Module:Cs1 documentation support
Documentation for this module may be created at Module:Cs1 documentation support/doc
require('strict');
local getArgs = require ('Module:Arguments').getArgs;
local cfg = mw.loadData ('Module:Citation/CS1/Configuration'); -- load the configuration module
local whitelist = mw.loadData ('Module:Citation/CS1/Whitelist'); -- load the whitelist module
local exclusion_lists = { -- TODO: move these tables into a separate ~/data module and mw.loadData() it
['cite book'] = {
['agency'] = true,
['air-date'] = true,
['arxiv'] = true,
['biorxiv'] = true,
['citeseerx'] = true,
['class'] = true,
['conference'] = true,
['conference-format'] = true,
['conference-url'] = true,
['degree'] = true,
['department'] = true,
['display-interviewers'] = true,
['docket'] = true,
['episode'] = true,
['interviewer#'] = true,
['interviewer-first#'] = true,
['interviewer-link#'] = true,
['interviewer-mask#'] = true,
['ismn'] = true,
['issn'] = true,
['issue'] = true,
['jfm'] = true,
['journal'] = true,
['jstor'] = true,
['mailinglist'] = true,
['message-id'] = true,
['minutes'] = true,
['MR'] = true,
['network'] = true,
['number'] = true,
['RFC'] = true,
['script-journal'] = true,
['season'] = true,
['section'] = true,
['sections'] = true,
['series-link'] = true,
['series-number'] = true,
['series-separator'] = true,
['sheet'] = true,
['sheets'] = true,
['SSRN'] = true,
['station'] = true,
['time'] = true,
['time-caption'] = true,
['trans-article'] = true,
['trans-journal'] = true,
['transcript'] = true,
['transcript-format'] = true,
['transcript-url'] = true,
['ZBL'] = true,
['cite journal'] = {
['agency'] = true,
['book-title'] = true,
['chapter'] = true,
['chapter-format'] = true,
['chapter-url'] = true,
['chapter-url-access'] = true,
['class'] = true,
['contribution'] = true,
['contributor#'] = true,
['contributor-first#'] = true,
['contributor-link#'] = true,
['contributor-mask#'] = true,
['degree'] = true,
['docket'] = true,
['edition'] = true,
['editor#'] = true,
['editor-first#'] = true,
['editor-link#'] = true,
['editor-mask#'] = true,
['editors'] = true,
['encyclopedia'] = true,
['episode'] = true,
['ignore-isbn-error'] = true,
['isbn'] = true,
['ismn'] = true,
['LCCN'] = true,
['minutes'] = true,
['network'] = true,
['script-chapter'] = true,
['season'] = true,
['section'] = true,
['sheet'] = true,
['sheets'] = true,
['station'] = true,
['time'] = true,
--[[-------------------------< A D D _ T O _ L I S T >---------------------------------------------------------
adds code/name pair to code_list and name/code pair to name_list; code/name pairs in override_list replace those
taken from the MediaWiki list; these are marked with a superscripted dagger.
|script-<param>= lang codes always use override names so dagger is omitted
local function add_to_list (code_list, name_list, override_list, code, name, dagger)
if false == dagger then
dagger = ''; -- no dagger for |script-<param>= codes and names
else
dagger = '<sup>โ </sup>'; -- dagger for all other lists using override
end
if override_list[code] then -- look in the override table for this code
code_list[code] = override_list[code] .. dagger; -- use the name from the override table; mark with dagger
name_list[override_list[code]] = code .. dagger;
else
code_list[code] = name; -- use the MediaWiki name and code
name_list[name] = code;
end
end
--[[-------------------------< L I S T _ F O R M A T >---------------------------------------------------------
formats key/value pair into a string for rendering
['k'] = 'v' โ k: v
local function list_format (result, list)
for k, v in pairs (list) do
table.insert (result, k .. ': ' .. v);
end
end
--[[-------------------------< L A N G _ L I S T E R >---------------------------------------------------------
Module entry point
Crude documentation tool that returns one of several lists of language codes and names.
Used in Template:Citation Style documentation/language/doc
{{#invoke:cs1 documentation support|lang_lister|list=<selector>|lang=<code>}}
where <selector> is one of the values:
2char โ list of ISO 639-1 codes and names sorted by code
3char โ list of ISO 639-2, -3 codes and names sorted by code
ietf โ list of IETF language tags and names sorted by tag
ietf2 โ list of ISO 639-1 based IETF language tags and names sorted by tag
ietf3 โ list of list of ISO 639-2, -3 based IETF language tags and names sorted by tag
name โ list of language names and codes sorted by name
all - list all language codes/tags and names sorted by code/tag
where <code> is a MediaWiki supported 2, 3, or ietf-like language code; because of fall-back, language names may
be the English-language names.
local function lang_lister (frame)
local lang = (frame.args.lang and '' ~= frame.args.lang) and frame.args.lang or mw.getContentLanguage():getCode()
local source_list = mw.language.fetchLanguageNames(lang, 'all');
local override = cfg.lang_tag_remap;
local code_1_list={};
local code_2_list={};
local ietf_list={};
local ietf_list2={};
local ietf_list3={};
local name_list={};
if not ({['2char']=true, ['3char']=true, ['ietf']=true, ['ietf2']=true, ['ietf3']=true, ['name']=true, ['all']=true})[frame.args.list] then
return '<span style="color:#d33">unknown list selector: ' .. frame.args.list .. '</span>';
end
for code, name in pairs (source_list) do
if 'all' == frame.args.list then
add_to_list (code_1_list, name_list, override, code, name); -- use the code_1_list because why not?
