Programming Primer for the Macintosh 1995
Programming Primer for the Macintosh, Volume 1 by John C. May and Judith B. Whittle, AP Professional, an imprint of Academic Press (Harcourt Brace), 1995, ISBN 0-12-480621-X. The scan is 296 pages.
What it covers
Volume 1 of an introductory Macintosh programming primer.
This is not a repair source
This is a programming book. It contains no schematics, no parts lists, no component values, no voltages, no connector pinouts and no service procedures, and nothing in it should be cited for a hardware figure. Apple's software documentation and its compiler manuals describe the machine as the programmer sees it, which is not the machine the technician sees.
For hardware data use:
 level: specifications, symptom charts, take-apart and module part numbers
  • Apple's Developer Notes — the one class of Apple developer document that does carry
 rail currents, expansion-slot power budgets and connector pinouts. Several are held here, for
 example Macintosh IIci Developer Note, Macintosh IIsi Developer Note and
 Macintosh LC 475 and Quadra 605 Developer Note.
 the compact Macs
Download: Programming_Primer_for_the_Macintosh_1995.pdf (61.0 MB)
