Sega Mega Drive / Genesis (Model 2) Capacitor Replacement Guide
Recapping a Sega Mega Drive / Genesis Model 2 is vital for long-term reliability, crisp audio/video output, and stable operation. Aged electrolytic capacitors in these 16-bit consoles can cause distorted sound, video artefacts, random resets, or outright failure.
Before beginning, inspect the board for these common capacitor issues:
  • Bulging or domed tops – Indicates internal gas build-up and imminent failure.
  • Leaking electrolyte – Brown, green, or white residue near the base or leads.
  • Corrosion or PCB staining – Green or blackened areas around capacitor pads.
  • Audio hum or distortion – Often tracks to failed audio path capacitors.
  • Video interference or colour issues – Dried-out SMD caps near the video encoder.
  • Random resets or power loss – Power rail capacitors with high ESR.
If any capacitor shows trouble, replace all electrolytics on the board.
Mega Drive / Genesis Model 2 Capacitor List
Sega produced several Model 2 board revisions (VA0, VA1, VA2, VA3, VA4, VA5, VA6, VA7, etc.). Always verify values and locations against your board’s silkscreen, but the following covers the most common variants (VA1–VA4).
Mainboard Electrolytic Capacitors
Sega Mega Drive / Genesis Model 2 Mainboard Capacitor List
Ref. Designator Capacitance Voltage Typical Purpose
C1 1000 µF 16 V Main +5 V input filter (power supply smoothing)
C2 470 µF 16 V Secondary +5 V filter (local decoupling)
C3 220 µF 10 V Audio path (preamp coupling)
C4 10 µF 16 V Audio path (mixing/decoupling)
C5 10 µF 16 V Audio path (mixing/decoupling)
C6 47 µF 16 V Video encoder supply filter
C7 1 µF 50 V Video path (composite coupling)
C8 1 µF 50 V Video path (luma/chroma coupling)
C9 4.7 µF 50 V Video path (encoder input/output)
C10 10 µF 16 V Reset circuit (RC timing)
C11 22 µF 16 V Audio path (DC-blocking)
C12 22 µF 16 V Audio path (DC-blocking)
C13 47 µF 16 V RF modulator supply (if fitted)
C14 220 µF 10 V Audio output coupling
C15 100 µF 16 V Power rail decoupling (varies by board)
Some VA7 boards use SMD (surface-mount) capacitors with slightly different values (e.g., 330 µF instead of 470 µF). Always match the original values and voltage ratings where possible.
Additional Board-Specific Notes
  • VA0/VA1 boards may have extra or omitted capacitors; check for C16–C18 (typically 10–47 µF, audio/video path).
  • PAL vs NTSC boards sometimes use different reference numbers or omit the RF modulator (C13).
  • SMD variants (VA7) – Use quality SMD replacements or carefully fit radial types if SMD are unavailable.
Recapping Procedure
  1. Disassemble the console: Remove the six case screws, separate the halves, and unplug the controller ports and LED wires.
  2. Remove shielding and mainboard: Unscrew and lift out the RF shield (if fitted), then the mainboard.
  3. Label all connectors: Take photos or label cables to ensure correct reassembly.
  4. Desolder each capacitor: Use solder-wick and flux. SMD caps require gentle heat and careful removal to avoid lifting pads.
  5. Clean pads thoroughly: Remove old flux and leaked electrolyte with isopropyl alcohol and a soft brush.
  6. Install new capacitors: Match polarity (long lead = positive, stripe = negative) and lead spacing. For SMD, align carefully and reflow both ends.
  7. Trim excess leads and inspect: Ensure no solder bridges or cold joints.
  8. Reassemble and test: Refit the board, reconnect all cables, and reassemble the case.
  • Temperature-controlled soldering iron (60–80 W, fine tip)
  • Desoldering pump and solder-wick
  • Isopropyl alcohol (IPA, 99%) and antistatic brush
  • Multimeter (for continuity and voltage checks)
  • ESR meter (optional, for in-circuit cap testing)
  • Quality 105 °C, low-ESR capacitors (e.g., Nichicon PW/PS, Panasonic FR/FC, Rubycon ZLH)
  • Tweezers and precision side-cutters
  • Kapton tape (to insulate capacitors near the RF shield)
  • Protective eyewear and ESD wrist-strap
Post-Recap Voltage / Ripple Checks
After recapping, verify voltage rails at key points:
Expected Voltage Rails – Sega Mega Drive / Genesis Model 2
Test Point (scope @20 MHz) Typical Value Max Ripple (p-p)
+5 V (mainboard input) 4.90 – 5.10 V < 50 mV
+5 V (video encoder Vcc) 4.85 – 5.10 V < 50 mV
Audio output (DC offset) < 50 mV negligible
If you observe visible video noise or audio hum, check for excessive ripple or incorrect capacitor orientation.
Extra Tips
  • Always double-check polarity before soldering. Incorrect installation can cause immediate failure.
  • Use high-quality capacitors – low-ESR, 105 °C rated, from reputable brands.
  • Clean up all leaked electrolyte – it is corrosive and will damage traces if left.
  • If using SMD replacements, ensure correct orientation and avoid overheating pads.
  • Test the console with a known-good PSU – a failing external adapter can damage new capacitors.
  • If audio remains distorted after recapping, check the headphone amp IC (often a 4558 or NJM2113) as it may also fail with age.
  • Consider recapping the power supply if using an original Sega AC adapter – these also contain ageing electrolytics.