elseif 2 == code:len() then
elseif 3 == code:len() then
add_to_list (code_2_list, name_list, override, code, name);
elseif code:match ('^%a%a%-.+') then -- ietf with 2-character language tag
add_to_list (ietf_list, name_list, override, code, name); -- add to main ietf list for |list=ietf
add_to_list (ietf_list2, name_list, override, code, name); -- add to ietf2 list
elseif code:match ('^%a%a%a%-.+') then -- ietf with 3-character language tag
add_to_list (ietf_list3, name_list, override, code, name); -- add to ietf3 list
end
end
local result = {};
local out = {};
if '2char' == frame.args.list or 'all' == frame.args.list then -- iso 639-1
list_format (result, code_1_list);
elseif '3char' == frame.args.list then -- iso 639-2, 3
list_format (result, code_2_list);
elseif 'ietf' == frame.args.list then -- all ietf tags
list_format (result, ietf_list);
elseif 'ietf2' == frame.args.list then -- 2-character ietf tags
list_format (result, ietf_list2);
elseif 'ietf3' == frame.args.list then -- 3 character ietf tags
list_format (result, ietf_list3);
else --must be 'name'
list_format (result, name_list);
end
local templatestyles = frame:extensionTag{
name = 'templatestyles', args = { src = "Div col/styles.css" }
table.sort (result);
table.insert (result, 1, templatestyles .. '<div class="div-col" style="column-width:16em">');
table.insert (out, table.concat (result, '\n*'));
table.insert (out, '</div>');
return table.concat (out, '\n');
end
--[[--------------------------< S C R I P T _ L A N G _ L I S T E R >------------------------------------------
Module entry point
Crude documentation tool that returns list of language codes and names supported by the various |script-<param>= parameters.
used in Help:CS1 errors
{{#invoke:cs1 documentation support|script_lang_lister}}
local function script_lang_lister (frame)
local lang_code_src = cfg.script_lang_codes ; -- get list of allowed script language codes
local this_wiki_lang = mw.language.getContentLanguage().code; -- get this wiki's language
local code_list = {}; -- interim list of aliases
local name_list={}; -- not used; defined here so that we can reuse add_to_list()
local out = {}; -- final output (for now an unordered list)
for _, code in ipairs (lang_code_src) do -- loop through the list of codes
local name = mw.language.fetchLanguageName (code, this_wiki_lang); -- get the language name associated with this code
add_to_list (code_list, name_list, override, code, name, false); -- name_list{} not used but provided so that we can reuse add_to_list(); don't add superscript dagger
end
local result = {};
local out = {};
list_format (result, code_list);
end
--[[--------------------------< A L I A S _ L I S T E R >------------------------------------------------------
experimental code that lists parameters and their aliases. Perhaps basis for some sort of documentation?
{{#invoke:cs1 documentation support|alias_lister}}
local function alias_lister ()
local alias_src = cfg.aliases; -- get master list of aliases
local key; -- key for k/v in a new table
local list = {}; -- interim list of aliases
for _, aliases in pairs (alias_src) do -- loop throu the master list of aliases
if 'table' == type (aliases) then -- table only when there are aliases
for i, alias in ipairs (aliases) do -- loop through all of the aliases
if 1 == i then -- first 'alias' is the canonical parameter name
key = alias; -- so it becomes the key in list
else
list[key] = list[key] and (list[key] .. ', ' .. alias) or alias; -- make comma-separated list of aliases
list[alias] = 'see ' .. key; -- make a back reference from this alias to the canonical parameter
end
end
end
end
for k, v in pairs (list) do -- loop through the list to make a simple unordered list
table.insert (out, table.concat ({'*', k, ': ', v}));
end
table.sort (out); -- sort it
return table.concat (out, '\010'); -- concatenate with \n
-- return (mw.dumpObject (list))
end
--[[--------------------------< C A N O N I C A L _ P A R A M _ L I S T E R >----------------------------------
experimental code that lists canonical parameter names. Perhaps basis for some sort of documentation?
returns a comma separated, alpha sorted, list of the canonical parameters. If given a template name, excludes
parameters listed in that template's exclusion_list[<template>]{} table (if a table has been defined).
{{#invoke:cs1 documentation support|canonical_param_lister|<template>}}
local function canonical_param_lister (frame)
local template = frame.args[1];
if '' == template then
template = nil;
end
if template then
template = mw.text.trim (template:lower());
end
local id_src = cfg.id_handlers; -- get master list of identifiers
for _, aliases in pairs (alias_src) do -- loop through the master list of aliases
local name;
name = aliases[1]; -- first member of an aliases table is declared canonical
else
name = aliases; -- for those parameters that do not have any aliases, the parameter is declared canonical
end
if not template then -- no template name, add this parameter
table.insert (list, name);
elseif not exclusion_lists[template] then -- template name but no exclusion list
elseif not exclusion_lists[template][name] then -- template name and exclusion list but name not in list
end
end
for k, ids in pairs (id_src) do -- spin through the list of identifiers
local name = id_src[k].parameters[1]; -- get the first (left-most) parameter name
local access = id_src[k].custom_access; -- get the access-icon parameter if it exists for this identifier
table.insert (list, name); -- add this parameter
if access then
table.insert (list, access); -- add this access-icon parameter
end
if access then
end
if access then
end
end
end
for _, param in ipairs (list) do -- loop through the list to make a simple unordered list
table.insert (out, table.concat ({'*', param}));
end
local function comp( a, b ) -- used in following table.sort()
return a:lower() < b:lower();
end
table.sort (out, comp); -- sort the list
end
--[[--------------------------< C A N O N I C A L _ N A M E _ G E T >------------------------------------------
returns first (canonical) name when metaparameter is assigned a table of names
returns name when metaparameter is assigned a single name
returns empty string when metaparameter name not found in alias_src{}, id_src{}, or id_src[meta].custom_access
metaparameter <metaparam> is the key in Module:Citation/CS1 aliases{} table or id_handlers{} table. Because access-icon
don't have <metaparam> keys, per se, we create pseudo <metaparam> keys by appending 'access' to the identifier <metaparam>:
the <metaparam> for |doi-access= is, for the purposes of this function, DOIaccess, etc
Some lists of aliases might be better served when a particular alias is identified as the canonical alias for a
particular use case. If, for example, <metaparam> Perodical lists:
'journal', 'magazine', 'newspaper', 'periodical', 'website', 'work'
that order works fine for {{cite journal}} documentation but doesn't work so well for {{cite magazine}}, {{cite news}},
or {{cite web}}. So, for using this function to document {{cite magazine}} the returned value should be the
parameter best suited for that template so we can specify magazine in the override (frame.args[2])
While for this function, it would be just as simple to not use the function, this mechanism is implemented here
to match similar functionality in alias_names_get() (there are slight differences)
<override> must exist in the alias list
does not apply to the access icon parameters (ignored - these have no aliases)
(and which would be best for {{cite news}}? |newspaper= or |work=? can't solve all of the worlds problems at once).
