Macintosh Performa 5400 Capacitor Replacement Guide
The Macintosh Performa 5400 series has electrolytic capacitors on four boards: the logic board, the power supply board, the analogue/video board and the CRT video board on the neck of the tube. Apple's Service Source for the Power Macintosh/Performa 5400 and 5500 is a module-level manual: it gives part numbers for whole boards and no component lists, values or schematics.[1] Console5's Power Macintosh capacitor lists include the 5200/6200 logic board (820-0685-B) but no 5400, 5500 or 6400 board.[2] Read the value, voltage and size off each capacitor before ordering replacements.
Safety
[edit | edit source]This machine has a CRT that stays charged after it is unplugged, and a power supply and analogue board that run from mains voltage. Discharge the CRT and remove the anode cap before touching anything behind the rear EMI shield; see CRT Discharge Procedure. Apple lists "discharge the CRT" and "remove the anode cap" as preliminaries for its analogue board and CRT procedures, and warns against wearing an antistatic wrist strap until the CRT is discharged.[3][4] The large capacitors on the primary side of the power supply can also hold a charge; check them with a meter before handling the board.
The boards
[edit | edit source]The power supply, analogue/video board and CRT assembly are shared with the Performa 5200 and 5300, and the Rev. A and Rev. B versions differ. Identify the revision first: speakers built into the front bezel mean the original version, and speakers fixed to the sides of the metal chassis mean Rev. B.[1][5]
| Board | Platinum models | Graphite models (5400/180, 5420, 5420/180) | Also used in |
| Power supply | 661-0930 (Rev. A), 661-0331 (Rev. A with thermistor at CN13), 661-1117 (Rev. B, thermistor at CN9) | 661-1138 | Performa 5200, 5300; Power Macintosh 5500 |
| Analogue/video board assembly | 661-0928 (Rev. A), 661-1356 (Rev. B) | 661-1182 | Performa 5200, 5300; Power Macintosh 5500 |
| CRT assembly | 661-0952 (US), 661-0954 (southern hemisphere) | 661-0952, 661-0954 | Performa 5200, 5300 |
| Logic board | 661-1072 (120 MHz), 661-1327 (160 MHz), 661-1324 (180 MHz), 661-1330 (200 MHz) | 661-1072 (120 MHz), 661-1324 (180 MHz) | 5400 series only |
Apple says the three power supplies are not interchangeable and must be exchanged like for like, and that the Rev. A and Rev. B analogue and video boards are not interchangeable either.[5][3] Capacitor work on the 5200 and 5300 supply and analogue board therefore applies to the same boards in a 5400; see Macintosh Performa 5200CD Capacitor Replacement Guide.
Symptoms Apple sends to each board
[edit | edit source]Apple's symptom charts give the order in which it replaced modules. The board named first is the one to inspect first:[7]
| Symptom | Apple's order |
| Will not start | Logic board reset, then power supply, then logic board |
| Starts from the rear switch but not the keyboard; restarts after Shut Down | Analogue board (after trying a known-good keyboard) |
| No video, no sound, no drive activity | Power cord, then analogue board, then logic board |
| Smoke or smell | Analogue board, then power supply, then logic board |
| Clicking, chirping or thumping | Analogue board, then logic board |
| Screen black or too dark while sound and drives work | Adjustments, then analogue/video board, then power supply board, then CRT |
| Single horizontal or vertical line | Analogue/video board, then CRT |
| Distorted sound from both speakers | Analogue/video board |
| Crackling on sounds other than system beeps | Audio Volume Extension 1.1 or later, then logic board |
Procedure
[edit | edit source]- Unplug the machine. Remove the I/O door (two security screws) and pull out the logic board by its handle.[3]
- Remove the rear housing (three Torx screws each side, under the screw covers), the front bezel and the rear EMI shield.[3]
- Discharge the CRT and remove the anode cap (CRT Discharge Procedure).
- Photograph every connector and cable run. Apple's power-supply and analogue-board procedures give different cable locations for Rev. A and Rev. B.[3]
- Remove the power supply, and for the analogue board the video board and analogue shield as well.[3]
- Inspect each electrolytic for a domed or split top, a dark ring or crust on the board, or a loose, tilted body. Record the marking on every capacitor before removing any: capacitance, working voltage, temperature rating and diameter. See Capacitor Failure Symptoms.
