Sega CD (Model 1)
Revision as of 09:46, 1 October 2026 by Josh (talk | contribs) (Infobox photo; correct audio path (LC7883 for CD audio, LC7881 for PCM), mixing-cable direction and Sega's flow chart branches from the manual; dates and prices per Wikipedia (Sega Retro unreachable); page-specific manual refs; copyedit)
Sega CD Model 1 / Mega-CD
A Model 1 Sega CD with the steel joining plate fitted
TypeCD-ROM add-on for the Mega Drive / Genesis
Released12 December 1991 (Japan)
15 October 1992 (North America)
2 April 1993 (UK)[1]
Intro price¥49,800 (Japan), US$299 (North America), £269.99 (UK)[1]
CPU68HC000 at 12.5 MHz (sub CPU), fitted as MC68HC000FN12, HD68HC000CP-12 or TMP68HC000T-12[2]
Memory4 Mbit program RAM, 2 × 1 Mbit word RAM, 64K × 8 PCM RAM, 16K × 8 CD-ROM buffer, 8K × 8 back-up RAM[3]
StorageSingle-speed CD-ROM drive unit, Sony KSK-1200A or JVC ELM-135[4]
DisplayNone; video is produced by the Mega Drive
SoundRicoh RF5C164A (Sega 315-5476A) 8-channel PCM, with LC7881 and LC7883 D/A converters[3][2]
PowerExternal AC adaptor, 10 V DC 1.2 A[5]
OS / Firmware1 Mbit boot ROM, EPR-15045 or MPR-15045[3][2]
SuccessorSega CD (Model 2)
The Sega CD Model 1, sold as the Mega-CD outside North America, is Sega's original front-loading CD-ROM add-on for the Mega Drive and Genesis. It sits under the console, connects through the console's expansion port and adds a second 68000 CPU, more RAM, a custom graphics chip with scaling and rotation, eight-channel PCM sound and a CD drive with a motorised tray.[1] It produces no video of its own, and it has its own mains adaptor.
History
Sega released the Mega-CD in Japan on 12 December 1991 at ¥49,800. It reached North America as the Sega CD on 15 October 1992 at US$299, and the UK on 2 April 1993 at £269.99. Sega followed it with the smaller, top-loading Model 2, released in Japan on 23 April 1993 to bring down manufacturing costs.[1]
Architecture
Sega's block diagram, dated 2 July 1991, shows the following blocks.[3] Board positions are from the parts list for the export main board, 837-8952.[2]
Main functional blocks
Block Device (export main board) Notes
Sub CPU IC1, 68HC000 at 12.5 MHz Runs from the boot ROM and program RAM. The Mega Drive's own 68000 remains the main CPU
Gate array IC2, Sega 315-5548 "custom chip MCE2" (Fujitsu MB634120) Labelled MEGA-CD ENGINE on the block diagram. Connects both CPUs, the word RAM, the CD-ROM decoder and the PCM chip
Boot ROM IC4, EPR-15045 or MPR-15045, 1 Mbit In a 40-pin socket
Program RAM IC5, µPD424270, 4 Mbit
Word RAM IC7 and IC8, TC511664, 1 Mbit each WORD-RAM 0 and WORD-RAM 1
PCM sound IC3, Ricoh RF5C164A (Sega 315-5476A), with IC10 and IC11 (64K × 8 wave RAM) Eight channels
CD-ROM decoder IC13, Sanyo LC8951, with IC14 and IC15 (16K × 8 buffer) Error correction for CD-ROM data
Back-up RAM IC16, MB8464A, 8K × 8 Held up by the cell BT on the main board
Audio Sub board: LC7883 and LC7881 D/A converters, µPC844 op-amps CD audio from the drive goes through the LC7883; PCM goes through the LC7881 and a low-pass filter. The two are mixed, filtered at 20 kHz and sent to the LINE OUT jacks
Clock 50 MHz crystal oscillator
Boards
The unit has three boards and a drive unit. The export manual gives parts lists for the export boards and carries Sega's schematics and mount diagrams, which are drawn for the earlier main board 837-8015-01 and sub board 837-8046-01.[2][6]
Boards and drive units
Board Export assembly Earlier assembly What it carries
Main 837-8952 (PCB 171-6326A) 837-8015-01 Sub CPU, gate array, all RAM, boot ROM, CD-ROM decoder, PCM chip, back-up cell, LEDs