output format is controlled by |format=
plain - renders in plain text in a <span> tag; may have id attribute
para - renders as it would in {{para|<param>}}
{{#invoke:cs1 documentation support|canonical_name_get|<metaparam>|<override>|id=<attribute>|format=[plain|para]}}
local function canonical_name_get (frame)
local args = getArgs (frame);
local name;
local meta = args[1]
local override = args[2];
local access; -- for id-access parameters
if meta:match ('^(%u+)access') then -- the metaparameter (which is not used in ~/Configuration) is id_handlers key concatenated with access: BIBCODEaccess
meta, access = meta:gsub ('^(%u+)access', '%1'); -- strip 'access' text from meta and use returned count value as a flag
end
if alias_src[meta] then
name = alias_src[meta]; -- name is a string or a table
if 'table' == type (name) then -- table only when there are aliases
if not override then
name = name[1]; -- first member of an aliases table is declared canonical
else
for _, v in ipairs (name) do -- here when override is set; spin throu the aliases to make sure override matches alias in table
if v == override then
name = v; -- declare override to be the canonical param for this use case
break;
end
end
end
end
elseif id_src[meta]then -- if there is an id handler
if access then -- and if this is a request for the handler's custom access parameter
if id_src[meta].custom_access then -- if there is a custom access parameter
name = id_src[meta].custom_access; -- use it
else
return ''; -- nope, return empty string
end
else
name = id_src[meta].parameters[1]; -- get canonical id handler parameter
else
for _, v in ipairs (id_src[meta].parameters) do -- here when override is set; spin throu the aliases to make sure override matches alias in table
break;
end
end
end
end
else
return ''; -- metaparameter not specified, or no such metaparameter
end
if 'plain' == args.format then -- format and return the output
if args.id then
return string.format ('<span id="%s">%s</span>', args.id, name); -- plain text with id attribute
else
return name; -- plain text
end
elseif 'para' == args.format then
return string.format ('<code class="nowrap">|%s=</code>', name); -- same as {{para|<param>}}
end
return string.format ('<b id="%s">%s</b>', args.id or '', name); -- because {{csdoc}} bolds param names
end
--[[--------------------------< A L I A S _ N A M E S _ G E T >------------------------------------------------
returns list of aliases for metaparameter <metaparam>
returns empty string when there are no aliases
returns empty string when <metaparam> name not found in alias_src{} or id_src{}; access icon parameters have no aliases so ignored
aliases that are not best suited for that template so we can specify magazine in the override (frame.args[2])
to be the canonical parameter so it won't be listed with the rest of the aliases (normal canonical journal will be)
<override> must exist in the alias list except:
when <override> value is 'all', returns the canonical parameter plus all of the aliases
when not specified, refurns the default bold format used for {{csdoc}}
{{#invoke:cs1 documentation support|alias_name_get|<metaparam>|<override>|format=[plain|para]}}
local function alias_names_get (frame)
local meta = args[1];
local out = {};
local source; -- selected parameter or id aliases list
local aliases;
source = alias_src[meta] or (id_src[meta] and id_src[meta].parameters);
if not source then
if meta:match ('%u+access') then
return 'no' == args.none and '' or 'none'; -- custom access parameters don't have aliases
else
return ''; -- no such meta
end
elseif not source[2] then -- id_source[meta] is always a table; if no second member, no aliases
end
aliases = source; -- normal skip-canonical param case
else
local flag = 'all' == override and true or nil; -- so that we know that <override> parameter is a valid alias; spoof when override == 'all'
aliases = {[1] = ''}; -- spoof to push alias_src[meta][1] and id_src[meta][1] into aliases[2]
for _, v in ipairs (source) do -- here when override is set; spin through the aliases to make sure override matches alias in table
if v ~= override then
table.insert (aliases, v); -- add all but overridden param to the the aliases list for this use case
else
flag = true; -- set the flag so we know that <override> is a valid alias
end
end
if not flag then
aliases = {} -- unset the table as error indicator
end
end
if 1 ~= i then -- aliases[1] is the canonical name; don't include it
table.insert (out, alias); -- plain text
table.insert (out, string.format ('<code class="nowrap">|%s=</code>', alias)); -- same as {{para|<param>}}
else
table.insert (out, string.format ("'''%s'''", alias)); -- because csdoc bolds param names
end
end
end
return table.concat (out, ', '); -- make pretty list and quit
end
return 'no' == args.none and '' or 'none'; -- no metaparameter with that name or no aliases
end
--[[--------------------------< I S _ B O O K _ C I T E _ T E M P L A T E >------------------------------------
fetch the title of the current page; if it is a preprint template, return true; empty string else
local book_cite_templates = {
['citation'] = true,
['cite book'] = true,
local function is_book_cite_template ()
local title = mw.title.getCurrentTitle().rootText; -- get title of current page without namespace and without sub-pages; from Template:Cite book/new -> Cite book
title = title and title:lower() or '';
return book_cite_templates[title] or '';
end
--[[--------------------------< I S _ L I M I T E D _ P A R A M _ T E M P L A T E >----------------------------
local limited_param_templates = { -- if ever there is a need to fetch info from ~/Whitelist then
['cite arxiv'] = true, -- this list could also be fetched from there
['cite biorxiv'] = true,
['ssrn'] = true,
local function is_limited_param_template ()
return limited_param_templates[title] or '';
end
--[[--------------------------< H E A D E R _ M A K E >--------------------------------------------------------
makes a section header from <header_text> and <level>; <level> defaults to 2; cannot be less than 2
local function _header_make (args)
if not args[1] then
return ''; -- no header text
end
local level = args[2] and tonumber (args[2]) or 2;
level = string.rep ('=', level);
return level .. args[1] .. level;
end
Entry from an {{#invoke:}}
local function header_make (frame)
return _header_make (args);
end
--[[--------------------------< I D _ L I M I T S _ G E T >----------------------------------------------------
return the limit values for named identifier parameters that have <id> limits (pmc, pmid, ssrn, s2cid, oclc, osti, rfc); the return
value used in template documentation and error message help-text
{{#invoke:Cs1 documentation support|id_limits_get|<id>}}
local function id_limits_get (frame)
local handlers = cfg.id_handlers; -- get id_handlers {} table from ~/Configuration
return args[1] and handlers[args[1]:upper()].id_limit or ('<span style="color:#d33">No limit defined for identifier: ' .. (args[1] or '<unknown name>') .. '</span>');
end
--[[--------------------------< C A T _ L I N K _ M A K E >----------------------------------------------------
local function cat_link_make (cat)
return table.concat ({'[[:Category:', cat, ']]'});
end
--[[--------------------------< S C R I P T _ C A T _ L I S T E R >--------------------------------------------
utility function to get script-language categories
local lang_list_t = mw.language.fetchLanguageNames ('en', 'all');
local function script_cat_lister (script_lang_codes_t, lang_tag_remap_t, cats_list_t)
for _, lang_code in ipairs (script_lang_codes_t) do
local lang_name = lang_tag_remap_t[lang_code] or lang_list_t[lang_code]; -- use remap table to get Bengali instead of Bangla and the like; else use standard MediaWiki names
local cat = 'CS1 uses ' .. lang_name .. '-language script (' .. lang_code .. ')'; -- build a category name
cats_list_t[cat] = 1; -- and save it
end
end
--[[--------------------------< C S 1 _ C A T _ L I S T E R >--------------------------------------------------
This is a crude tool that reads the category names from Module:Citation/CS1/Configuration, makes links of them,
and then lists them in sorted lists. A couple of parameters control the rendering of the output:
|select= -- (required) takes one of three values: error, maint, prop
|sandbox= -- takes one value: no
|hdr-lvl= -- base header level (number of == that make a header); default:2 min:2
This tool will automatically attempt to load a sandbox version of ~/Configuration if one exists.
