RetroTechCollection:Citing sources
| This page documents an the RetroTechCollection guideline. Editors should generally follow it, though exceptions may apply. Substantive edits to this page should reflect consensus. When in doubt, discuss first on this guideline's talk page. |
Citing sources ensures technical information on RetroTechCollection can be verified and provides proper attribution to original creators. While not strictly required for all content, proper citations enhance credibility and help readers locate additional technical information.
When to Cite
[edit source]Strongly Recommended
[edit source]Citations are strongly encouraged for:
- Technical specifications - Voltage levels, timing parameters, component values
- Safety procedures - High-voltage precautions, chemical handling, discharge procedures
- Repair procedures - Diagnostic steps, calibration methods, troubleshooting flowcharts
- Historical information - Release dates, production numbers, design changes
- Performance data - Benchmark results, compatibility information, operating parameters
Required Citations
[edit source]Citations are mandatory for:
- Direct quotes - Any text copied verbatim from source material
- Copyrighted excerpts - Material used under fair use provisions
- Controversial claims - Information that might be disputed or challenged
- Safety-critical information - Procedures involving potential hazards
Citation Formats
[edit source]Service Manuals
[edit source]The most common source type for vintage hardware documentation:
{{cite manual
| title = Macintosh Plus Service Source
| publisher = Apple Computer, Inc.
| year = 1986
| pages = 45-47
| url = http://example.com/manual.pdf
For brief in-line citations:
The power supply outputs +5V and ±12V rails.<ref>{{cite manual |title=Apple IIe Service Manual |publisher=Apple Computer |year=1983 |page=23}}</ref>
Technical Datasheets
[edit source]For component specifications and technical parameters:
{{cite datasheet
| title = MC68000 16-Bit Microprocessor
| publisher = Motorola Semiconductor
| year = 1984
| part_number = MC68000L8
| url = http://example.com/datasheet.pdf
Books and Technical Publications
[edit source]For published technical references:
{{cite book
| last = Hertzfeld
| first = Andy
| title = Revolution in the Valley: The Insanely Great Story of How the Mac Was Made
| publisher = O'Reilly Media
| year = 2005
| isbn = 0596007191
| pages = 156-158
Web Sources
[edit source]For online technical resources:
{{cite web
| url = https://68kmla.org/bb/index.php?threads/macintosh-plus-repair-guide.12345/
| title = Macintosh Plus Repair Guide
| author = TechUser123
| website = 68kMLA Forums
| date = 2023-05-15
| access-date = 2025-01-07
Forum Posts and Community Sources
[edit source]For community-generated technical content:
{{cite forum
| url = https://forum.example.com/thread/12345
| title = SE/30 Capacitor Replacement Success
| author = VintageRepairGuy
| forum = Vintage Mac Repair Forum
| date = 2024-03-10
Simplified Citation Methods
[edit source]Basic Reference Tags
[edit source]For quick citations without formal templates:
The flyback transformer operates at 15.75 kHz.<ref>Apple Monitor II Service Manual, p. 34</ref>
Manufacturer Specifications
[edit source]For well-known technical specifications:
The Commodore 64 uses a 6510 processor running at 1.023 MHz.<ref>Commodore 64 User's Guide, 1982</ref>
Multiple Sources
[edit source]When information is confirmed by several sources:
The standard disk format uses 40 tracks per side.<ref name="multiple">Apple Disk II Manual, 1978; DOS 3.3 Reference, 1980; Beneath Apple DOS, 1981</ref>
Source Quality Guidelines
[edit source]Preferred Sources
[edit source]Listed in order of preference:
- Official service manuals - Manufacturer documentation for repair procedures
- Technical datasheets - Component specifications from manufacturers
- Engineering documentation - Schematics, design notes, technical bulletins
- Published technical books - Authoritative references by recognized experts
- Established technical websites - Sites with documented expertise and peer review
Acceptable Sources
[edit source]May be used with appropriate context:
- Community forums - When information is verified by multiple experienced users
- Technical blogs - Written by recognized experts with documented credentials
- Video documentation - When accompanied by written technical verification
- Personal experience - Clearly marked as such, preferably with supporting documentation
Sources to Avoid
[edit source]Generally not suitable for citations:
- Social media posts - Unless from official manufacturer accounts
- Wikipedia or other wikis - Use their sources instead
- Commercial listings - eBay, Amazon, or sales descriptions
- Unverified claims - Information without supporting documentation
- Speculation or rumors - Unconfirmed technical information
Technical Accuracy
[edit source]Verification Standards
[edit source]When citing technical information:
- Cross-check specifications - Verify against multiple sources when possible
