Power Macintosh 8100 Logic Board Schematic
The Schematic, Main Logic Board Power Macintosh 8100/110 is Apple Computer's drawing 051-0333, revision A, scanned as 31 PDF pages. It covers the logic board of the Power Macintosh 8100/110.
Contents
Sheet list from the title sheet:
  • 1 Title and table of contents
  • 2 PowerPC 601 processor; 3 Address buffers and processor core regulator; 4 HMC memory controller; 5 Data path chips
  • 6–7 8 MB on-board DRAM; 8–9 DRAM SIMM sockets; 10 PDS, cache and ROM connectors; 11 Clocks
  • 12 I/O controller; 13 Curio; 14 Fast SCSI controller; 15 Serial (GeoPort) ports
  • 16 Cuda, power monitor and ADB; 17 Graphics DAC; 18 Monitor and ADB connectors; 19 AWACS sound circuit; 20 Floppy disk
  • 21 Terminators and resistors; 22 NuBus connectors; 23 BART NuBus controller; 24 Ethernet and GeoPort wake-up
  • Test points, and cross-reference tables on sheets 28–31, including a unit cross-reference that gives the type of every part
What it settles
  • Sheet 16: the 22-pin power supply connector J17 (+5 V, ground, −12 V, trickle 5 V, PFW and +12 V); battery BT1 3.6 V; connector J27, labelled as power for a Peltier-type active heat sink.
  • The cross-reference on sheet 29 lists 38 polarised capacitors (type CAP-P), all found on the drawing sheets; their values are used on Power Macintosh 8100 Capacitor Replacement Guide.
  • No bill of materials, so no Apple part numbers for the components.
  • Voltage ratings are not printed on the audio capacitors of sheet 19 or on several 10 µF parts, and the value of C60 on sheet 16 is faint.
  • Drawn for the 8100/110 board; the 8100/80 and 8100/100 are not covered separately. No power supply schematic.
Service procedures are in Power Macintosh 8100/ WS 8150 Service Source.
Pages that cite this document
Download: Power Macintosh 8100-110 logic board schematic (051-0333).pdf