Setting |sandbox=no will defeat this.
{{#invoke:cs1 documentation support|cat_lister|select=<error|maint|prop>|sandbox=<no>}}
local function cat_lister (frame)
local list_live_cats = {}; -- list of live categories
local list_sbox_cats = {}; -- list of sandbox categories
local live_sbox_out = {} -- list of categories that are common to live and sandbox modules
local live_not_in_sbox_out = {} -- list of categories in live but not sandbox
local sbox_not_in_live_out = {} -- list of categories in sandbox but not live
local out = {}; -- final output assembled here
local sandbox; -- boolean; true: evaluate the sandbox module
local hdr_lvl; --
local sb_cfg;
local sandbox, sb_cfg = pcall (mw.loadData, 'Module:Citation/CS1/Configuration/sandbox'); -- get sandbox configuration
local cat;
local select = args.select;
if 'no' == args.sandbox then -- list sandbox?
sandbox = false; -- no, live only
end
if hdr_lvl then -- if set and
if tonumber (hdr_lvl) then -- can be converted to number
if 2 > tonumber (hdr_lvl) then -- min is 2
hdr_lvl = 2; -- so set to min
end
else -- can't be converted
hdr_lvl = 2; -- so default to min
end
else
hdr_lvl = 2; -- not set so default to min
end
if 'error' == select or 'maint' == select then -- error and main categorys handling different from poperties cats
for _, t in pairs (cfg.error_conditions) do -- get the live module's categories
if ('error' == select and t.message) or ('maint' == select and not t.message) then
cat = t.category:gsub ('|(.*)$', ''); -- strip sort key if any
list_live_cats[cat] = 1; -- add to the list
end
end
if sandbox then -- if ~/sandbox module exists and |sandbox= not set to 'no'
for _, t in pairs (sb_cfg.error_conditions) do -- get the sandbox module's categories
list_sbox_cats[cat] = 1; -- add to the list
end
end
end
elseif 'prop' == select then -- prop cats
for _, cat in pairs (cfg.prop_cats) do -- get the live module's categories
cat = cat:gsub ('|(.*)$', ''); -- strip sort key if any
end
script_cat_lister (cfg.script_lang_codes, cfg.lang_tag_remap, list_live_cats); -- get live module's foriegn language script cats
for _, cat in pairs (sb_cfg.prop_cats) do -- get the sandbox module's categories
end
script_cat_lister (sb_cfg.script_lang_codes, sb_cfg.lang_tag_remap, list_sbox_cats); -- get sandbox module's foriegn language script cats
end
else
return '<span style="color:#d33; font-style:normal;">error: unknown selector: ' .. select .. '</span>'
end
for k, _ in pairs (list_live_cats) do -- separate live/sbox common cats from cats not in sbox
if not list_sbox_cats[k] and sandbox then
table.insert (live_not_in_sbox_out, cat_link_make (k)); -- in live but not in sbox
else
table.insert (live_sbox_out, cat_link_make (k)); -- in both live and sbox
end
end
for k, _ in pairs (list_sbox_cats) do -- separate sbox/live common cats from cats not in live
if not list_live_cats[k] then
table.insert (sbox_not_in_live_out, cat_link_make (k)); -- in sbox but not in live
end
end
local function comp (a, b) -- local function for case-agnostic category name sorting
end
local header; -- initialize section header with name of selected category list
if 'error' == select then
header = 'error';
elseif 'maint' == select then
header = 'maintenance';
else
header = 'properties';
end
header = table.concat ({ -- build the main header
'Live ', -- always include this
((sandbox and 'and sandbox ') or ''), -- if sandbox evaluated, mention that
header, -- add the list name
' categories (', -- finish the name and add
#live_sbox_out, -- count of categories listed
')' -- close
header = table.concat ({ -- make a useable header
_header_make ({header, hdr_lvl}),
'\n' .. templatestyles .. '<div class="div-col">' -- opening <div> for columns
table.sort (live_sbox_out, comp); -- sort case agnostic acsending
table.insert (live_sbox_out, 1, header); -- insert the header at the top
table.insert (out, table.concat (live_sbox_out, '\n*')); -- make a big string of unordered list markup
table.insert (out, '</div>\n'); -- close the </div> and add new line so the next header works
if 0 ~= #live_not_in_sbox_out then -- when there is something in the table
header = table.concat ({ -- build header for subsection
'In live but not in sandbox (',
#live_not_in_sbox_out,
_header_make ({header, hdr_lvl+1}),
table.sort (live_not_in_sbox_out, comp);
table.insert (live_not_in_sbox_out, 1, header);
table.insert (out, table.concat (live_not_in_sbox_out, '\n*'));
end
if 0 ~= #sbox_not_in_live_out then -- when there is something in the table
'In sandbox but not in live (',
#sbox_not_in_live_out,
table.sort (sbox_not_in_live_out, comp);
table.insert (sbox_not_in_live_out, 1, header);
table.insert (out, table.concat (sbox_not_in_live_out, '\n*'));
end
return table.concat (out); -- concat into a huge string and done
end
--[=[--------------------------< H E L P _ T E X T _ C A T S >--------------------------------------------------
To create category links at the bottom of each error help text section and on the individual error category pages;
fetches category names from ~/Configuration; replaces this:
{{#ifeq:{{FULLPAGENAME}}|Category:CS1 errors: bioRxiv|Category:CS1 errors: bioRxiv|[[:Category:CS1 errors: bioRxiv]]}}
with this:
{{#invoke:Cs1 documentation support|help_text_cats|err_bad_biorxiv}}
where {{{1}}} is the error_conditions key from Module:Citation/CS1/Configuration
add |pages=yes to append the number of pages in the category
local function help_text_cats (frame)
local args_t = getArgs (frame);
local error_conditions_t = cfg.error_conditions; -- get the table of error conditions
local replacements_t = {}; -- table to hold replacement parameters for $1 etc placeholders in category names
for k, v in pairs (args_t) do -- look for |$1=<replacement> parameters
if 'string' == type (k) and k:match ('^$%d+$') then -- if found
replacements_t[k] = v; -- save key and value
end
end
if args_t[1] and error_conditions_t[args_t[1]] then -- must have error_condition key and it must exist
local error_cat = error_conditions_t[args_t[1]].category; -- get error category from cs1|2 configuration
if error_cat:match ('$%d') then -- look for placeholders in <error_cat>
error_cat = error_cat:gsub ('$%d', replacements_t) -- replace place holders with matching value from replacements_t
end
local title_obj = mw.title.getCurrentTitle(); -- get a title object for the currently displayed page
local name_space = title_obj.nsText;
if ('Category' == name_space) and (error_cat == title_obj.text) then -- if this is the category page for the error message
return table.concat ({'Category:', error_cat}); -- no link; just category name
else -- here when currently displayed page is other than the error message category
local pages = ''; -- default empty strin for concatenation
if 'yes' == args_t.pages then -- if we should display category page count: TODO: do we need to keep this?
