Macintosh Performa 5200CD Troubleshooting
Troubleshooting is essential for diagnosing and resolving issues with your Macintosh Performa 5200CD. This guide covers the 5200CD and all related variants including the Performa 5200, 5210CD, 5215CD, 5220CD, and Power Macintosh 5200/75 LC.
  • Verify the power cord is securely connected at both ends
  • Test the wall outlet with another device
  • Check for visible damage to the power cord
  • Listen for any sounds when pressing the power button
  • Check that the brightness control is not set to minimum
Target Voltage Levels:
  • +5V: 4.85V โ€“ 5.15V
  • +12V: 11.9V โ€“ 12.7V
No response, no LED Power cord, outlet, or fuse Test outlet, inspect cord, check internal fuse
Ticking or clicking sound Short circuit or failed capacitor Inspect analog board for failed capacitors, check for shorts
Powers on briefly then dies Power supply failure Check capacitors in power supply section, verify voltage output
LED on but no startup Logic board issue Reseat RAM, check for corrosion, test with known-good RAM
Intermittent power Bad solder joints Reflow solder on analog board power connectors
Power Supply Testing
  1. Disconnect all external devices except keyboard and mouse
  2. Remove internal expansion cards
  3. Test power supply voltages at the logic board connector
  4. If voltages are out of spec, inspect and replace failed capacitors
Chime but No Video
Video Issues After Successful Chime
Chime, no video, drive activity CRT or analog board failure Check CRT neck board, verify flyback operation
Chime, dim or faded display Failing CRT or weak flyback Test CRT, check flyback transformer output
Chime, scrambled colors Video RAM or color shift issue Known issue in early units โ€“ may require logic board repair
Chime, display geometry problems Deflection circuit failure Check yoke connections, inspect analog board
Chime, horizontal or vertical line only Deflection circuit failure Inspect analog board, check yoke connector solder joints
Flyback Transformer Check
The flyback transformer provides high voltage to the CRT. Symptoms of failure include:
  • No high voltage (dark CRT, no static discharge)
  • Clicking or arcing sounds
  • Burning smell
Warning: The flyback and CRT retain lethal voltages even when unpowered. Discharge the CRT before any inspection.
System Instability Issues
Random freezes Known 5200 design flaw Install Open Transport 1.2+, add SCSI terminator, check capacitors
Freeze with color shift Logic board defect Apple Repair Extension Program (if still available) or board-level repair
Freezes under heavy use Overheating or power supply Clean vents, check fan operation, verify PSU voltages
Freezes on network access Network stability issue Install Open Transport 1.2+, connect printer to modem port if no modem installed
Freeze after sleep PRAM battery or software issue Replace PRAM battery, reset PRAM, update system software
Sad Mac Error Codes
See the Sad Mac Error Codes page for a complete reference.
Common Sad Mac Codes for Performa 5200 Series
Code Meaning Action
0000000F 00000001 ROM checksum error Replace or reseat ROM (logic board issue)
0000000F 00000002 Memory test failure Reseat or replace RAM SIMMs
0000000F 00000003 Memory addressing error Test SIMMs individually, check SIMM socket
0000000F 0000000E Data bus test failure Logic board failure
0000000F 0000000F Address bus test failure Logic board failure
Floppy Drive Issues
Floppy Drive Problems
Disk not recognized Dirty heads or worn drive Clean heads with cleaning disk, test with known-good drive
Disk eject failures Mechanical issue Lubricate eject mechanism, check for debris
Read/write errors Head alignment or media Try different disks, clean heads, may need drive replacement
No eject on startup Stuck mechanism Manual paper clip eject, inspect mechanism
CD-ROM Drive Issues
CD-ROM Drive Problems
CD not recognized Dirty lens or failed drive Clean lens with appropriate cleaner, test with known-good drive
Slow reading or skipping Dirty or worn lens Clean lens, check for media damage
Tray won't open Mechanical failure Manual eject with paper clip, check tray mechanism
Drive makes grinding sounds Mechanical failure Drive replacement likely needed
Hard Drive Issues
IDE Hard Drive Problems
Drive not recognized Cable, drive, or HD Setup version Check IDE cable, try Drive Setup 1.0.3 or later
Clicking or grinding Drive failure Back up immediately if possible, replace drive
Slow performance Outdated driver Use FWB HD Toolkit or updated Apple driver
Boot failure, question mark Corrupt system or drive failure Boot from CD, run Disk First Aid, reinstall system
Note: Apple HD SC Setup versions prior to System 7.5.2 may not recognize newer IDE drives. Use Drive Setup 1.0.3 or later.
SCSI Problems
External SCSI Issues
SCSI device not seen Termination or ID conflict Verify termination at end of chain, check unique SCSI IDs
System freeze with SCSI Termination power issue Add active terminator, SCSI devices must provide termination power
Intermittent SCSI errors Cable quality or length Use high-quality cables, keep total length under 6 meters
Note: The Performa 5200 does not provide SCSI termination power. External devices or an active terminator must supply it.
Audio Problems
Sound Issues
No sound output Volume setting or speaker failure Check volume in Control Panel, test with headphones
Distorted sound Failed capacitors or speaker Inspect analog board capacitors, test speakers
8-bit sound quality Hardware revision Check for capacitor C255 on logic board; if present, unit has 8-bit audio
