Osborne Vixen Capacitor Replacement Guide
Replacing the original electrolytic capacitors in your Osborne Vixen is essential for long-term reliability, stable power rails, and protection of rare custom ICs. Ageing capacitors are a leading cause of power instability, video noise, and unpredictable system faults. Proactive recapping prevents catastrophic failures and preserves your Osborne for years to come.
editBefore starting, examine all electrolytic capacitors for:
- Bulging or domed tops – Indicates internal gas build-up and imminent failure.
- Leaking electrolyte – Brown or white crust at the base or on the PCB is a clear sign of leakage.
- Corrosion or PCB staining – Green or darkened areas around capacitor leads suggest leakage and urgent replacement.
- Unusual odours – A fishy or acrid smell can indicate vented electrolyte.
If any capacitor shows these symptoms, replace all electrolytics on the power supply, logic, and video boards. Even if no visual faults are present, original capacitors are now well past their design life.
Osborne Vixen Capacitor Lists
editThe Osborne Vixen uses a combination of through-hole and (in some units) SMD electrolytic capacitors across its power supply, logic, and video boards. Values may vary slightly between early and late production runs; always confirm against silkscreen and service manual.
Power Supply Board Electrolytic Capacitors
edit| Ref. Designator | Capacitance | Voltage | Notes |
| C1 | 220 µF | 250 V | Mains filter (high voltage, safety rated) |
| C2 | 220 µF | 250 V | Mains filter (paired with C1) |
| C3 | 4 700 µF | 25 V | +12 V output reservoir |
| C4 | 4 700 µF | 16 V | +5 V output reservoir |
| C5 | 1 000 µF | 16 V | -12 V output reservoir |
| C6 | 220 µF | 16 V | +12 V regulator decoupling |
| C7 | 220 µF | 16 V | -12 V regulator decoupling |
Note: Some Vixen PSUs may use a single 10 000 µF 16 V capacitor for the +5 V rail instead of C4. Replace with same or higher capacitance/voltage.
Logic Board Electrolytic Capacitors
edit| Ref. Designator | Capacitance | Voltage | Function |
| C10 | 10 µF | 16 V | Reset timing (power-on reset) |
| C11 | 1 µF | 50 V | Video sync coupling |
| C12, C13, C14 | 22 µF | 16 V | Local decoupling (RAM, CPU, video) |
| C15 | 47 µF | 16 V | Audio output coupling |
| C16 | 10 µF | 16 V | Serial port decoupling |
Some Vixen logic boards use axial capacitors for C10–C16; radial replacements are acceptable if lead spacing matches.
Video Board Electrolytic Capacitors
| VC1 | 47 µF | 16 V | Video output coupling |
| VC2 | 10 µF | 16 V | Sync decoupling |
| VC3 | 1 µF | 50 V | Video signal path |
If your Vixen has a separate video board, confirm values as silkscreened; some units combine video and logic functions.
edit- Power down and unplug the Vixen. Wait several minutes for capacitors to discharge.
- Remove the case – Unscrew rear and side fasteners, then carefully lift the top cover.
- Label all connectors (especially PSU and video) before unplugging.
- Discharge high-voltage capacitors (C1, C2) in the PSU with a resistor and insulated leads.
- Desolder each capacitor using braid or a pump. Take care with double-sided PCBs and fragile pads.
- Clean pads and inspect for damage or lifted traces.
- Install new capacitors, matching polarity and lead spacing. Observe correct orientation – long lead is positive.
- Trim excess leads and reflow joints for solid connections.
- Clean flux residue with isopropyl alcohol and a brush.
- Reassemble and double-check all connectors before powering up.
Recommended Tools & Parts
edit- Temperature-controlled soldering iron (60–80 W, 2 mm chisel tip)
- Desoldering pump and solder wick
- Multimeter with continuity and ESR test
- Isopropyl alcohol (99%) and antistatic brush
- High-quality 105 °C, low-ESR electrolytic capacitors (Nichicon PW/PS, Panasonic FR/FC, Rubycon ZLH)
- Insulated gloves and safety glasses (especially for PSU work)
- Resistor (10 kΩ, 2 W) for safe discharge of large PSU capacitors
Post-Recap Voltage & Ripple Checks
editAfter reassembly, verify power rails at the logic board edge connector:
| Test Point | Nominal Voltage | Acceptable Range | Max Ripple (p-p) |
| +5 V (logic) | 5.00 V | 4.85 – 5.15 V | < 50 mV |
| +12 V (floppy, video) | 12.00 V | 11.5 – 12.6 V | < 100 mV |
| -12 V (serial/audio) | -12.00 V | -11.5 – -12.6 V | < 100 mV |
Check with a multimeter and, if possible, an oscilloscope (20 MHz bandwidth) for ripple. Excessive ripple may indicate a missed or reversed capacitor.
Extra Tips
edit- Always replace PSU capacitors with equal or higher voltage and capacitance ratings.
- Check for PCB damage under leaky capacitors and repair traces as needed.
- Observe correct polarity – double-check before soldering, especially on the PSU.
- Do not substitute tantalum for high-value electrolytics in the PSU.
- Power up slowly using a variac or current-limited supply if available.
- Store the Vixen in a dry, cool environment to prolong capacitor life.
- Dispose of old capacitors responsibly at an electronics recycling centre.