pages = mw.site.stats.pagesInCategory (error_cat, 'all'); -- get category page count
pages = table.concat ({' (', mw.language.getContentLanguage():formatNum (pages), ' page', (1 == pages) and ')' or 's)'}); -- make renderable text
end
return table.concat ({'[[:Category:', error_cat, ']]', pages}); -- link to category with or without page count
end
else
return '<span style="color:#d33">unknown error_conditions key: ' .. (args_t[1] or 'key missing') .. '</span>';
end
end
--[[--------------------------< H E L P _ T E X T _ E R R O R _ M E S S A G E >--------------------------------
to render help text example error messages
{{#invoke:Cs1 documentation support|help_text_error_messages|err_bad_biorxiv}}
assign a single underscore to any of the |$n= parameters to insert an empty string in the error message:
{{#invoke:Cs1 documentation support|help_text_error_messages|err_bad_issn|$1=_}} -> Check |issn= value
{{#invoke:Cs1 documentation support|help_text_error_messages|err_bad_issn|$1=e}} -> Check |eissn= value
error message is rendered at 120% font size; to specify another font size use |size=; must include unit specifier (%, em, etc)
local function help_text_error_messages (frame)
local error_conditions = mw.loadData ('Module:Citation/CS1/Configuration').error_conditions;
-- local span_o = '<span class="cs1-visible-error citation-comment">';
local span_o = '<span class="citation-comment" style="color:#d33; font-size:' .. ((args_t.size and args_t.size) or '120%') .. '">';
local span_c = '</span>';
local message;
local out = {}; -- output goes here
if args_t[1] and error_conditions[args_t[1]] then -- must have error_condition key and it must exist
message = error_conditions[args_t[1]].message;
local i=1;
local count;
local rep;
repeat
rep = '$'..i
args_t[rep] = args_t[rep] and args_t[rep]:gsub ('^%s*_%s*$', '') or nil; -- replace empty string marker with actual empty string
message, count = message:gsub (rep, args_t[rep] or rep)
i = i + 1;
until (0 == count);
table.insert (out, span_o);
table.insert (out, message);
table.insert (out, span_c);
else
end
local out_str = table.concat (out);
return table.concat ({frame:extensionTag ('templatestyles', '', {src='Module:Citation/CS1/styles.css'}), out_str});
end
--[[--------------------------< T E M P L A T E S _ T >--------------------------------------------------------
This table is a k/v table of sequence tables. The keys in this table are collapsed lowercase form of the cs1|2
template names ({{ROOTPAGENAME}}):
Template:Cite AV media -> citeavmedia
Each subsequence table holds:
[1] documentation page where the TemplateData json is stored ({{cite book}} is the oddball)
[2] key to 'preprint_arguments_t' and unique_arguments_t' tables in Module:Citation/CS1/Whitelist; these keys
dictate which of the basic or limited arguments and numbered arguments tables will be used to validate
the content of the TemplateData
local templates_t = {
citearxiv = {'Template:Cite_arXiv/doc', 'arxiv'}, -- preprint arguments
citeavmedia = {'Template:Cite AV media/doc', 'audio-visual'}, -- unique arguments
citeavmedianotes = {'Template:Cite AV media notes/doc'}, -- no template data
citebiorxiv = {'Template:Cite bioRxiv/doc', 'biorxiv'}, -- preprint arguments
citebook = {'Template:Cite book/TemplateData'},
citeciteseerx = {'Template:Cite CiteSeerX/doc', 'citeseerx'}, -- no template data; preprint uses limited arguments
citeconference = {'Template:Cite conference/doc', 'conference'}, -- unique arguments
citedocument = {'Template:Cite document/doc', 'document'}, -- special case; uses whitelist.document_parameters_t
citeencyclopedia = {'Template:Cite encyclopedia/doc'},
citeepisode = {'Template:Cite episode/doc', 'episode'}, -- unique arguments
citeinterview = {'Template:Cite interview/doc'},
citejournal = {'Template:Cite journal/doc'},
citemagazine = {'Template:Cite magazine/doc'},
citemailinglist = {'Template:Cite mailing list/doc', 'mailinglist'}, -- unique arguments -- no template data
citemap = {'Template:Cite map/TemplateData', 'map'}, -- unique arguments
citemedrxiv = {'Template:Cite medRxiv/doc', 'medrxiv'}, -- preprint arguments
citenews = {'Template:Cite news/doc'},
citenewsgroup = {'Template:Cite newsgroup/doc', 'newsgroup'}, -- unique arguments
citepodcast = {'Template:Cite podcast/doc'},
citepressrelease = {'Template:Cite press release/doc'},
citereport = {'Template:Cite report/doc', 'report'}, -- unique arguments
citeserial = {'Template:Cite serial/doc', 'serial'}, -- unique arguments -- no template data
citesign = {'Template:Cite sign/doc'},
citespeech = {'Template:Cite speech/doc', 'speech'}, -- unique arguments -- no template data
citessrn = {'Template:Cite SSRN/doc', 'ssrn'}, -- preprint arguments -- no template data
citetechreport = {'Template:Cite tech report/doc'},
citethesis = {'Template:Cite thesis/doc', 'thesis'}, -- unique arguments
citeweb = {'Template:Cite web/doc'},
citation = {'Template:Citation/doc'},
--[[--------------------------< N O _ P A G E _ T E M P L A T E S _ T >----------------------------------------
local no_page_templates_t = {};
--[[--------------------------< I D E N T I F I E R _ A L I A S E S _ T >--------------------------------------
a table of the identifier aliases
local identifier_aliases_t = {}
for identifier, handler in pairs (cfg.id_handlers) do -- for each identifier
local aliases_t = {}; -- create a table
for _, alias in ipairs (handler.parameters) do -- get the alaises
aliases_t[alias] = true; -- and add them to the table in a form that mimics the whitelist tables
end
identifier_aliases_t[identifier:lower()] = aliases_t; -- add new table to the identifier aliases table; use lowercase identifier base name for the key
end
--[[--------------------------< T E M P L A T E _ D A T A _ J S O N _ G E T >----------------------------------
