PLA Replacement Options
A Commodore 64 logic board. On a long board the PLA is the 28-pin device at U17; on the 250469 short board it is the 64-pin part at U8.
The PLA is the single most-replaced chip in a Commodore 64. This page covers what the part actually is on each board, and which replacements can be verified from their makers' own documentation.
Every product claim below is cited to the maker's own page.[1][2][3]
Which part is in your machine
This matters more than anything else on the page, because the "PLA" is a different device on the short board and most replacements do not fit it.[3]
The PLA by board assembly
Assembly Year Device Socket Notes
326298 1982 82S100 / 906114-01 U17 5-pin video connector board
250407 1983 82S100 / 906114-01 U17 Eight 4164 DRAMs
250425 1984 82S100 / 906114-01 U17 Reduced oscillator circuit
250466 1986 82S100 / 906114-01 U17 Two 41464 DRAMs; colour RAM is still a separate 2114 at U6
250469 Rev.A / 3 / 4 1987 251715-01, 64-pin U8 Colour RAM is a separate 2114 at U19
250469 Rev.B 252535-01, 64-pin U8 Colour RAM integrated; no 2114 at U19
The 251715 and 252535 are not PLAs in the 82S100 sense — they integrate the PLA and a set of discrete TTL functions into one 64-pin device, which is why they are often called the "SuperPLA". The 252535 additionally absorbs the 4 K colour RAM.[3]
A 28-pin DIP replacement for U17 will not fit U8, and vice versa. Replacements for the 64-pin part are a separate and much smaller field.
Replacements whose specification can be checked
SuperPLA V3 — Individual Computers
Jens Schönfeld reverse-engineered the C64 PLA and produced the SuperPLA; V3 unifies the earlier versions, with jumpers on the underside selecting the target machine.[1][2]
It adds no functionality — it is a repair part.[1]
SuperPLA V3 jumper settings, from Individual Computers
Machine Socket Jumpers
C64 assy 326298, 250407, 250425, 250466 U17 2 and 4 (as shipped)
CBM 610 U18 1 and 4
CBM 710 U18 1 only
C16 U16 none
C116 U101 none
plus/4 U19 none
1551 drive cartridge 1 and 3
PET UE5 only 2
Two limits stated by Individual Computers themselves:
  • Assembly 250469 is not supported. SuperPLA V3 does not replace the 64-pin part.[1]
  • On a PET, only socket UE5 is supported. The second PLA cannot be replaced with SuperPLA V3.[1]
The product is listed in Individual Computers' EOL category, so treat it as a second-hand purchase rather than a current stock item.[1]
The jumpers sit in the socket adapter on the underside and are, in Individual Computers' own words, tiny — fit them with tweezers, with good light, and take care not to break the adapter pins.[1]
PLA20V8 — Daniël Mantione
A deliberately low-cost, self-buildable design: two GAL20V8B devices from Lattice, in DIP packages, on a small PCB. One GAL cannot hold all the logic, hence two. The GAL20V8B is out of production but widely available second-hand, and can be programmed with the inexpensive TL866, so a repairer can keep several spares on hand without paying for someone else's assembly labour.[2]
The GAL's AND-then-OR array is structurally close to the original PLA; in the "simple" and "complex" modes its flip-flop is bypassed.[2]
Other replacements in circulation
Mantione, who surveyed the field while designing the PLA20V8, names RealPLA, PLAnkton, PLAdvanced and Ultimate PLA as existing replacements, and says that many of them are as good as or better than the original part.[2]
This wiki has not verified the logic device, current draw or compatibility list of any of those four against its maker's own documentation, and therefore states none. Do not assume that a specification you have seen attributed to one of them belongs to it — several of these products are described with each other's parts in online summaries.
EPROM-based substitutes
The earliest replacements used an EPROM holding the PLA truth table. Mantione lists the known disadvantages plainly: timing, risk of bus contention, switching noise and voltage levels. They work, but they are the weakest option and the one most likely to fail with cartridges.[2]
Fitting a replacement
  1. Power off and unplug the supply.
  2. The part at U17 on a long board is a 28-pin DIP — lift it with a DIP extractor or by easing each end alternately with a small flat blade. It is not a PLCC.
  3. Inspect the socket for oxidation and for pads lifted by earlier extraction attempts.
  4. Match pin 1 to the notch on the socket and the board silkscreen.
  5. Press home squarely; do not rock the part side to side, which bends pins under the body where you cannot see them.
  6. Power on and confirm a BASIC screen, then exercise the decode paths — load from disk, run a cartridge, and run a diagnostic. See Commodore Test Cartridge Index.
If you are fitting a replacement in a machine that also has a JiffyDOS or kernal switcher board, fit one thing at a time. Two changes at once turns a five-minute diagnosis into an afternoon.
  1. ↑ 1.0 1.1 1.2 1.3 1.4 1.5 1.6 Individual Computers, SuperPLA V3, https://wiki.icomp.de/wiki/SuperPLA_V3 . Source for what SuperPLA is and is not, the jumper settings, and the exact list of machines and sockets it supports. The page is filed under Individual Computers' EOL category.
  2. ↑ 2.0 2.1 2.2 2.3 2.4 2.5 Daniël Mantione, PLA20V8 — The Commodore 64 PLA that you can build yourself, https://www.freepascal.org/~daniel/c64pla/ . Source for the design being two GAL20V8B devices in DIP, programmable with a TL866; for the named disadvantages of EPROM-based substitutes (timing, bus contention, switching noise, voltage levels); for the attribution of the original reverse-engineering and of SuperPLA to Jens Schönfeld; and for the list of other replacements in circulation.
  3. ↑ 3.0 3.1 3.2 C64 Hardware Reference and Repair Guide (open_cerebrum), https://opencbm.org/doc/c64/hardware_reference_and_repair_guide/ . Community reference. Board-by-board component placement tables for assemblies 326298, 250407, 250425, 250466 and 250469, and the pinout and function of the 251715 / 252535 PLA/MMU. Secondary source, but the placement tables agree with Commodore's own schematics.
