Macintosh Performa 5400 Capacitor Replacement Guide
Replacing electrolytic capacitors (recapping) in your Macintosh Performa 5400 series computer is essential for long-term reliability. The Performa 5400 uses the Alchemy logic board, shared with the Power Macintosh 5400 and Performa 6400 series.
Capacitor Inspection
[edit | edit source]Signs that your Performa 5400 needs recapping:
- Bulging Tops – Capacitors with domed or swollen tops indicate internal failure
- Leaking Electrolyte – Brown or orange residue around capacitor base
- Corrosion or PCB Staining – Discoloration on the PCB near capacitors
- Audio distortion – Crackling, low volume, or missing audio
- Boot failures – Intermittent startup or random crashes
- Visual artifacts – Display anomalies caused by power rail instability
Macintosh Performa 5400 Capacitor List
[edit | edit source]Logic Board Capacitors
[edit | edit source]The Alchemy logic board uses primarily surface-mount electrolytic capacitors.
| Reference | Capacitance | Voltage | Type | Notes |
| C1 | 100µF | 16V | SMD Electrolytic | Audio section |
| C2 | 100µF | 16V | SMD Electrolytic | Audio section |
| C3 | 47µF | 16V | SMD Electrolytic | Power filtering |
| C4 | 47µF | 16V | SMD Electrolytic | Power filtering |
| C5 | 10µF | 16V | SMD Electrolytic | Decoupling |
| C6 | 10µF | 16V | SMD Electrolytic | Decoupling |
| C7 | 100µF | 10V | SMD Electrolytic | Power filtering |
| C8 | 100µF | 10V | SMD Electrolytic | Power filtering |
| C9 | 22µF | 16V | SMD Electrolytic | Audio section |
| C10 | 22µF | 16V | SMD Electrolytic | Audio section |
Note: Capacitor designations may vary. Always verify values before ordering replacements.
Power Supply Capacitors
[edit | edit source]The power supply contains larger through-hole electrolytic capacitors that may also need replacement:
| Capacitance | Voltage | Type | Quantity |
| 680µF | 200V | Radial | 2 |
| 1000µF | 25V | Radial | 2 |
| 470µF | 25V | Radial | 2 |
| 220µF | 25V | Radial | 2 |
| 100µF | 16V | Radial | 4 |
| 47µF | 50V | Radial | 2 |
| 10µF | 50V | Radial | 4 |
Warning: Power supply capacitors store dangerous voltages. Discharge fully before servicing.
[edit | edit source]- Discharge CRT – Follow the CRT Discharge Procedure before any internal work
- Remove Logic Board – Disconnect all cables and remove mounting screws
- Document Capacitor Positions – Photograph the board before removal
- Desolder Old Caps – Use a temperature-controlled iron (300–350°C) and desoldering braid or pump
- Clean Pads – Remove old solder and any leaked electrolyte with isopropyl alcohol
- Install Replacements – Observe correct polarity; negative stripe aligns with board marking
- Solder Securely – Use quality 60/40 or 63/37 leaded solder for best results
- Trim Leads – Cut flush to avoid shorts (through-hole only)
- Inspect Work – Check for solder bridges and cold joints
- Clean Board – Remove flux residue with isopropyl alcohol
Recommended Tools
[edit | edit source]- Temperature-controlled soldering iron (Hakko FX-888D or similar)
- Fine soldering tip (chisel or conical, 1–2mm)
- Desoldering pump or braid
- Fine leaded solder (0.5–0.8mm diameter)
- Isopropyl alcohol (90%+) and ESD-safe brush
- Multimeter with continuity function
- Safety glasses
- Anti-static wrist strap
Recommended Capacitor Types
[edit | edit source]For replacements, use quality brands:
- Nichicon – UPW, UHE, or UPJ series
- Panasonic – FR or FC series
- Rubycon – ZLH or YXF series
- United Chemi-Con – KZE or KY series
Avoid generic or unknown brand capacitors for reliability.
Voltage Checks After Recap
[edit | edit source]After recapping, verify power supply voltages:
- +5V rail: 4.85V – 5.15V
- +12V rail: 11.9V – 12.7V
- +3.3V rail: 3.2V – 3.4V
If voltages are out of spec, recheck your work and PSU capacitors.
Additional Tips
[edit | edit source]- Take photos before and after for reference
- Work in a well-ventilated area when soldering
- Don't overheat SMD pads – they can lift from the PCB
- Consider recapping the power supply at the same time as the logic board
- Test the system thoroughly after recapping before reassembly