get template doc page content and extract the content of the TemplateData tags (case insensitive)
<template> is the canonical name of the template doc page (with namespace) that holds the template data; usually
Template:Cite xxx/doc (except Template:Cite book/TemplateData)
local function template_data_json_get (template)
local json = mw.title.new (template):getContent() or ''; -- get the content of the article or ''; new pages edited w/ve do not have 'content' until saved; ve does not preview; phab:T221625
json = json:match ('<[Tt]emplate[Dd]ata>(.-)</[Tt]emplate[Dd]ata>'); -- remove everything exept the content of the TemplatData tags
return json and mw.text.jsonDecode (json); -- decode the json string and return as a table; nil if not found
end
--[[--------------------------< V A L I D A T E _ D O C U M E N T _ P A R A M >--------------------------------
looks for <param> (can be the canonical parameter name or can be an alias) in whitelist.document_parameters_t.
When found, returns true; nil else
<param> is the parameter's name as listed in the TemplateData
local function validate_document_param (param)
if true == whitelist.document_parameters_t[param] then
return true;
end
end
--[[--------------------------< V A L I D A T E _ U N I Q U E _ P A R A M >------------------------------------
looks for <param> (can be the canonical parameter name or can be an alias) in whitelist.basic_arguments{} and if
necessary in whitelist.numbered_arguments{}. When found, returns true; nil else
local function validate_basic_param (param)
if true == whitelist.common_parameters_t[param] then
return true;
end
end
--[[--------------------------< V A L I D A T E _ P R E P R I N T _ P A R A M >--------------------------------
looks for <param> (can be the canonical parameter name or can be an alias) in whitelist.preprint_arguments_t{} or
whitelist.limited_basic_arguments{} or whitelist.limited_numbered_arguments{}. When found, returns true; nil else
<key> is key neccessary to look in the appropriate subtable of whitelist.preprint_arguments_t{}
local function validate_preprint_param (param, key)
if true == whitelist.preprint_arguments_t[key][param] or
true == whitelist.limited_parameters_t[param] then
-- true == whitelist.limited_basic_arguments_t[param] or
-- true == whitelist.limited_numbered_arguments_t[param] then
return true;
end
end
looks for <param> (can be the canonical parameter name or can be an alias) in whitelist.unique_arguments_t{} or
whitelist.basic_arguments{} or whitelist.numbered_arguments{}. When found, returns true; nil else
<key> is key neccessary to look in the appropriate subtable of whitelist.unique_arguments_t{}
local function validate_unique_param (param, key, cfg_aliases_t)
if true == whitelist.unique_arguments_t[key][param] or true == validate_basic_param (param) then
return true;
end
end
--[[--------------------------< V A L I D A T E _ I D _ P A R A M >--------------------------------------------
looks for <param> <alias> in identifier_aliases_t{}. When found, returns true; nil else
<alias> is the alias that we're looking for
local function validate_id_alias (param, alias)
return identifier_aliases_t[param] and identifier_aliases_t[param][alias];
end
--[[--------------------------< P A R A M _ E R R O R_ M S G >-------------------------------------------------
local function param_error_msg (param)
return '<span style="font-family:"monospace">|' .. param .. '=</span> is not a valid parameter';
end
--[[--------------------------< D U P _ A L I A S _ E R R O R_ M S G >-----------------------------------------
local function dup_alias_error_msg (param, alias)
return '<span style="font-family:"monospace">|' .. param .. '=</span> has duplicate aliases: <span font-family:"monospace";>|' .. alias .. '=</span>';
end
--[[--------------------------< D U P _ A L I A S E S _ C H E C K >--------------------------------------------
create an associative array of <param> aliases. if <alias> already present in <aliases_t> add an error message
to <out>
local function dup_aliases_check (param, alias, aliases_t, out_t)
if not aliases_t[alias] then
else
table.insert (out_t, dup_alias_error_msg (param, alias));
end
end
--[[--------------------------< A L I A S _ E R R O R_ M S G >-------------------------------------------------
local function alias_error_msg (param, alias)
return '<code style="color: inherit; background: inherit; border: none; padding: inherit">|' .. alias .. '=</code> is not a valid alias of: <code style="color: inherit; background: inherit; border: none; padding: inherit">|' .. param .. '=</code>';
end
--[[--------------------------< C F G _ A L I A S E S _ T _ M A K E >------------------------------------------
convert this from cfg.aliases{}:
['AccessDate'] = {'access-date', 'accessdate'}
to this in out_t{}
['access-date'] = 'AccessDate',
['accessdate'] = 'AccessDate',
to test if |accessdate= is an aliases of |access-date=:
if out_t['access-date'] == out_t['accessdate']
local function cfg_aliasts_t_make ()
local out_t = {};
for meta, params_t in pairs (cfg.aliases) do
if 'table' == type (params_t) then -- metaparameters that are assigned string values do not have aliases
for _, param in ipairs (params_t) do -- for each alias
param = param:gsub ('#', ''); -- get rid of enumerators
out_t[param] = meta; -- add it to the output table
end
end
end
--error (mw.dumpObject (out_t))
return out_t;
end
--[[--------------------------< T E M P L A T E _ D A T A _ V A L I D A T E >----------------------------------
compairs parameter names listed in a cs1|2 template's TemplateData structure (everything between <TemplateData>
and </TemplateData> tag case insensitive). Returns error messages when errors found, empty string else.
