Schneider DMP4000 Service Manual
The Kundendienst-Handbuch / Service Manual DMP 4000 is Schneider Computer Division's service manual for the DMP 4000 wide-carriage dot-matrix printer ā the DACH-region badge of the Amstrad DMP4000. Ident-Nr. 33984; the footer code is HDS 60964/2500/16/87, dating it to 1987. 14 pages, German and English in parallel, with a text layer.
Amstrad's own combined manual treats the DMP4000 as an eight-page appendix. This one is a dedicated DMP4000 manual with its own complete electrical parts list, and is the better source for the machine.
Contents
[edit | edit source]- p. 1 ā cover Ā· p. 2 ā cabinet parts list Ā· p. 3 ā cabinet drawing
- p. 4 ā mechanism parts list (print head 37 665 00-501, gears, springs, cable drives, tractors, carriage, platen)
- p. 6ā7 ā circuit diagram Ā· p. 8 ā control PCB Ā· p. 9 ā main PCB Ā· p. 10 ā wiring diagram Ā· p. 11 ā AC PCB and control PCB, with the mains-side safety warning
- p. 12 ā Electrical parts list: ICs, transistors, diodes and resistors
- p. 13 ā Capacitors, switches and miscellaneous including the fuses
- p. 14 ā Technische Daten, DIP-switch table and the Centronics interface pinout
The parts that matter on the bench
[edit | edit source]| Ref | Part | Schneider part no. |
| F1 | fuse T5A / 250 V | 124A0001-5000 |
| F2 | fuse T3.15 / 250 V | 124A0001-3150 |
| F3 | fuse T1A / 250 V | 124A0001-1000 |
| C101, C104 | 0.047 µF / 250 V metallised film | 102A0008-4725 |
| LF1 | mains filter choke, 1.3 mH | 108A1000-0001 |
| X1 | 11 MHz ceramic resonator | 111A0002-1160 |
| DSW1 | 8-way DIP switch | 107A0010-0801 |
| DSW2 | 10-way DIP switch | 107A0010-1001 |
| SW1āSW4 | tact switches | 107A0011-0112 |
| BZ1 | piezo bleeper | 114A0091-0001 |
| CN9 | 36-way Centronics socket | 109A0006-3603 |
| PT1 | photo-interrupter SPI 216 | P88010 |
| ā | HP (home position) sensor assembly | SP1300A56 |
| ā | PE (paper end) sensor assembly | SP1300A67 |
| IC1 | 7805 voltage regulator | 106A0003-7805 |
| IC12 | µPD7811 ā the printer's CPU | 106A0000-7811 |
| IC9 | 256K EPROM, 250 ns | 106A0001-2756 |
| IC11 | 6264-15 SRAM | 106A0001-6264 |
| BR1, BR2 | bridge rectifiers RS403L | 104A1003-0410 |
| D1, D5 | 1N6275 15 V transient suppressor | 104A2012-6275 |
| D8 | RD15 1 W zener | 104A2001-1150 |
| D35, D36 | RD47 1.5 W zener | 104A2001-2470 |
| TR3 | 2SD1196 | 105A0204-1196 |
| TR10 | 2SA1423 | 105A0101-1423 |
| R77, R78 | 7.5 Ī© 3 W | 101A0006-0751 |
The DMP4000 has three fuses ā T5A, T3.15A and T1A, all 250 V, all slow-blow. That is worth knowing before condemning a board: the DMP3000 has a different arrangement, and a dead wide-carriage machine is often one of these three.
The capacitor list in this manual is short by design. Only C101 and C104 appear, both 0.047 µF 250 V film parts on the mains side. The electrolytics are not itemised in this document ā if you are recapping a DMP4000, this manual will not give you their values, and this wiki has no other source that does.
Technical data, as printed
| Print system | Impact dot-matrix wire printer |
| Speed | 200 cps normal |
| Character matrix | ASCII table 1: 9 Ć 9; table 2: 18 Ć 9; special characters tables 3.1/3.2: 12 Ć 11 and 4.1/4.2: 24 Ć 11 |
| Character sets | 96 ASCII, 96 italic, 96 NLQ, 96 NLQ italic, 9 international sets, 132 special characters including IBM graphics |
| Columns | 136 standard (10 cpi), 163 elite (12 cpi), 233 condensed (17 cpi) |
| Line feed | 1/6, 1/8, 7/72 in, n/72 and n/216 in programmable; 1/6 in in 0.1 s |
| Paper | Continuous 7.5ā42 cm wide; single sheet 8ā39.5 cm wide |
| Interface | Parallel, Centronics-compatible |
| Mains | 220ā240 V, 50 Hz |
| Size and weight | 60 Ć 35 Ć 14 cm; 9.5 kg |
As on the DMP3000, the Centronics port sources +5 V at 50 mA maximum.
What it does not contain
[edit | edit source]No fault-symptom table, no adjustment or alignment procedure, and ā importantly ā no list of the electrolytic capacitors.
[edit | edit source]- Schneider DMP3000 Service Manual ā the narrow-carriage machine, with a full capacitor list
- Amstrad DMP2000 / DMP3000 / DMP4000 Service Manual Ā· Amstrad DMP1 Printer Service Manual Ā· Amstrad LQ3500 Printer Service Manual
- Schneider NLQ-401 Service Manual Ā· Capacitor Failure Symptoms
Download the Schneider DMP4000 Service Manual here: Schneider DMP4000 Service Manual.pdf (2.8 MB)