Sub 837-8953 (PCB 171-6327A) 837-8046-01 DC input, fuse, 5 V regulator, audio D/A converters and output stage, MIX and LINE OUT jacks
Connect 839-0534 (PCB 171-6328A) 837-8326 or 837-8327-01 The 60-pin edge connector to the console
Drive unit 610-5270 (Sony KSK-1200A) or 610-5270-10 (JVC ELM-135) Complete CD mechanism, servo and pickup
Console5 records the Sony KSK-1200A with a KSS-240A pickup and the JVC drive (PCB EMW10258 / ENN-335A-1) with an Optima-5S pickup. The two mechanisms share no parts.[6]
Power
The Model 1 has its own external adaptor. Sega's accessories list for Europe gives 400-5122A and 400-5122B for 220 V mains and 400-5127 and 400-5127A for 240 V, all 10 V DC at 1.2 A.[5] On the sub board the DC input goes through fuse F1, a Pico II 2.5 A radial part, and diode D1 to IC6, a µPC2405HF 5 V regulator on a heat sink.[2][6]
Servicing
Sega's PCB repair flow chart works at module level.[7] With no picture and no power, it blames the AC adaptor or the sub board. With a picture, it sends a missing CD-ROM screen to the main board or the Mega Drive, a tray that will not open or shut to the CD drive unit, no sound to the FFC cable between the main and sub boards, and a mixing fault to the plug cord or the Mega Drive. The drive unit is a complete assembly with a single Sega part number, and the manual gives no adjustment procedure for it.[4]
The electrolytic capacitors are the usual age fault: twelve on the export main board, ten of them surface-mount, and eighteen on the sub board.[2] See the Sega CD (Model 1) Capacitor Replacement Guide for the list, the Sega CD (Model 1) Troubleshooting Guide for fault finding and the Sega CD (Model 1) Maintenance Guide for strip-down and cleaning.
Things that are not faults
  • No picture from the Mega-CD on its own. It has no video output.
  • No CD sound through the television with a Model 1 Mega Drive. The CD unit's sound comes out of its own LINE OUT jacks; to hear the console and the CD together, the Mega Drive's headphone output is cabled into the input jack on the back of the CD unit and the mixed sound is taken from the CD unit. A Model 2 console does not need the cable.[1]
  • Two mains adaptors. The add-on has its own by design.
  1. ↑ 1.0 1.1 1.2 1.3 1.4 Sega CD—link(accessed 2026-10-01) Secondary source; the dates and prices are cited there to Sega's own Mega-CD page, Retro Gamer issue 153 and Computer and Video Games issue 138, p. 8.
  2. ↑ 2.0 2.1 2.2 2.3 2.4 2.5 2.6 Sega Enterprises, Ltd., MEGA-CD Maintenance Manual (Export), August 1992, Rev. A, section 8, parts lists for main board 837-8952 (PDF pp. 94-96), sub board 837-8953 (pp. 97-98) and connect board 839-0534 (p. 99). See Sega CD Service Manual.
  3. ↑ 3.0 3.1 3.2 3.3 Sega Enterprises, MEGA-CD Maintenance Manual (Export), August 1992, Rev. A, section 1, block diagram (PDF p. 5, "MEGA-CD HARD MANUAL", Ver. 0.5, 2 July 1991). See Sega CD Service Manual.
  4. ↑ 4.0 4.1 Sega Enterprises, MEGA-CD Maintenance Manual (Export), August 1992, Rev. A, section 2-2 assembly lists (assembly 1006, PDF pp. 19-20), section 2-3 disassembly and assembly procedure (pp. 23-24) and section 3 spare parts list (p. 26). See Sega CD Service Manual.
  5. ↑ 5.0 5.1 Sega Enterprises, MEGA-CD Maintenance Manual (Export), August 1992, Rev. A, section 4, accessories list for Europe (PDF p. 28). See Sega CD Service Manual.
  6. ↑ 6.0 6.1 6.2 Sega CD v1—link(accessed 2026-10-01) Secondary source: IC lists and capacitor lists read off real boards, including the earlier Japanese boards and both drive PCBs.
  7. ↑ Sega Enterprises, MEGA-CD Maintenance Manual (Export), August 1992, Rev. A, section 5, PCB repair flow chart (PDF p. 30). See Sega CD Service Manual.