{{#invoke:Cs1 documentation support|template_data_validate|{{ROOTPAGENAME}}}}
When called from a different page:
{{#invoke:cs1 documentation support|template_data_validate|<canonical template name>}}
where the <canonical template name> is the template's canonical name with or without namespace and or subpages
local function template_data_validate (frame)
if not args_t[1] then
return '<span style="color:#d33">Error: cs1|2 template name required</span>';
end
local template_idx = args_t[1]:lower():match ('cit[ae][^/]+'); -- args_t[1] has something
if not template_idx then -- but if not a cs1|2 template abandon with error message
else
template_idx = template_idx:gsub (' ', ''); -- is what appears to be a cs1|2 template so strip spaces
end
local cfg_aliases_t = cfg_aliasts_t_make ();
local template_t = templates_t[template_idx];
local out = {};
local template_doc = template_t[1];
local json_t = template_data_json_get (template_doc);
if not json_t then
table.insert (out, 'Error: can\'t find TemplateData');
else
for param, param_t in pairs (json_t['params']) do
local param_i; -- this will be the parameter name that gets validated
if param:find ('[Ss]2[Cc][Ii][Dd]') then -- |s2cid*= parameters are not enumerated ...
param_i = param; -- ... so don't convert the '2' to '#'
else
param_i = param:gsub ('%d+', '#'); -- for enumerated parameters, convert the enumerator digits to a single '#' character; all others unmolested
end
local param_is_valid; -- boolean true when param is valid; nil else
if template_t[2] then -- if template is a preprint or uses unique parameters of 'document' parameters
if 'document' == template_t[2] then -- if a {{cite document}} template
param_is_valid = validate_document_param (param_i, template_t[2]);
if param_is_valid then
local aliases_t = {}; -- used by dup_aliases_check
if param_t['aliases'] then
for _, alias in ipairs (param_t['aliases']) do
dup_aliases_check (param, alias, aliases_t, out);
local alias_i = alias:gsub ('%d+', '#'); -- in case an enumerated parameter, convert the enumerator digits to a single '#' character
if not validate_document_param (alias_i, template_t[2]) then -- is 'alias' a known parameter?
table.insert (out, alias_error_msg (param, alias)); -- may be known but is not supported
elseif cfg_aliases_t[param_i:gsub ('#', '')] ~= cfg_aliases_t[alias_i:gsub ('#', '')] then -- is 'alias' known to be an alias of 'param'?
end
end
end
else -- here when param not valid preprint param
table.insert (out, param_error_msg (param))
end
elseif whitelist.preprint_arguments_t[template_t[2]] then -- if a preprint template
param_is_valid = validate_preprint_param (param_i, template_t[2]);
if not validate_preprint_param (alias_i, template_t[2]) then -- is 'alias' a known parameter?
end
end
end
end
elseif whitelist.unique_arguments_t[template_t[2]] then -- if a unique parameters template
param_is_valid = validate_unique_param (param_i, template_t[2]);
local alias_i = alias:gsub ('%d+', '#'); -- in case an enumerated parameter, convert the enumerate digits to a single '#' character
if not validate_unique_param (alias_i, template_t[2]) then -- is 'alias' a known parameter?
end
end
end
else -- here when param not valid unique parameter
end
else -- should never be here if coder is doing the right thing ...
table.insert (out, 'internal error: unexpected keyword in templates_t: ' .. template_t[2]);
break;
end
else -- here when not unique or preprint
param_is_valid = validate_basic_param (param_i);
if not validate_basic_param (alias_i) and not validate_id_alias (param, alias) then -- for isbn13 (while still supported) must not mask the digits
end
end
end
end
end
end
end
---------- this emits errors when page/pages/at listed in templatedata of templates that don't support those parameters ----------
-- if json_t then
-- if ({['citeavmedia']=true, ['citeepisode']=true, ['citemailinglist']=true, ['citenewsgroup']=true, ['citepodcast']=true, ['citeserial']=true, ['citesign']=true, ['citespeech']=true})[template_idx] then
-- local insource_params_t = {}; -- build sequence of pagination params not supported by these templates
-- for _, meta_param in ipairs ({'At', 'Page', 'Pages', 'QuotePage', 'QuotePages'}) do
-- if 'table' == type (cfg.aliases[meta_param]) then
-- for _, alias in ipairs (cfg.aliases[meta_param]) do -- metaparameter is a sequence
-- table.insert (insource_params_t, alias); -- add the aliases from the metaparameter sequence to the table
-- end
-- else -- metaparameter is plain text
-- table.insert (insource_params_t, cfg.aliases[meta_param]); -- add the alias to the table
-- end
-- end
-- for _, param in ipairs (insource_params_t) do
-- if json_t.params[param] then
-- table.insert (out, param_error_msg (param)); -- error; this parameter not supported by this template
-- end
-- end
-- end
-- end
---------- end page/pages/at error detection ----------
if 0 ~= #out then
table.sort (out);
out[1] = '*' .. out[1]; -- add a splat to the first error message
-- return table.concat ({'[[' .. template_doc .. ']] TemplateData has errors:<div style="color:#d33; font-style: normal">\n', table.concat (out, '\n*'), '</div>'});
'[[Template:' .. args_t[1] .. ']] uses ',
whitelist.preprint_arguments_t[template_t[2]] and 'preprint and limited parameter sets' or (whitelist.unique_arguments_t[template_t[2]] and 'unique and standard parameter sets' or 'standard parameter set'),
'; TemplateData has errors:\n',
'<div style="color:#d33; font-style: normal">\n', table.concat (out, '\n*'), '</div>'
else
return; -- no errors detected; return nothing
end
end
--[[--------------------------< E R R O R _ C A T _ P A G E _ T A L L Y >--------------------------------------
loop through Module:Citation/CS1/Configuration error_conditions {} fetching error category names. For each error
category add the number of pages in the category to the tally. Render the number when done.
