VAX-11/780 Power System Service
VAX-11/780 with the doors open; the H7100 supplies sit in a row below the CPU card cage (Patrick Finnegan, CC BY 2.0)
The power system of the VAX-11/780: the cabinet power controllers and the power control bus, the H7100 DC supplies and their regulators, and the battery backup units. It is drawn from DEC's VAX-11/780 Power System Technical Description (EK-PS780-TD-001), the H7100 print set (MP-00480) and DEC's field service troubleshooting guide.[1][2][3]
Warning: the main cabinet takes three-phase mains at 120/208 V or 240/416 V and up to 150 A per phase at switch-on.[4] On systems with 866 or 861 power controllers, one phase is unswitched: it keeps feeding the H7112 memory battery backup, the memory power supply, the H7111 clock battery supply and one blower even after an emergency shutdown on the power control bus.[5] Disconnect each cabinet at the wall before working inside it.
Power controllers and the power control bus
Each cabinet has its own power controller, fed from its own customer receptacle.[1]
VAX-11/780 power controllers (DEC section 1.3)
Cabinet Shipped before Later
Main and SBI cabinets, 120/208 V 866D (before June 1978) 869D
Main and SBI cabinets, 240/416 V 866E 869E
Unibus expansion, 120 V 861C (before September 1978) 869C
Unibus expansion, 240 V 861B 869B
[1]
The controllers are chained by the three-wire power control bus, which meets DEC Standard 123: pin 1 power request, pin 2 emergency shutdown, pin 3 ground. Connecting line 1 to ground energises the controller's contactor and switches on its outlets; connecting line 2 to ground disconnects all of its switched outlets. With the controller's LOCAL/OFF/REMOTE switch at LOCAL, lines 1 and 3 are joined.[6][5] The whole system is switched from the five-position key switch at the right of the main cabinet's control panel, which also carries ATTN, RUN, POWER and REMOTE lamps and an AUTO RESTART switch.[7]
869D and 869E controllers (DEC Table 2-2)
Item 869D 869E
Input 3-phase, 90–132 V phase to neutral 3-phase, 180–264 V phase to neutral
Current 24 A per phase 12 A per phase
Circuit breaker 30 A per pole, 4 poles 15 A per pole, 4 poles
Outlets 9 duplex, 120 V 20 A, J11–J19 9 duplex, 240 V 15 A, J11–J19
Overtemperature switch Opens the contactor at 71 °C, resets at 49 °C Same
[8][6]
DEC's caution is that no load outside the cabinet is to be plugged into a controller.[6] On an 866, the overtemperature sensor shuts down the switched outlets only; on an 869 it shuts down the whole cabinet, independently of the power control bus, while other cabinets keep running.[9] Each blower in the main cabinet, normally three, has its own air flow sensor.[10]
H7100 DC power supplies
Up to six H7100 supplies fit in the main cabinet. A minimum "C" configuration uses three, a "D" configuration four, and an FP780 floating point accelerator adds one more.[11] Each supply has a thermal sensor on its output transistor heat sink.[5]
H7100 specifications (DEC Table 2-6)
Item Specification
Input Single phase, 90–128 V or 180–256 V rms, 47–63 Hz; 10 A at 120 V, 5 A at 240 V; 1200 VA
Inrush 80 A peak for half a cycle
Input protection 2-pole circuit breaker, 20 A per phase
Output power 500 W
Base supply +5.1 V at 10–100 A
H7101 regulator option −5.2 V at 3–30 A
H7102 regulator option +12 V at 1–10 A
H7103 regulator option +5.0 V at 2–20 A and −5.0 V at 0–0.2 A (battery-backed)
Regulation ±5% on all outputs
Cooling External forced air at 2.22 m/s
Size and weight 17.8 × 27.9 × 40.6 cm, 15.9 kg
[12]
Status indicators
H7100 front-panel indicators
Indicator Meaning
POWER NORMAL (green) Outputs correct
PLUG-IN REGULATOR FAILURE (red) Fault in one or more of the plug-in regulators: +5 V, +5 VB or −5 VB, +12 V
OVERCURRENT (red) +5 V load of 120 A or more
OVERVOLTAGE (red) +5 V at 6.2 V or more
POWER INVERTER FAILURE (red) Main +5 V inverter failed
OVERTEMPERATURE (yellow reflective flag) Internal temperature of 150 °F (66 °C) or more
[13][3]
Replacing supplies and regulators
DEC's field kit held a configurable H7100 (the base supply with its bias/control board, giving +5.1 V), an H7101 −5.2 V regulator board (5412560) and an H7102/H7103 +12 V and ±5 V battery-backed regulator board (5412556/5412558). DEC's guidelines:[14]
  1. A failed regulator board is replaced with the board from the kit.
  2. A failed base supply is replaced with the kit's H7100.
  3. If the base supply has failed but its regulators are good, the regulators are moved into the new H7100: remove the blank J6 or J7 from the new supply, reconnect the regulators with the old supply's cables, fit J6 or J7 in the rear panel cut-out, reuse the old insulator boards and fit the decal that shows the regulator complement (3614762-00 for an H7101, 3614762-01 for H7102 and H7103).
The cables were ordered separately: 7014545 (12-wire output, H7101), 7014546 (output harness, H7102/H7103), 7014548 (7-wire input, H7103) and insulator board 1700021-04.[14]
Board electrolytics
The H7100 print set lists these aluminium electrolytics on the supply's three circuit boards:[2]
H7100 circuit board electrolytics (print set MP-00480)
Board Reference Value Rating DEC part
Motherboard 54-12550 (rev. H) C5, C6 2800 µF 55 V 1014337-00
Bias/control 54-12554 (rev. M) C5–C8 560 µF 20 V 1012607-00
Bias/control 54-12554 (rev. M) C11 600 µF 25 V 1011849-01
Status card 54-12562 (rev. C) C1, C2 8 µF 25 V 1012084-01
Status card 54-12562 (rev. C) C4 25 µF 25 V 1000075-00
[15][16][17]
The bias/control board also has solid tantalums (1 µF 35 V at C10, C49, C104 and C105, among others).[16] Read the values printed on any capacitor mounted off these boards before ordering.
