Macintosh Performa 5200CD General Maintenance
Proper maintenance is essential to extending the lifespan and ensuring reliable operation of your Macintosh Performa 5200CD. This guide covers the 5200CD and all related variants including the Performa 5200, 5210CD, 5215CD, 5220CD, and Power Macintosh 5200/75 LC.
Regular Cleaning
Internal Cleaning
  • Power off and unplug the computer; allow capacitors to discharge for at least 15 minutes
  • Discharge the CRT before working inside – see CRT Discharge Procedure
  • Use compressed air to remove dust from the logic board, analog board, and power supply
  • Pay attention to ventilation areas and fan assemblies
  • Clean the CD-ROM drive lens with a lint-free cloth and isopropyl alcohol
  • Inspect all cable connections for corrosion or looseness
External and CRT Cleaning
  • Clean the exterior case with a damp cloth and mild soap
  • Clean the CRT screen with a soft, lint-free cloth
  • Use plastic-safe cleaners only; avoid ammonia-based products
  • Do not spray liquids directly on the screen or case
Keyboard and Mouse Cleaning
  • Remove keycaps and clean with isopropyl alcohol
  • Clean the keyboard case with a damp cloth
  • For ball mice: remove the ball cover, clean the ball and rollers
  • For optical mice: clean the sensor lens
PRAM Battery Handling
The Performa 5200CD uses a 4.5V alkaline PRAM battery.
Best Practices
  • Check battery voltage annually; replace if below 4.2V
  • Replace the battery every 3–5 years as preventive maintenance
  • Always use the correct battery type (4.5V alkaline)
  • Note system settings before replacement; PRAM will reset
Cleaning Battery Leakage
  • Wear gloves when handling leaking batteries
  • Neutralize alkaline leakage with white vinegar, then clean with isopropyl alcohol
  • Inspect nearby components and traces for corrosion damage
  • Use a fiberglass pen or fine abrasive to clean corroded traces
  • Apply conformal coating to repaired areas
Connector and Socket Corrosion
Key Areas to Check
  • SIMM sockets – RAM slot contacts can oxidize
  • LC PDS slot – Check for bent or corroded pins
  • Serial port connectors – DIN-8 connectors prone to oxidation
  • SCSI connector – DB-25 pins can corrode
  • Internal ribbon cables – Check IDE and floppy cables
  • Expansion card connectors – Communications, TV, video slots
Use DeoxIT D5 or similar contact cleaner on oxidized connections. For heavy corrosion, carefully scrape with a fiberglass pen and reapply contact cleaner.
Common Failure Points
Analog Board Issues
The analog board contains the power supply and CRT deflection circuits. Common problems include:
  • Cracked solder joints – Resolder connections around the flyback transformer, deflection yoke connector, and large capacitors
  • Failed capacitors – Electrolytic capacitors in the power supply section fail over time
  • Flyback transformer failure – Can cause no video or clicking sounds
Apple released a "Revision B" analog board during production; parts are not interchangeable between revisions.
Power Supply Problems
The internal power supply may exhibit:
  • Clicking or ticking – Often indicates a short circuit or failed component
  • Low output voltage – Check capacitors in the primary and secondary stages
  • No power – Test fuse, power switch, and incoming AC
Logic Board Socket Oxidation
  • Clean SIMM sockets with contact cleaner
  • Reseat all socketed components including the CPU card (if present)
  • Check the L2 cache slot if an L2 cache card is installed
PRAM Battery Damage
A leaking PRAM battery can corrode nearby traces and components. Inspect the battery area annually and replace batteries proactively.
Voltage Adjustment and Power Checks
Measure power supply voltages with the system under load (booted to desktop):
Rail Target Acceptable Range
+5V 5.00V 4.85V – 5.15V
+12V 12.00V 11.9V – 12.7V
Adjustments may be possible via potentiometers on the analog board. Consult the Apple Service Source documentation for your specific board revision.
Warning: The analog board contains hazardous voltages. Only qualified technicians should adjust or service the analog board.
Network Stability
The Performa 5200 series has known network instability issues. To improve stability:
  • Install Open Transport 1.2 or later (included with Mac OS 8)
  • Install a 25-pin SCSI terminator if no external SCSI devices are connected
  • If using a serial printer without a modem, connect the printer to the modem port
  • Consider a comm slot Ethernet card for reliable networking