- Note discrepancies - Document when sources disagree
- Update outdated information - Replace superseded technical data
- Specify conditions - Include operating parameters, tolerances, and limitations
Measurement Citations
[edit source]For technical measurements and test results:
{{cite measurement
| parameter = +5V rail voltage
| value = 5.02V ± 0.1V
| conditions = Room temperature, 2A load
| equipment = Fluke 87V multimeter
| date = 2024-06-15
| operator = TechUser456
Safety Information Citations
[edit source]Critical Safety Procedures
[edit source]Safety information must be properly sourced:
{{cite safety
| procedure = CRT discharge procedure
| source = RCA Service Manual X-2547
| warning_level = DANGER
| voltage = 25kV
| equipment = Insulated probe, safety glasses
Hazard Identification
[edit source]Document sources for safety warnings:
RIFA capacitors are prone to explosive failure.<ref>{{cite web |url=https://console5.com/wiki/RIFA |title=RIFA Capacitor Information |publisher=Console5 Wiki |access-date=2025-01-07}}</ref>
Citation Management
[edit source]Reference Lists
[edit source]Organize references at page bottom:
{{reflist}}
== Additional Reading ==
* [[Related Article One]]
* [[Related Article Two]]
* [https://external-resource.com External Technical Resource]
Reference Groups
[edit source]For different types of sources:
{{reflist|group=manuals}}
== Additional Sources ==
{{reflist|group=community}}
Named References
[edit source]For sources used multiple times:
<ref name="apple_manual">{{cite manual |title=Apple IIe Technical Reference |year=1982}}</ref>
Later in the article:
<ref name="apple_manual" />
Special Cases
[edit source]Orphaned Documentation
[edit source]For sources where copyright status is unclear:
{{cite manual
| title = Unknown Manufacturer Service Guide
| publisher = [Publisher unknown]
| year = circa 1985
| note = Copyright status uncertain - used under fair use for educational purposes
Foreign Language Sources
[edit source]For non-English documentation:
{{cite manual
| title = コンピュータ修理マニュアル
| trans-title = Computer Repair Manual
| language = Japanese
| publisher = Fujitsu
| year = 1984
Multiple Revisions
[edit source]When citing documents with multiple versions:
{{cite manual
| title = Commodore 64 Service Manual
| version = Revision C
| publisher = Commodore Business Machines
| year = 1983
| note = Supersedes Revision A and B
Linking and Access
[edit source]URL Guidelines
[edit source]When including web links:
- Use stable URLs - Prefer permalink or archive versions
- Check link validity - Verify links work before publishing
- Provide alternatives - Include archive.org links for unstable sources
- Note access requirements - Indicate if registration or payment required
Archive Citations
[edit source]For historical or hard-to-find sources:
{{cite web
| url = https://web.archive.org/web/20100615000000/http://example.com/manual.html
| title = Original Manual Page
| archive-url = https://web.archive.org/web/20100615000000/http://example.com/manual.html
| archive-date = 2010-06-15
Copyright and Attribution
[edit source]Fair Use Citations
[edit source]When using copyrighted material under fair use:
{{cite manual
| title = Proprietary Service Manual
| publisher = TechCorp Inc.
| year = 1987
| pages = 45-46
| note = Brief excerpt used under fair use for educational purposes
Permission Required
[edit source]For extensive use of copyrighted material:
{{cite manual
| title = Complete Technical Reference
| publisher = Hardware Inc.
| year = 1990
| note = Used with permission from copyright holder
| permission = Email dated 2024-05-15
Common Citation Errors
[edit source]Incomplete Information
[edit source]Avoid citations lacking essential details:
- Missing dates - Always include publication or access dates
- Vague titles - Use complete, specific titles
- No page numbers - Include specific page references for long documents
- Broken links - Verify all URLs before publishing
Over-Citation
[edit source]Don't cite unnecessarily:
- Common knowledge - Well-known technical facts don't require citations
- Basic specifications - Standard voltages, connector types widely documented
- Simple procedures - Basic maintenance steps don't need detailed sourcing
Under-Citation
[edit source]Always cite when needed:
- Unusual specifications - Non-standard or surprising technical information
- Safety procedures - Any procedure involving potential hazards
- Controversial information - Claims that might be disputed
Tools and Resources
[edit source]Citation Templates
[edit source]RetroTechCollection provides templates for common source types:
- {{cite manual}} - Service manuals and technical documentation
- {{cite datasheet}} - Component specifications
- {{cite web}} - Online resources
- {{cite book}} - Published references
- {{cite forum}} - Community sources
External Tools
[edit source]Helpful citation management tools:
- Archive.org - Wayback Machine for preserving web sources
- DOI lookup - For academic papers and formal publications
- ISBN databases - For book identification and verification