Battery backup units
Both battery units use sealed lead-acid batteries, DEC 12-12499-00. DEC gives the H7111 battery's shelf life as 40 days at 70 °C and 6000 days at 0 °C.[18][19]
Battery backup supplies (DEC Tables 2-8 and 2-9)
Item H7111 time-of-day clock supply H7112 memory battery backup
Input 90–128 V (H7111A) or 180–256 V (H7111B) 90–128 V or 180–256 V, 50 or 60 Hz
Input fuse 1/8 A slow-blow 1.0 A (120 V) or 0.5 A (240 V) slow-blow
Output +5 V, 0–25 mA 27–45 V DC, 250 W
Batteries One, 5 Ah, 2 A fuse Three in series (30–48 V), 15 A fuse
Charge time Under 24 hours to 90% 16 hours maximum to 90%
Backup time 100 hours minimum 10 minutes minimum
[18][19]
Power-fail signals
The power monitoring signals of the console's H780 supply and of H7100 supplies 1, 2 and 3 are ORed into the LSI-11 console's BPOK and BDCOK lines. DEC's troubleshooting guide says the H7100 AC LO and DC LO signals should sit at −9.5 V or more negative for proper noise immunity; noisy or marginal levels cause false power-fail traps in the console.[20] See VAX-11/780 Troubleshooting Guide.
Restoration experience
A German museum restoring a VAX-11/780-compatible Robotron K 1840 had its power supplies repaired before the machine could be switched on, and checked every board for shorts before applying power. Another owner planned to dismantle and test his five supplies one at a time, and built a new power distribution unit so that the cabinet could run from 120/240 V split-phase instead of 120/208 V three-phase.[21] DEC's own power-up order is on VAX-11/780 Maintenance Guide.
  1. ↑ 1.0 1.1 1.2 Digital Equipment Corporation, VAX-11/780 Power System Technical Description, EK-PS780-TD-001, March 1979, p. 1-1 (File:VAX-11 780 Power System Technical Description (EK-PS780-TD-001).pdf). Controllers, key switch, H7100 supplies.
  2. ↑ 2.0 2.1 Digital Equipment Corporation, H7100 power supply field maintenance print set, MP-00480, January 1983 (File:VAX-11 780 H7100 Power Supply Print Set (MP-00480, January 1983).pdf).
  3. ↑ 3.0 3.1 Digital Equipment Corporation, Guide to VAX-11/780 System Troubleshooting, EY-2217E-SG-0001, November 1985, p. 7-13, H7100 Power Regulator LEDs (File:Guide to VAX-11 780 System Troubleshooting (EY-2217E-SG-0001).pdf).
  4. ↑ DEC, EK-PS780-TD-001, pp. 2-1 to 2-2, Table 2-1. Main cabinet power and surge current.
  5. ↑ 5.0 5.1 5.2 DEC, EK-PS780-TD-001, p. 3-19. Power control bus operation; unswitched phase on 866 and 861 systems; thermal sensors.
  6. ↑ 6.0 6.1 6.2 DEC, EK-PS780-TD-001, pp. 2-4 to 2-5, Table 2-2 (cont.). Thermoswitch, power control bus pins, outlets and loads caution.
  7. ↑ DEC, EK-PS780-TD-001, pp. 3-1 to 3-2, Figure 3-1, VAX-11/780 control panel.
  8. ↑ DEC, EK-PS780-TD-001, p. 2-3, Table 2-2. 869D/E input, current and circuit breakers.
  9. ↑ DEC, EK-PS780-TD-001, p. 3-87, section 3.4.4. Power controller overtemperature sensor.
  10. ↑ DEC, EK-PS780-TD-001, p. 3-88, section 3.4.5. Air flow sensors.
  11. ↑ DEC, EK-PS780-TD-001, pp. 3-88 to 3-89, section 3.5.1. H7100 supplies by configuration.
  12. ↑ DEC, EK-PS780-TD-001, pp. 2-13 to 2-14, Table 2-6, H7100 DC Power Supply Specifications.
  13. ↑ DEC, EK-PS780-TD-001, p. 2-15, Table 2-6 (cont.). Status indicators.
  14. ↑ 14.0 14.1 DEC, EK-PS780-TD-001, pp. B-1 to B-2, appendix B, H7100 power supply and regulator replacement.
  15. ↑ DEC, MP-00480, motherboard STAR (H7100) parts list 5412550-0-DBP, revision H (PDF p. 29).
  16. ↑ 16.0 16.1 DEC, MP-00480, H7100 bias control parts list 5412554-0-DBP, revision M, sheet A1 (PDF p. 35).
  17. ↑ DEC, MP-00480, status card parts list 5412562-0-DBP, revision C (PDF p. 20).
  18. ↑ 18.0 18.1 DEC, EK-PS780-TD-001, pp. 2-19 to 2-20, Table 2-8, H7111 TODC Battery Power Supply.
  19. ↑ 19.0 19.1 DEC, EK-PS780-TD-001, pp. 2-20 to 2-21, Table 2-9, H7112 Memory Battery Backup Power Supply.
  20. ↑ DEC, EY-2217E-SG-0001, p. 1-142. Power fail traps and AC LO/DC LO levels.
  21. ↑ "Who is still running a VAX/780?", Vintage Computer Federation forum, January 2024 to October 2024, forum.vcfed.org, pages 1 and 3.
