed Recap; check AWACS chip
Intermittent crashes General capacitor degradation Full recap recommended
Brown residue on logic board Electrolyte leakage Clean thoroughly; recap immediately
Corrosion around caps Advanced leakage Clean with vinegar then IPA; repair traces if damaged
The LC 630 logic board contains 9 SMD electrolytic capacitors:
  • 3× 100µF 6.3V
  • 6× 47µF 16V
Refer to Macintosh LC 630 Capacitor Replacement Guide for specifications and procedures.
PRAM/NVRAM Issues
PRAM-Related Problems
Wrong date/time on each boot Dead PRAM battery Replace 4.5V alkaline battery
Wrong startup disk selected Corrupted PRAM Zap PRAM: Cmd-Opt-P-R at startup
Monitor settings not saved Dead battery or corrupt PRAM Replace battery; zap PRAM
System asks for time zone always Battery failure Replace 4.5V battery
Zapping PRAM
  1. Restart the Mac
  2. Immediately hold Command-Option-P-R
  3. Wait for second startup chime
  4. Release keys
Software Compatibility
Supported System Software
Version Compatibility Notes
System 7.1.2 Minimum Requires Enabler 405
System 7.5.x Recommended Best 68K compatibility
Mac OS 7.6.1 Compatible Stable on 68040
Mac OS 8.0 Compatible Works but slower
Mac OS 8.1 Maximum Last supported version
Mac OS 8.5+ Not compatible Requires PowerPC
Software Notes
  • 68LC040 has no FPU—software requiring FPU will fail
  • Full 68040 upgrade adds hardware FPU support
  • Some games and CAD software require FPU
  • SoftwareFPU can emulate FPU in some cases
Quick Diagnostic Checklist
  1. Check power cable and outlet
  2. Verify monitor connection and power
  3. Listen for startup chime
  4. Check for Sad Mac error code
  5. Zap PRAM (Cmd-Opt-P-R)
  6. Boot with extensions off (hold Shift)
  7. Reseat RAM SIMMs
  8. Reseat expansion cards
  9. Inspect for capacitor leakage
  10. Test with known-good peripherals
