This guide provides a thorough, step-by-step process for diagnosing, removing, cleaning, and replacing the ZX Spectrum keyboard membrane (both "rubber-key" 16/48K and 48K+/128K / Spectrum+ variants), including advanced troubleshooting and upgrade options.
The Spectrum keyboard relies on a multi-layer printed plastic membrane; pressing a key bridges conductive traces to signal the row/column. Over time, these membranes become brittle or delaminate, and the ribbon "tails" frequently crack, resulting in unresponsive keys.
1. Insert the membrane into the support plate in the same orientation as the original. Ensure conductive pads lie flat and align over PCB contact areas.
2. Route ribbon tails in a gentle “S-shape” to avoid strain; this is critical for Plus membranes.
3. Seat tail ends fully and clamp; ensure clamps are neither loose nor overtightened.
For Spectrum+, confirm clamp assembly is correct—misalignment leads to extended key malfunctions.
4. Apply insulating tape if the ribbon tail contacts the RF modulator—this can cause failures even without electrical contact.
