Sinclair ZX80 General Maintenance
The Sinclair ZX80 is a classic home computer, and with careful maintenance, it can remain reliable for decades. This guide covers essential care, preventive steps, and troubleshooting for all ZX80 board revisions. Always observe ESD (Electrostatic Discharge) precautions when handling the PCB or components—use a grounded wrist strap and work on an antistatic mat. Regular maintenance intervals:
  • Visual inspection: Every 12 months
  • Capacitor check: Every 2–3 years
  • Full electrical test: Every 5 years or after storage
Sinclair ZX80 Mainboard (Issue 2)
Board Revisions
Revision PCB Markings Notable Differences Common Issues
Issue 1 "ZX80 ISSUE ONE" silk Early production, hand-wired mods Poor video sync, regulator overheating
Issue 2 "ZX80 ISSUE TWO" silk Improved video, revised regulator layout Keyboard connector wear, RAM instability
Power Supply & Regulator Care
The ZX80 uses a simple linear power supply:
  • PSU Part: Sinclair 9V DC Adapter (center negative)
  • Specs: 9V DC, 700–1000mA, 2.1mm barrel
  • On-board Regulator: 7805 (IC3) 5V linear
  • Common Failure Modes:
    • PSU cable splits or shorts
    • 7805 overheating or output drift
    • Capacitor (C4, C5) leakage or bulging
On-board Capacitor Designators:
  • C4, C5: Smoothing and decoupling for 7805
  • C1, C2, C3: Logic supply filtering
Capacitor Replacement Table
Position Value Voltage Notes Series/Type
C1 22μF 16V Logic rail smoothing Axial, low ESR
C2 1μF 16V Video circuit Tantalum or electrolytic
C3 0.1μF 50V Noise bypass Ceramic disc
C4 100μF 16V 7805 input Axial, low ESR
C5 100μF 16V 7805 output Axial, low ESR
Voltage & Clock Test Points
Test Point IC/Pin Expected Value (±Tolerance)
5V Rail IC3 (7805) Output 5.00V ±0.15V
9V Input C4 (+) 9.0V ±0.5V
CPU Clock IC1 (Z80) Pin 6 3.25MHz ±0.05MHz
Video Sync IC5 Pin 3 5Vpp square wave
Essential Tools
  • Antistatic wrist strap & mat
  • Multimeter (with continuity and voltage)
  • Oscilloscope (≥10MHz, for clock/video)
  • Soldering iron (fine tip, ESD safe)
  • Solder sucker or wick
  • Small flat and Phillips screwdrivers
  • IC extractor
  • Fine tweezers
  • Isopropyl alcohol & brush (for cleaning)
  1. Power off and unplug the unit.
  2. Discharge static and open the case.
  3. Inspect PCB for corrosion, broken traces, or burnt components.
  4. Check all capacitors for bulging or leakage.
  5. Verify keyboard membrane and connector for cracks.
  6. Clean dust and debris with a soft brush.
  7. Test PSU output voltage before connecting.
  8. Reseat all socketed ICs gently.
  9. Inspect solder joints for cracks ("dry joints").
  10. Reassemble and test operation.
Common Faults & Quick Checks
Symptom Likely Cause Quick Check
No power PSU or 7805 failure Measure 9V in, 5V out at IC3
No video C2, IC5, or ULA fault Scope video out, check C2
Keyboard dead Membrane or connector Inspect for cracks, reseat
Random resets C1, C4, or RAM Replace caps, test RAM
Overheating 7805 or shorted cap Check C4/C5, IC3 temp
Troubleshooting Flowcharts
  1. No Power
    1. → Check PSU output (9V)
    2. → Check 7805 output (5V)
    3. → If 5V missing, replace 7805 and C4/C5
    4. → If still dead, inspect PCB for shorts
  1. No Video Output
    1. → Confirm 5V present
    2. → Test C2 and IC5 (video circuit)
    3. → Swap ULA if available
    4. → Inspect video connector and cable
  1. Keyboard Not Responding
    1. → Inspect membrane for cracks
    2. → Clean and reseat connector
    3. → Test continuity across matrix
  1. Random Freezing/Resets
    1. → Replace C1, C4, C5
    2. → Test RAM ICs
    3. → Check for dry joints on IC sockets
