Template:R mentioned in hatnote
When used with the "Redirect category shell" (Rcat shell) template:
This page is a redirect. The following categories are used to track and monitor this redirect:
- Template {{Redirect category shell}} may be used to add one or more rcat templates, along with their parameters and categories, to a redirect. For more information, see the documentation page below.
When used by itself:
- Mentioned in a hatnote: This is a redirect from a title that is mentioned in a hatnote at the redirect target. The mention is usually atop the target article. It may, however, be directly under a section header, or in another article's hatnote (whenever the hatnote is under a section, {{R to section}} should also be used).
- The titles of redirects mentioned in hatnotes may refer to a subject other than that of the target page. It is possible that this redirect may need to be retargeted, or become an article under its own title (see {{R with possibilities}}). If the title is a good candidate for a Wiktionary link, it may also be added.
