Tandon TM100-2
Tandon TM100-2
Tandon TM100-2A (photo: Mister rf, CC BY-SA 4.0)
Manufacturer Tandon Corporation
Type Full-height 5.25-inch floppy disk drive, double-sided, 48 TPI
Interface 34-pin edge connector; 4-pin AMP power connector
Compatible IBM PC (5150), IBM 5155, IBM PC XT (5160)
Dimensions 86 x 149 x 203 mm (IBM)
Weight 2.04 kg (IBM)
Predecessor Tandon TM100-1
Model TM100-2, TM100-2A
Storage 500 KB unformatted; 320 KB under DOS 1.1, 360 KB under DOS 2.0 and later
Media 5.25-inch double-sided double-density soft-sectored diskette, 40 tracks per side
The Tandon TM100-2 is a full-height 5.25-inch double-sided floppy disk drive with 40 tracks per side at 48 tracks per inch. It is the two-head version of the Tandon TM100-1, and Tandon documents both in one manual.[1] It was used as the "360K" drive in the IBM PC (5150), the IBM 5155 Portable and the IBM PC XT (5160); a later version is marked TM100-2A.[2] IBM first called it the "320 KB Diskette Drive", because DOS 1.1 formats 8 sectors per track; DOS 2.0 and later format 9 sectors per track, giving 360 KB.[3]
Tandon TM100-2 specifications
Parameter Value
Heads 2
Tracks 80, 40 per side, at 48 TPI
Track spacing 0.529 mm (20.8 mil)
Unformatted capacity 500 KB per disk
Recording modes FM, MFM, MMFM
Data transfer rate 250,000 bit/s, double density
Flux reversals per inch, inside track 5,535 side 0; 5,877 side 1
Rotational speed 300 RPM ± 1.5 % (295.5 to 304.5 RPM)
Instantaneous speed variation ± 3 %
Average rotational latency 100 ms
Motor start / stop time 250 ms / 150 ms maximum
Seek time, track to track 5 ms
Head settling time 15 ms
Average access time, including settling 75 ms
Head life 20,000 media contact hours
+12 V supply ± 0.6 V, 900 mA average, 100 mV peak-to-peak ripple
+5 V supply ± 0.25 V, 600 mA average, less than 100 mV peak-to-peak ripple
Hard error rate 1 in 1012 bits
Seek error rate 1 in 106 seeks
MTBF / MTTR 8,000 hours at 25 % duty cycle / 30 minutes
Operating temperature 10 °C to 46 °C
Operating humidity 20 % to 80 %, non-condensing
All figures are from Tandon's Tables 2-1 to 2-3, pp. 2-2 to 2-4.[1] IBM's own reference for the drive it sold gives some looser figures: 6 ms track to track, 500 ms maximum start time, and ± 5 % on both supplies.[4]
DC power enters on a four-pin AMP connector, J2: pin 1 +12 V, pin 2 +12 V return, pin 3 +5 V return, pin 4 +5 V. A 3/16-inch quick-disconnect lug takes the chassis ground from the controller, and Tandon says the chassis should be earthed for proper operation (p. 3-5).[1]
Configuration and termination
Drive address and options are set by a programmable shunt (AMP 435704-7) in a DIP socket at location 1E on the logic board; its positions can be cut, or it can be replaced by a DIP switch (pp. 3-5 to 3-8, Figure 3-3).[1]
Tandon TM100 option jumpers
Jumper Function Setting
DS0-DS3 Drive select Cut all except the one that addresses this drive
MX Multiplex: keeps the drive logic enabled at all times Single-drive systems only; cut in multi-drive systems
HS, HM Not used Cut
W2, W3 Write flip-flop set and preset lines W2 standard
W4, W5 Write-protect switch W4 standard (write protect enabled)
RP1 Terminator resistor pack Fitted in the last drive on the cable only
The IBM PC's floppy cable swaps the drive-select and motor-on lines between its two drive connectors, so both drives are jumpered alike and the cable decides which is A:.[3] minuszerodegrees warns that some wrong termination arrangements cause faulty drive operation.[2]
Common faults
The faults below are the ones minuszerodegrees lists for the drive in IBM machines.[2] Before blaming the drive, substitute a known-good one to rule out the controller, the cable and dirty edge connectors.
Hardened rail lubricant
The lubricant on the rails the head carriage slides on hardens, and the carriage moves stiffly or not at all. With the power off, the carriage should slide freely by hand against slight resistance from the stepper motor. The site's author cleans the old lubricant off and re-lubricates with a silicone-based lubricant, grease or spray, which he and others have found satisfactory, and treats a clean and re-lube as worthwhile even when it does not cure the fault.[2] Tandon's manual contains no lubrication instruction.
minuszerodegrees also records that some owners with a stepper motor that would not step properly freed it with WD-40.[2]
Head contamination
Old disks whose oxide wipes off can leave a thick deposit on the heads. The minuszerodegrees author notes that a cleaning diskette may need 20 to 50 passes to clear it, and uses isopropyl alcohol on a cotton tip instead, taking care not to damage the heads; a thick layer has taken him a couple of minutes to remove. He warns that cleaning diskettes are abrasive, and that a drive cleaned after a bad disk will be fouled again if that disk goes straight back in.[2] That is his practice, not Tandon's.