- Fit replacements of the same capacitance and at least the same voltage and temperature rating, observing polarity (the stripe on an aluminium electrolytic marks the negative lead).
- Clean the pads and any electrolyte residue with isopropyl alcohol, and inspect the solder joints around the parts you changed.
- Reassemble, then run the monitor for 10 minutes and check the high-voltage setting (29.5 V DC ± 0.1 V at D713 or D703) and the cutoff and white balance. Apple calls for the high-voltage adjustment after replacing the CRT or deflection board, and for cutoff after replacing the CRT or deflection board or disturbing the screen control.[4] The procedures are on Macintosh Performa 5400 General Maintenance.
Clock battery
[edit | edit source]The clock battery is a 4.5 V alkaline pack on the logic board, which Apple replaces below 3.0 V.[8][9] Take it out while the logic board is on the bench. If it has leaked, neutralise the alkaline residue with dilute white vinegar before recapping the board; see Battery Explosion, Capacitor or Corrosion Damage.
[edit | edit source]- Macintosh Performa 5400
- Macintosh Performa 5400 General Maintenance
- Macintosh Performa 5400 Troubleshooting
- Macintosh Performa 5200CD Capacitor Replacement Guide
- CRT Discharge Procedure
- Capacitor Failure Symptoms
- Recommended Tools
[edit | edit source]- ↑ 1.0 1.1 Apple Computer, Power Macintosh/Performa 5000 Series (5400 and 5500) Service Source, 1997, Basics chapter: Rev. B (p. 2), Service Strategy ("module exchange and parts replacements", p. 13), CRT and Degauss Frame (p. 36). Hosted as File:Powermac.perf_5400.5500.pdf; see Power Macintosh/Performa 5000 Series Service Source.
- ↑ Power Macintosh, Console5 Tech Wiki—link(accessed 2026-09-30)
- ↑ 3.0 3.1 3.2 3.3 3.4 3.5 Apple Computer, Power Macintosh/Performa 5000 Series Service Source, 1997, Take Apart chapter: I/O Door (pp. 17–19), Logic Board (pp. 20–25), Rear Housing (pp. 30–33), Front Bezel (pp. 34–37), Rear EMI Shield (pp. 40–42), Power Supply, Original Version (pp. 59–70), Power Supply, Rev. B (pp. 71–74), Video Board (pp. 75–78), Analog Shield (pp. 79–81), Analog Board, Original Version (pp. 82–89), Analog Board, Rev. B (pp. 90–93). Hosted as File:Powermac.perf_5400.5500.pdf.
- ↑ 4.0 4.1 Apple Computer, Power Macintosh/Performa 5000 Series Service Source, 1997, Adjustments chapter: Geometry (pp. 7–23), Video (pp. 24–38), High Voltage (pp. 39–43). Hosted as File:Powermac.perf_5400.5500.pdf.
- ↑ 5.0 5.1 Apple Computer, Power Macintosh/Performa 5200 and 5300 Service Source, 1997, Exploded View, p. 1; Take Apart, Power Supply, Rev. A, p. 57. Hosted as File:Powermac.perf_5200.5300.pdf.
- ↑ Apple Computer, Power Macintosh/Performa 5000 Series Service Source, 1997, Exploded View (5400/5500, p. 1; Performa 5400/180, 5420, 5420/180, p. 1). Hosted as File:Powermac.perf_5400.5500.pdf.
- ↑ 7.0 7.1 Apple Computer, Power Macintosh/Performa 5000 Series Service Source, 1997, Troubleshooting chapter, Symptom Charts: System (pp. 3–4), Audio (pp. 5–6), Video (pp. 7–12), Miscellaneous (pp. 25–26). Hosted as File:Powermac.perf_5400.5500.pdf.
- ↑ Macintosh Performa 5400CD: Technical Specifications, Apple—link(accessed 2026-09-30) Battery type: 4.5 V alkaline.
- ↑ Apple Computer, Power Macintosh/Performa 5000 Series Service Source, 1997, Additional Procedures chapter, Battery Verification (pp. 1–2) and Battery Replacement (pp. 3–4). Hosted as File:Powermac.perf_5400.5500.pdf.
