Psion Series 3c
Psion Series 3c
A Psion Series 3c, open
DeveloperPsion PLC
ManufacturerPsion PLC
TypeClamshell palmtop / PDA
Released1996
Discontinued1998
CPUNEC V30H @ 7.68 MHz, in Psion's ASIC9
Memory1 MB ROM; 1 MB or 2 MB RAM
StorageTwo internal Solid State Disk (SSD) slots
Display480 ร— 160 monochrome LCD; backlit on later models
SoundMembrane speaker, built-in microphone, 12-bit sound recording
Dimensions165 mm ร— 85 mm ร— 22 mm
Weight275 g including batteries
OS / FirmwareEPOC16 (SIBO), with OPL
PredecessorPsion Series 3a
SuccessorPsion Series 3mx
Model no.There was never a Series 3b
The Psion Series 3c of 1996 is a refined Series 3a: same processor, same screen resolution, but with an infrared port, a changed serial port, revised built-in software and, on later machines, a backlight. Psion never released a Series 3b.[1]
What changed from the 3a
Series 3a โ†’ Series 3c[1][2]
Change Detail
Infrared port Added, and visible on the case
Serial port Changed โ€” the 3c uses the same arrangement as the Siena, and a serial cable for direct connection to a Windows PC was supplied. Travel Modem connections differ between 3/3a and 3c/3mx.
Serial speed Raised to 56,400 bit/s
Case Redesigned: badge moved centrally on the lid, fewer undulations, matte dark grey painted finish
Backlight Fitted to later models โ€” mainly, though not only, the US 2 MB machines
RAM 1 MB or 2 MB only
Application buttons 9 reprogrammable buttons, against the 3a's 8
Expansion Two internal SSDs plus an external PC-Card option
Software Several modifications to the built-in applications
Everything else โ€” the V30H at 7.68 MHz inside ASIC9, the 480 ร— 160 screen with its grey plane, the microphone and 12-bit sound recording, the 58-key keyboard, 2 ร— AA cells and the CR1620 backup cell โ€” is as the 3a.[2][1]
For the architecture itself โ€” ASIC9, the bank-switched memory, the hardware 32-bit RTC, the power states and the supply rails โ€” see Psion Series 3a.
The SSD door sensing
This is the one internal difference that matters for repair.
The 3c senses the state of its SSD slot doors using a set of PCB tracks and a small metal connector on the slot door hinge. The later 3mx replaced that with a pair of angled microswitches โ€” which is why the 3mx has a characteristic broken-switch fault that the 3c does not.[3]
On a 3c that will not see an SSD, clean the tracks and the metal door contact before suspecting anything else.
The sticky case
The 3c's redesigned case carries a rubberised soft-touch coating, and with age that coating degrades into something resembling glue. It is one of the first things a collector notices about a 3c that has been in a drawer since the 1990s.[4]
It is fixable โ€” see Psion Series 3c General Maintenance.
Easter egg
The 3c and the later 3mx contain an Easter egg: a hidden melody and credits screen.[1]
Known problems
As with the rest of the family: hinge breakage, button bar failure, screen cable deterioration producing vertical lines,[1] and the battery lead. Add to those the sticky case coating, which is specific to the 3c.
General maintenance
Hinge repair
  1. โ†‘ 1.0 1.1 1.2 1.3 1.4 "Psion Series 3", Wikipedia. Source for the model history, the absence of a 3b, the infrared port, the changed serial port, the case redesign, the backlight, the RAM options, the Easter egg and the documented clamshell problems.
  2. โ†‘ 2.0 2.1 "Psion specifications", netogram.com. Source for the comparative specifications including serial speed, ROM and RAM sizes, keyboard button counts and backlight availability.
  3. โ†‘ Richard Zealley, "Psion Series 3mx SSD door microswitch repair", Retro Coding, 25 May 2020. Source for the difference between the 3c's door-sensing tracks and the 3mx's microswitches.
  4. โ†‘ Community discussion of the Psion 3c sticky-case problem on comp.sys.psion.misc, together with established soft-touch coating restoration practice. Source for the degradation of the 3c's rubberised finish and the isopropyl alcohol stripping method and its cautions.