Drive overloads the host power supply
If a TM100-2A shorts the PC's supply, minuszerodegrees names the two tantalum capacitors C36 and C43, each 4.7 µF 16 V, as the first suspects. An aluminium electrolytic of the same value, or a 25 V part, will do as a replacement. Fit it with the positive lead in the hole marked "+".[2] See Capacitor Failure Symptoms.
Spindle speed
The specification is 300 RPM ± 1.5 %, 295.5 to 304.5 RPM. Adjust R4 on the servo board at the rear of the drive.[1][2] minuszerodegrees gives three ways to measure the speed: the frequency at pin 2 of the servo board's LM2917 on a digital oscilloscope; ImageDisk's Test RPM command; or the 50 Hz and 60 Hz strobe rings on the spindle flywheel under strong mains-powered fluorescent light, using the ring that matches the local mains frequency. It also records a speed fault cured by tightening a loose spindle flywheel screw, and suggests the spindle may need lubrication.[2]
Track 0 switch
The TM100's Track 0 sensor is a mechanical switch, operated by the head carriage between tracks 0 and 3 (p. 4-3).[1] minuszerodegrees quotes Chuck(G) of the VCFed forum: "I've found that many of the 'alignment' issues on Tandon 100s to be not alignment per se, but a dirty track 0 sensor."[2] Check it before touching any alignment.
Bent test-point posts
The logic board's test points are upright posts. On a drive that has been badly stored or shipped, one may be bent over onto other circuitry.[2]
Dirty hub clamp
minuszerodegrees links a case from the VCFed member Tezza in which a dirty hub clamp caused the fault.[2]
If the drive treats every disk as write-protected, or none, check the switch (section 5.4, p. 5-3). With power off and a disk without a write-protect tab inserted, there should be continuity between the two wires of Plug 8; with a write-protected disk, none. Test Point 9 should be high for a write-protected disk and low otherwise; if the switch tests good and TP9 is wrong, suspect the logic board. The switch is moved up or down on its bracket to adjust it.[1]
Head alignment
Alignment drift happens over many years but not on every drive. minuszerodegrees identifies it by two signs together: disks formatted in the drive read back in the same drive, but good disks formatted on a known-good drive will not read. The author advises against attempting an alignment without that evidence, because a failed attempt can leave the drive worse.[2]
Alignment and adjustment
Tandon's checks need a dual-channel oscilloscope and a certified alignment diskette, Dysan 224/2A or equivalent. The alignment diskette and drive must stabilise at room temperature for one hour first (p. 5-6).[1]
Tandon TM100 checks and tolerances
Check Tolerance Adjustment Manual
Drive motor speed 300 RPM ± 1.5 %; the 60 Hz ring of the speed disk on the spindle pulley stands still under fluorescent light R4 on the servo board pp. 5-3 to 5-5
Radial track alignment Cat's eye at track 16 on each head: smaller lobe not less than 75 % of the larger. Track 16 is 1.9167 in from the hub centre Head module retaining and cam screws pp. 5-6 to 5-9
Index to data 200 ± 100 µs Index sensor retaining screw pp. 5-9 to 5-10
Head azimuth Within ± 18 minutes on the third burst at track 34, each head Not adjustable: replace the module assembly p. 5-11
Track 0 switch and stop As described Switch position; stop pp. 5-12 to 5-13
Head output, cone centring As described Check only pp. 5-13 to 5-14
Drive belt
The spindle is belt-driven by a DC motor. Tandon's part number for the belt is 914000-001 (Appendix A, p. A-1). To replace it, turn the drive over with the spindle up, remove the old belt, loop the new one shiny side inward onto the small flanged motor pulley, then turn the spindle while working it onto the large spindle pulley (p. 6-7, Figure 6-1).[1]
Media
The drive needs double-sided, double-density 5.25-inch diskettes, and the IBM floppy adapter adds the requirement that they be soft-sectored. These are the disks sold as "360K", with an unformatted capacity of 500 KB.[2][4] A double-density disk written or formatted in a high-density 1.2 MB drive does not conform to the double-density standard and may not read in a TM100-2.[2]
  1. ↑ 1.00 1.01 1.02 1.03 1.04 1.05 1.06 1.07 1.08 1.09 Tandon Corporation, OEM Operating and Service Manual, TM100-1, TM100-2 Disk Drives, 48 Tracks Per Inch, part number 179022-001 Rev. B, 1983 (printed 7-83), hosted as File:Tandon TM100-1 TM100-2 48TPI Operating and Service Manuals 1983.pdf.
  2. ↑ 2.00 2.01 2.02 2.03 2.04 2.05 2.06 2.07 2.08 2.09 2.10 2.11 2.12 2.13 2.14 minuszerodegrees.net, "Tandon TM100-2 in IBM 5150/5155/5160 - Known Problems/Issues" (retrieved 2026-10-01). The site author's own repair notes on the drive.
  3. ↑ 3.0 3.1 minuszerodegrees.net, "IBM 5150 - Floppy Drive Support" (retrieved 2026-10-01). IBM's name "320 KB Diskette Drive", the 320 KB and 360 KB formats, BIOS and controller support, and the IBM floppy cable that swaps the drive-select and motor-on lines.
  4. ↑ 4.0 4.1 IBM, Personal Computer Hardware Reference Library: IBM 5-1/4" Diskette Drive, part number 6361486, p. 3, hosted as File:IBM Options and Adapters - IBM 5.25-inch Diskette Drive.pdf. Mechanical and electrical specifications, including dimensions and weight; logic diagrams for three drive types on pp. 5-12.