{{#invoke:cs1 documentation support|error_cat_page_tally}}
local function error_cat_page_tally ()
local tally = 0;
local cat_t = {}; -- some error message share a category; save tallied cats here so we don't recount the already counted
local i = 0; -- number of categories
for k, v_t in pairs (error_conditions_t) do
if k:match ('^err') then
if not cat_t[v_t.category] then
cat_t[v_t.category] = true;
tally = tally + mw.site.stats.pagesInCategory (v_t.category, 'pages'); -- get category page count; ignore subcats and files
i = i + 1;
end
end
end
return mw.language.getContentLanguage():formatNum (tally)
end
--[[--------------------------< M A I N T _ C A T _ P A G E _ T A L L Y >--------------------------------------
{{#invoke:cs1 documentation support|maint_cat_page_tally}}
Dynamic subcats of CS1 maint: DOI inactive not counted because these names come and go as time goes by.
local function maint_cat_page_tally ()
local tally = 0;
if not k:match ('^err') then -- if not an error key its a maint key
if 'maint_mult_names' == k or 'maint_numeric_names' == k then
local special_case_translation_t = cfg.special_case_translation;
for _, name in ipairs ({'AuthorList', 'ContributorList', 'EditorList', 'InterviewerList', 'TranslatorList'}) do
local cat_name = v_t.category:gsub ('$1', special_case_translation_t[name]); -- replace $1 with translated list name
tally = tally + mw.site.stats.pagesInCategory (cat_name, 'pages'); -- get category page count; ignore subcats and files
i = i + 1;
end
else
i = i + 1;
end
end
end
end
end
--[[--------------------------< U N C A T E G O R I Z E D _ N A M E S P A C E _ L I S T E R >------------------
For use in the Help:CS1 error ยงNotes
Get namespace names and identifiers from MediaWiki. Make a human readable list of namespace names and identifiers
that cs1|2 does not categorize.
{{#invoke:cs1 documentation support|uncategorized_namespace_lister}}
For convenience,
{{#invoke:cs1 documentation support|uncategorized_namespace_lister|all=<anything>}}
returns a list of all namespace names and identifiers used on the current wiki. Any namespace with an
identifier less than 1, currently Mainspace (0), Special (-1), and Media (-2), is excluded from the list.
local function uncategorized_namespace_lister (frame)
local list_t = {};
local function compare (a, b) -- local function to sort namespaces numerically by the identifiers
local a_num = tonumber (a:match ('%d+')); -- get identifiers and convert to numbers
local b_num = tonumber (b:match ('%d+'));
return a_num < b_num; -- do the comparison
end
for i, _ in pairs (mw.site.namespaces) do -- for each namespace in the table
if '' == frame.args.all or not frame.args.all then -- when |all= not set, make a list of uncategorized namespaces
if cfg.uncategorized_namespaces[i] then -- if the identifier is listed in our uncategorized namespace list
table.insert (list_t, table.concat ({mw.site.namespaces[i].name, ' (', i, ')'})) -- add name and identifier to our local list
end
elseif 0 < i then -- |all=<anything>: all namespace names and identifiers; ignore identifiers less than 1
table.insert (list_t, table.concat ({'*', mw.site.namespaces[i].name, ' (', i, ')'})) -- add name and identifier as an unordered list item
end
end
table.sort (list_t, compare); -- ascending numerical sort by identifier
if not frame.args.all then -- when |all= not set, format list of uncategorized namespaces and identifiers
list_t[#list_t] = 'and ' .. list_t[#list_t]; -- add 'and ' to the last name/identifier pair
return table.concat (list_t, ', '); -- make a big string and done
else -- make list of all namespaces and identifiers
return table.concat (list_t, '\n'); -- make a big string and done
end
end
--[[--------------------------< S I N G L E _ L T R _ 2 N D _ L V L _ D O M A I N _ L I S T E R >-------------
for Help:CS1_errors#bad_url, list the supported top level domains that support single-letter 2nd level names
{{#invoke:Module:cs1 documentation support|single_ltr_2nd_lvl_domain_lister}}
local function single_ltr_2nd_lvl_domain_lister ()
local out_t = {}; -- output goes here
for _, tld in ipairs (cfg.single_letter_2nd_lvl_domains_t) do -- fetch each tld
table.insert (out_t, '.' .. tld); -- prefix with a dot and save in out_t{}
end
return table.concat (out_t, ', '); -- make a big string and done
end
--[[--------------------------< C O D E _ N A M E _ P A I R _ E X I S T S >----------------------------------------
Returns language code if pair exists, nil if either code doesn't exist or the name doesn't match.
Intended for use by Template:CS1 language sources/core
args[1] is language code
args[2] is language name
local function code_name_pair_exists(frame)
local wiki_language = mw.getContentLanguage():getCode()
local source_list = mw.language.fetchLanguageNames(wiki_language, 'all');
local name_list = {};
for code, name in pairs(source_list) do
add_to_list(code_list, name_list, override, code, name);
end
local args = getArgs(frame);
local language_code = args[1]
local language_name = args[2]
-- Check if the language code exists and the corresponding name matches
if code_list[language_code] == language_name then
-- Both code and name are a valid pair
return language_code
else
if override[language_code] == language_name then
-- Code and name are a valid pair found in override table
else
-- Either code doesn't exist or the name doesn't match
return nil
end
end
end
--[[--------------------------< E X P O R T E D F U N C T I O N S >------------------------------------------
return {
alias_lister = alias_lister,
alias_names_get = alias_names_get,
canonical_param_lister = canonical_param_lister,
canonical_name_get = canonical_name_get,
cat_lister = cat_lister,
code_name_pair_exists = code_name_pair_exists,
error_cat_page_tally = error_cat_page_tally,
header_make = header_make,
help_text_cats = help_text_cats,
help_text_error_messages = help_text_error_messages,
id_limits_get = id_limits_get,
is_book_cite_template = is_book_cite_template,
is_limited_param_template = is_limited_param_template,
lang_lister = lang_lister,
maint_cat_page_tally = maint_cat_page_tally,
script_lang_lister = script_lang_lister,
single_ltr_2nd_lvl_domain_lister = single_ltr_2nd_lvl_domain_lister,
template_data_validate = template_data_validate,
uncategorized_namespace_lister = uncategorized_namespace_lister,
